Question about Dryers
Tumble dryer trips electricity
I have an Indesit IS70C Tumble dryer and when i start to use it it trips the electricity in my house.
  • 3 Answers
I own the same machine and this happened to me, if the internal working of the machine get wet it will cut off causing the electrics to trip. This model is a condenser dryer, at the bottom of the machine if you open up the flap you will see the condenser on the left hand side, the manufacturer recommends that you clean this unit once every month and also empty the reservoir and clean the fluff filter after every use. While this may seem like a lot of hard work there is a very good reason for this. I suspect that your problem is due to a build up of fluff and or gunge in the condenser and bottom of the machine. Remove the condenser and give it a good clean of all fluff, you can run water through it either in the sink or bath as the best way to do this it is very fiddley using just your hands. Next check to see if there is a build up of water in the back the machine where the condenser usually sits, you will have to lie on your stomach and reach into the back of the machine (OBVIOUSLY ENSURE THAT YOU HAVE UNPLUGGED FROM THE MAINS SUPPLY BEFORE YOU DO THIS!) along the floor of the machine you will feel a channel cut into the plastic which runs into the sump at the back of the machine, if you have not cleaned the machine properly this is probably blocked and is the culprit. With this blocked the water is unable to travel to the pump that takes the water from the condenser into the resevoir at the top of the machine, and therefore it stays in the machine and can get thrown about onto the electrics and could cause the machine to cut out and trip your electrics! If this is not blocked check the black rubber pipe leading from the pump to the reservoir is not blocked, failing that perhaps the pump (in the plastic case at the back of the machine) is faulty and will need to be replaced. If water has built up in the machine you will also need to check to make sure none is sitting in the heater coil compartment (it did with mine) to get at this you will have to unscrew the metal plate at the back of the machine and let any water out. Leave the machine for a few hours to make sure it is dry and then give it another go. If your machine is still under warranty though i would call indesit first as they may get a little funny if you remove any of the machine covers yourself and refuse to look at your machine.
Posted on May 28, 2009
  • Dryers Master
  • 5,568 Answers
Your problem isn't very well defined; the dryer could be overloading the circuit it is on or it could have an internal electrical 'leak' causing a GFI (Ground Fault Interrupter) to trip. Those are very different problems.
It isn't too likely that the dryer is drawing too much current since they do use special plugs requiring a particular AC outlet for appliances. In the last few years, I have replaced circuit breakers serveral times that just would not stay set after tripping. So, the breaker could be at fault.
If it is tripping the GFI, then your dryer may have developed a dangerous problem that could lead to (potentially lethal) shocks if it wasn't there. These devices sense a difference in in the current in and current out. If they do not cancel, that means that a current is flowing from a 'hot' line to ground and the GFI trips since that lost current could be flowing trough your body.
Posted on Mar 03, 2009
Tumble dryer eeps tripping electric
Had same problem found a lot or water at the rear of the condensing element at bottom front of dryer because the float at the rear was blocked with fluff resulting in water being flicked up by the fan onto the heating element and tripping the electric. Cleaned out float compartment and been fine up til now. For a quick fix (UNPLUG FIRST) remove the condensing element at the bottom front of tumble dryer(behind the drop down cover) then carefully tip the dryer forward and to the left so that it practically balancing on the front left corner, you will probably get a fair bit of water come out so have some towels ready, then dry as much as you can see inside the compartment then replace element and should be good for quite a while until you have more time to clean out the rear compartment. Hope this helps, let me know.
Feb 11, 2014 | Indesit IS70C Electric Dryer
Make a lot of nosie
Hi mervyn2011
Sounds like you have a bearing problem or drum roller/slide problems.
You will need to take the dryer apart to determine which problem it is.
For an owners manual go to the following webpage
Please take time to rate me
Bud
http://www.indesit.co.uk/indesit/_pdf/manuals/19504260005_UK.pdf
For parts go to the following webpage.
http://www.ransomspares.co.uk/parts/brands/indesit/tumble-dryers/is70c/
Oct 16, 2012 | Indesit IS70C Electric Dryer
Why does my indesit is70c rattle when spining
the front or back wheel has gone they are plastic
Jun 28, 2012 | Indesit IS70C Electric Dryer
I've changed the belt on my indesit is60v but now it will not start could it be a loose wire? my test pen says power is going from the start button to the timer
Just because power is getting to the switch doesn't necessarily mean the switch isn't bad. It is also possible that the motor or timer is defective.
May 12, 2012 | Indesit IS70C Electric Dryer
My dryer trips my electric when i switch it on
this will be either the motor or control has shorted
Apr 20, 2012 | Indesit IS70C Electric Dryer
Hi I have an Indesit is70c dryer it seems to work fine for 10-15 mins but then trips the fues box in the house as it cuts out. I've had a look for at the fuse and have cleaned out all filters / condensers....
Do not overload the dryer as the motor can struggle and try to draw to much power.which could cause the trip to go to out, only load drum half full.....this applies to washing machines as well"NEVER OVERLOAD THEM" with washing machines it can affect the quality of your wash as well as putting extra strain on the motor.
Nov 08, 2017 | Indesit IS70C Electric Dryer
Indesit condensor tumble dryer does not heat up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 08, 2011 | Indesit IS70C Electric Dryer
Hi,my indesit IS70C tumble drier works but does not heat up.\possible causes please.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Indesit IS70C Electric Dryer
How can i fix my indesit is70c tumble dryer? my indesit is70c tumble dryer wont heat up during performance
open the back panel , not the the full back just the smaller panel located near the bottom half.
the termo will be screwed onto this panel . unscrew and you will see two circles near the top one will have a small pin hole in it . stick a pin in till you hear a click replace and should work fine
Mar 05, 2010 | Dryers
Dryers Logo
475 people viewed this question
Top Dryers Experts
