Question about Hayward 116k BTU HeatPro Digital Heat Pump HP21003T
Pool heat pump won't keep running
The pool heat pump won't keep running. When started, it starts and then immediately shuts off. This was done over and over. Pool pump is running fine. Why won't the heat pump continue to run and is the problem a serious one.
  • 3 Answers
Many heat pumps have a water flow sensor. If the sensor is bad and is detecting no water flow it will shut off as to not burn out the unit. You may need a service call to troubleshoot though.
Posted on Oct 24, 2013
  • 78 Answers
It is likely that you have a low refrigerant condition and require an HVAC person to service the unit. It's not unusual to need "freon" every so often. Call the repair man...
Posted on Apr 22, 2010
I have a Jacuzzi J340 Hot Tub. I am having trouble with the heating. When the pump is on, the water circulates just fine. once the heater kicks on, it runs for about 10 seconds, then clicks to OH, and...
make sure the heating element isnt touching the casing inside the heating tube. if its an indoor tub, make sure the filtration cycles are not set to constant. constant filter cycles on an indoor tub will generate residual heat from the circ pump running 24/7, causing tub to heat past 104 degrees
Sep 15, 2013 | Jacuzzi Pool & Spa
I have a Aqua Pro heat pump P130 with error code F5 does anyone know what that means
Error FS?
Unit has started defrost cycle and will reverse operation in 5 minutes.
If coolant has nor res=ached desired temp, unit will shut down and display FS
Other models:
FS can mean not enough water flow in cooling mode.
Mar 25, 2013 | Aqua Pro Swimming Pool Heat Pump 125000...
Pool Pump Runs Intermittently (~10 seconds on, ~1 minute off)
Need more info. What is the voltage at the pump? What voltage is the pump wired for? Sounds like your pump is shutting down from heat thru a safety. If the voltage is wrong the pump will heat up very quickly and a thermal switch will cut out, it will then cool off and try again. Get the readings at the motor connections NOT the breaker.
Apr 02, 2017 | AO Smith A O Smith Motors Century 1hp 115v...
New Versa 130 won't stay lit
if wired 120 volt then make sure wired correctly they come wired for 220 volt if 120 volt have to change wires if wired correctly change black and white its not rectifing
May 18, 2012 | Raypak Pool & Spa
Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Dec 26, 2011 | AO Smith Pool & Spa
Pool pump turns off after 1/2 hour or so but I can turn on manually after it sits for a while. Timer is working fine. Hayward Super II around 5 yrs old. Do I need to replace this motor? This problem just...
Your pump is protected by a thermal device that shuts it off when over heated. Are you running 110 or 220? In my experience, your pump will run cooler on 220 ... consider coverting if appropriate.
Aug 28, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Pool pump does not turn on
smell burn? replace motor. if not replace capacitor hard to get good luck
Aug 19, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I have a rule 1800 computerized pool cover pump. As soon as I plug it in, it runs a few seconds then shuts right off, WON"T keep running. (this is outside of the water, dry) any help?
That's a good thing. That pump uses resistance on the impeller to alert it to the presence of water. It will periodically start and run for a few seconds. If there is any water present, it will keep running, otherwise it will shut off until the next time it tries. Put it in water, and see if it works there.
Dec 12, 2008 | Rule H53sp 24mgra Swimming Pool Cover Pump...
Hayward 116k BTU HeatPro Digital Heat Pump HP21003T Logo
557 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
