Question about Compaq Presario S6500NX (DQ181A#ABA) PC Desktop
0x75606eb5 @ 0x00000008 could not be read - Compaq Presario S6500NX (DQ181A#ABA) PC Desktop
  • Anonymous Mar 15, 2009
    I have the same problem
  • 51 Answers
It seems you have a memory problem. Open up the case and remove memory cards. Then re-insert them. Boot up. If the problem still exists you need to upgrade your memory.
Posted on Mar 03, 2009
SO184 able to read of82b?SO184 able to read of82b?SO184 able to read of82b?SO184 able to read of82b?SO184 able to read of82b?SO184 able to read of82b?SO184 able to read of82b?SO184 able to read of82b?SO184...
so184 just an adapter that he did not read the chip function so184 long as the customer can get him on the chip package on it. TSOP 32 is thought that this type of chip packaging can be placed inside the adapter.
May 17, 2014 | obd2-scanner Car Diagnostic Fault Code...
. In town of 500
real problems not jokes please:0
Sep 23, 2010 | Computers & Internet
Alina read 56 pags in 3 hours. At the same rate, find the number of hours it will take her to read the remaining 40 pages
> Alina reads 56 pages in 3 hours.
Alina reads 56/3 pages in 3/3 hours.
Alina reads 18 pages in 1 hour.
Alina reads 18 pages in 60 minutes.
Alina reads 40 pages in (40/18)*(60) minutes.
Alina reads 40 pages in (40*60)/18 minutes.
Alina reads 40 pages in 2400/18 minutes.
Alina reads 40 pages in 400/3 minutes.
Alina reads 40 pages in [about] 133 minutes.
Aug 02, 2010 | Computers & Internet
Change time
Hey here is something you can use to adjust the time on your T7206.To Change the Time:
1. Press the CHANGE softkey Display will read: "Hour:
2. Press the CHANGE softkey Display will read: "Hour: _ "
3. Enter the new HOUR. (in 24-hour format - Ex.: 5:00pm = 17:00. Display will then read the new Hour programmed.
4. Press NEXT Display will read: "Minutes: # # "
5. Press the CHANGE softkey Display will read: "Minutes": _ "
6. Enter the new MINUTES.
To Change the Date:
1. Press NEXT Display will read: "Date DD MM YY"
2. Press the CHANGE softkey Display will read: "Year: # # "
3. Press the CHANGE softkey, (If the year is incorrect) Display will read: "Year: _ "
4. Enter the new YEAR Display will then read the new Year programmed.
5. Press NEXT Display will read: "Month: # # "
6. Press the CHANGE softkey, (If the month is incorrect) Display will read: "Month: _ "
7. Enter the new MONTH Display will then read the new Month programmed
8. Press NEXT Display will read: "Month: # # "
9. Press the CHANGE softkey, (If the day is incorrect) Display will read: "Day: _ "
10. Enter the new DAY Display will then read the new Day programmed
Let me know how that turns out and good luck
Oct 03, 2008 | NorStar T7208 Corded Phone
Printing issue
In order to proceed with the solution to your problem, we'll need to save the current settings on your Crown printer and then restore the printer to its original factory settings as shipped. Your current settings will be saved, and can be restored after we finish this troubleshooting session. You will need to access the printers front panel in order to perform the following settings.
Procedure to save your current printer settings
Procedure to restore printers original factory settings
Procedure to restore your saved printer settings
1. Make sure the Online light is lit and that the display reads Idle.
2. Press the Online/Offline button to take your printer offline.
3. Press the Menu button once. The display should read Operator Control.
4. Press the Right Arrow button once. The display should read Administration.
5. Press the Select button once. The display should read Communications.
6. Press the Left Arrow button until you see Miscellaneous in the display.
7. Press the Select button once. The display should read Save Defaults.
8. Press the Select button again. The display should read No.
9. Press the Left Arrow button once. The display should read Yes.
10. Press the Select button.
11. A few seconds should pass until the display reads Yes Is Selected.
12. Press the Online button twice to take the printer online while the display reads Idle. Your current printer settings are now saved and you are ready to proceed with returning the printer to its original factory settings.
6. Press the Left Arrow button until you read Miscellaneous in the display.
8. Press the Right Arrow button. The display should read Restore Defaults.
9. Press the Select button once. The display should read Factory Defaults.
10. Press the Select button again. The display should read No.
11. Press the Left Arrow button once. The display should read Yes.
12. Press the Select button. Yes Is Selected will appear in the display.
13. A few seconds will pass and the printers display should read Disk And Flash Sys Loader.
14. Your printer will reboot with the original factory settings and return to Idle.
Try a test print. Does the problem still exist?
10. Press the Right Arrow button. The display should read Custom Defaults.
11. Press the Select button. The display should read NO.
12. Press the Left Arrow button once. The display should read Yes.
13. Press the Select button. Yes Is Selected will appear in the display.
14. A few seconds will pass and the printers display should read Disk And Flash Sys Loader. Your printer settings are now restored to their original saved settings
Try a test print, does the problem still exist?
Sep 24, 2008 | Minolta magicolor 3100 Laser Printer
Comdo fail to read DVDs'
  1. Check its DVD reading speed
  2. Try reading a prerecorded or original DVD disk for a movie for example, if it can read this then it means the DVD you are tryng to read were burnt at speed faster than what your DVD can read.
Mar 25, 2008 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Dvd writer doesn't read or burn dvd/ but only read CD-R plz reply to ka_s5@hotmail.com
have you installed the softwares to burn DV/CDs? maybe you hadn't installed the softwares yet. normally samsung uses NERO. check the installation kits.
Oct 31, 2007 | Computers & Internet
Compaq Presario S6500NX (DQ181A#ABA) PC Desktop Logo
784 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
