Question about Kenmore 24032\24036 Top Load Washer
Spin cycle my washer has only had 1 load of wash put through it and it has been stored for app.2 yrs....it works fine but in the spin cycle the washer will try to run away on me and i have sone everything that i can think of...even making sure that it is level...what now?
  • henryatwk Mar 03, 2009
    first load ran though it and it starts bouncing around like it is off balanced
  • 188 Answers
Make sure the shipping pins have been removed. They're usually attached to yellow strap at the rear of the machine (sometimes people just cut off the strap so look underneath as well to make sure it has been removed). Looking at the inside, the washer drum should move freely from front to back and side to side.
Next is leveling. This is sometimes tricky in that it really has nothing to do putting a level on the machine unless your floor is uneven and adjustments need to be made to the front legs. As long as it looks fairly straight to the eye, level the machine by opening the lid, putting your foot in front of machine and holding the inside of the cabinet. Tilt the machine toward you and lift the rear of the machine about 2-3 inches (you should hear the legs drop). Set it back down. It should now be leveled since the rear legs are self leveling. Try rocking the machine from the top in a diagonal motion and ensure the weight is evenly distributed on all 4 legs.
If these things have been checked and it's still "walking" make sure the load inside the washer is not off balance.
Posted on Mar 03, 2009
I have an Estae(whirlpool) washer that i have had for 9 yrs. It works fine until it get to the spin cycle. Then it stops and the water stays in the washer and will not drain. Every different wash mode...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 12, 2010 | Washing Machines
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
My frontloader starts out fine , but when time to drain, it spins and only a small amount of water comes out,the spin cycle is so load and moves the washer while spinning also the cycle ends and the...
check water pump , from your discription i beleive you have a blockage before the pump this would account for the small amout of water removal
NEVER OPEN MACHINE CASE WITH REMOVING POWER PLUG FROM THE MAIN POWER SUPPLY
Jan 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Rattles like rocks in it when going to spin cycle! Less than 2 yrs. old
Your load is uneven, try spreading the load evenly before spin cycle.
Nov 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Sep 07, 2008 | Maytag Performa PAV2200
GE Top Load Washer 10 yrs. old, used for 3 years, stored after that
the water must drain out of the tank b4 it can spin make sure the pump is working ok
Nov 17, 2007 | GE WBSR3140DW Top Load Washer
MAYTAG WASHER SAV205DAWW
i can step you through it in a live chat session
Sep 27, 2007 | Washing Machines
Maytag LSE7804ADE Top Load Stacked Washer / Dryer
you'll need to by a sink kit at any hardware store and a sump pump , be advise at the place you buy . good luck .let me know take care
Jun 15, 2007 | Maytag LSE7806A Top Load Stacked...
Kenmore 24032\24036 Top Load Washer Logo
50 people viewed this question
Sal De
fordexpert
Robert Rankin
