Question about Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit
Delphi myfi xm2go
My delphi myfi xm2go won't turn on. The charger has a little light on so i assume that the charger works, but resetting it and taking the battery out and putting it back in doesn't work, so i have no idea what to do.
I cannot get my Delphi xm2go unit to turn on. I ran the battery out and have tried putting it in the docking station to recharge but it will not charge. I have gone through the taking out the battery and resetting through the little whole to the side of battery with battery out and battery in. Anyone know the secret to getting this fixed?
  • Anonymous Apr 20, 2009
    I have the same problem as stated above.
The power adapter is the problem.
I have two of these units.
The one I was using died and will no longer power on.
So, I called xm and switched to my back-up.
That one's dead, too.
I tried two adapters, four batteries and neither radio works.
BUT, I just happened to try a third adapter I had.
After re-setting the device (Take out battery, depress reset button with a pin. It's in the upper left in back. It's a VERY small hole.)
Then, I plugged the cord back in, and the battery is charging.
Apparently, the power adapters have a limited life span.
I'll be picking up a few new ones now.
Posted on Jan 14, 2010
  • 41 Answers
Replace the battery. Your Myfi will not work without it -- even if it is plugged into the charger.
Posted on Oct 04, 2009
Does a car's vibration somehow disconnect the charge from the power AC to the cradle? I have a unit in a minivan which works perfectly but in my Honda Civic, I have a duplicate unit and the charge doesn't hold.
Posted on Oct 03, 2012
2 Suggested Answers
TOLhamRadio
  • 509 Answers
SOURCE: My delphi myfi xm2go will not recharge. What do I
New battery - make sure it's WHITE and not a black one as the black ones were recalled.
Posted on Jan 26, 2010
The radio will not turn on ,not manually and not with remote
power suplay Transformer dies...
Try to find another suitable transformer and try running it
Nov 24, 2013 | Delphi Myfi Xm2go Portable Satellite Radio...
MYFI XM2GO WILL NOT TURN ON. ALSO WHEN I PUT IN CRADLE WILL NOT SHOW CHARGING
I had the same problem. This procedure from the "Technical Questions" section of http://shopdelphi.com/consumers/support/faqs/myfi/ worked for me:
"My MyFi won't power up, how do I reset it?
To reset your MyFi, start by turning the receiver off and removing it from its (car, home, audio system) cradle. Then remove the back cover and battery. Using a small paperclip, press the reset button located on the top left corner of the battery compartment. Now plug the AC power adapter into a wall outlet and plug the power port directly into the bottom of the MyFi (battery stays removed). Wait 10 seconds and listen for a beep. After you hear the beep the message "insert battery" will appear. Cycle the MyFi to ensure it powers up and powers down. If the power cycle is normal, then turn off the MyFi, unplug the power adapter, and reinstall the battery. Re-plug the AC power adapter directly into the bottom of the MyFi. Wait 10 seconds and listen for a beep. After the beep you will see the message "battery charging". Leave the MyFi plugged in until it's fully charged. You will see the message "charging complete" displayed. After the MyFi is fully charged, turn it on and reset to the factory defaults. Unplug the MyFi from the AC power adapter and using the battery power leave it on until it fully discharges (approximately 2-5 hours). Plug the MyFi in using the AC power adapter to recharge the unit and resume normal use. If you need help at any point during this process contact us at 1-877-463-3574 for technical support."
I hope it works for you too.
Sep 27, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
My Delphi XM2GO MyFi has stopped transmitting to an FM station on a house radio. Is it repairable? If so, is there a facility in the Cleveland, OH area where I can take it?
IF you take it out of the home dock and run it on batteries, I'll bet you it works again. The newer home docks TURN OFF the FM transmitter. Try a car dock, or try it with just the power plug plugged into the bottom of the MyFi, without the home dock and see if you can now get the FM transmitter to work. Let me know. Thanks and good luck.
Aug 09, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
No reception
your antenna connection inside the unit is broken on the circuit board,i had one of these and repaired it numerous times by taking the unit apart and resoldering the connection at the board,also their antennas don't last long as far as the antenna plug end is concerned
Apr 30, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
Nov 21, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
My delphi xm2go radio unit will not take a charge. Have tryed everthing! It starts to charge then goes dead!
I had the same problem, Based suggestion that the plug in the Radio is worn and not making contact, I used a small screw driver to shift the pin in the charger input hole from the center a little. That did it on both my Myfi;s. The now charge properly, and stay on as long as I need. Which needless to say, brings a smile to my face :) .
Apr 21, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Another manual
if you go to http://shopdelphi.com/consumers/satradio/xpressrc/ you can download the manual online and print it out.
Feb 11, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
XM2GO remote doesn't work
hi i have same radio try turning the radio off and taking the battery out for a minute or so and putting it back and turning it back on worked for me
Nov 27, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi myfi xm2go
I have the same problem. I finally was able to get Delphi Tech Service and found out that these units have a flaw. they have been going out after about 14-18 months and there is no known repair... neither does Delphi offer a repair service for this problem.
Dec 17, 2007 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit Logo
1,572 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
