Question about Refrigerators
Refrigerator compressor will not kick on
Amana 20 energy saver. Moved from parents house to future wife's. Laid down horizontally for 40-50 mins, then stood vertically for 36 hrs before attempting to power. Lights come on, compressor will not kick on. Is there a safety kill switch that I can reset? If so, How?
model - BX20NL
s/n - 9012068674
manufactoring # - P7812527WL
In advance, thank you for any assistance
  • 400 Answers
Is it possible that with the moving a cable may have been pulled. Open the cover on the compressor connections and check that all wires are fitting snug.
Posted on Mar 05, 2009
KitchenAid KBRA22KL Moved houses and now fridge and freezer will not cool. Lights work. Here fridge has power but not kicking in the condenser. Is there a reset somewhere or is it fried. Pls help!
you must have laid the refrigerator down during transport. compressor oil is now blocking the capillary tube. just keep trying by plugging in for a few minutes every couple hours until the oil finally clears the capillary tube
APPLIANCE 911
Jul 24, 2016 | KitchenAid Refrigerators
How do I get my Samsung fridge model #rs25hs5000bc off demo mode? I tried holding down energy saver and power freezer but doesn't work.
IT is three buttons not two. Cooling Off mode (also called Shop mode), is designed for use by retailers when they display refrigerators on the shop floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and the refrigerator and freezer do not get cold. To start Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button for 5 seconds during normal operation. The refrigerator chime sounds and O-FF appears on the display. To cancel Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button again for 5 seconds, until the chime sounds. Cooling Off mode is only available on refrigerators sold in the U.S. Instructions are on page 20=> HERE
APPLIANCE911
Apr 12, 2016 | Samsung Refrigerators
We moved a side by side refrigerator to a different location(from the house to the garage) and the tempterature on the refrigerator side is staying about 48.I have lower the thermostate. Any suggestio
If you moved it, hopefully it was not laid down and remained upright as this can damage compressor. If you were careful and it did not get radically tilted down, then you may want to unplug for a hour or so and see if it clears up. Most often when this happens it is defrosting issue, as in, build up of ice blocking fan operation. Unplugging will melt blockage and help narrow problem down.
Sep 08, 2014 | Refrigerators
Moved refrigerator about 2 miles it was laying on its side for about 20 minutes... got it to the second location have plugged it in and it does not work... what could be wrong????
When you laid it on it's side all the oil inside the compressor went up into the evaporative coil lines. The oil bypassed the seals inside the compressor. You should NEVER lay a fridge on it's side or back. It will never work right again, sorry.
Dec 09, 2010 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
I have some problem with my AMANA BX20ML Model REFIGERATOR
You may have a bad condensor fan motor or paper may have gotten pulled under the fridge and jammed the fan blade. The energy switch will not help with cooling it only controls exterior moisture.
Feb 16, 2010 | Refrigerators
Moved our GE monogram to new house; was laid on side; now plugged in the motor does not kick on...all lights come on; worked fine before
Oooh -Refrigerators do NOT like laying down.
If you have done this - leave upright - unplugged for at least 4 hours before restarting.
If it has had this - it is possible the compressor may be offcentre inside it's black casing.
Try knocking it fairly hard once or twice, then plugging in again.
If this does not cause life to return, then it needs a serious look at to determine if it is getting power to it, if the control board is doing the right thing, and if the thermostats are set right.
Try resetting the thermostats really low to start with - and see if it wants to try cooling.
Aug 16, 2009 | GE Monogram Side by Side Refrigerator
Amana Refrigerator cooling problem
The energy saver switch doesn't really save you anything, all that does is turn off the mullion heater circuit which if you really add up the pennies on your electric bill, might save you enough in one year to cash in for a bite size snickers bar... leave that off. Replace the operating thermostat (freezer thermostat) to correct this problem. If you're concerned with being green, after you replace the thermostat, turn on the energy saver and see if this makes any difference, it shouldn't in operating temperatures. Wiring and diagrams are usually available at sears, or by visiting searspartsdirect.com.
Aug 06, 2009 | Refrigerators
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Kenmore side by side shorts out when plugged in
Try a different circuit to plug the fridge. Possible you GFI is weak and can not take the start surge of the compressor. Refrigerators need to be on 20 amp circuits and not on same circuits with lights ,televisions,etc.
Also if the refrigerator has be laid down on its side during moving give it 24 hour for the oil to return to the compressor. This also is a symptom of overload on the compressor.
Let me know what you find..Sea Breeze
Jan 31, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Cooling
if you have laid the fridge down as you moved it make sure that it sits upright for at least 15 mins before you turn it on again (this alowes the oil in the compressor to level back into the sump)
make sure that everything is running in it - the compressor - any fans and that all airflows are ok.
If all is working then it is a refrigeration problem. low gas, blocked pipes or filter. This will have to be looked at by a refrigeration mechanic
Apr 09, 2008 | Maytag MSD2756GES Side by Side...
Refrigerators Logo
344 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
