Question about Hotpoint 23 in. BFI68 Built-in Dishwasher
Hotpoint Dishwasher BFI 680 (BFI680) LED 7 Flashing
Hi my Hotpoint Dishwasher BFI 680 (BFI680) will not start. It powers up OK but LED light 7 (program number 7 duo wash mode furthest on the right) flashes and I cannot change the program or start a program.
Many thanks in advance
5 Suggested Answers
  • 38 Answers
SOURCE: Dishwasher does not heat up
the heater t.o.c will be blown it may be resetable access by removing the side panel if the stat is resetable it will have a red button on the top simply press till you hear a click good luck
Posted on Jul 21, 2007
SOURCE: function buttons do not work on off button does
I have expreienced the same problem and carried out a hard re-set by holding down the on/off switch whilst pressing the program button. It's now working - but not sure for how long!
Posted on Feb 28, 2009
  • 44 Answers
SOURCE: Hi My BFI 680 trips the electricity at the mains.
could a internal fault in m/c[shorted wires] water,faulty on /of switch,recheck wiring to m/c
Posted on Dec 31, 2009
Daniel S
  • 4323 Answers
SOURCE: My BFi 680 dishwasher swithches
Hi
The timer is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 21, 2011
  • 31 Answers
SOURCE: My Hotpoint BFI680 dishwasher trips
This is caused by having a dryer element, if you are able to get to the back of the element look for where the wires connect to it, I am almost positive the element is bad, always turn off the power when looking at any electrical unit to service , if not sure use a tester, you should have zero volts at the connection box near lower right hand side near floor. you can get this element from here if you have all the information on this unit, http://www.appliancepartspros.com/ you can also email me at glipsky@tampabay.rr.com good luck
Posted on Jul 26, 2011
My dishwasher is just flashing F10 all the time
Codes are pretty generic between Hotpoint, Hoover and Whirlpool.
Heating element fault
Issue: The LED lights on your dishwasher are displaying in the following sequence (please see below these error codes for your LED reference
  • LED 1: OFF
  • LED 2: ON
  • LED 3: OFF
  • LED 4: ON
Action: We recommend you call our customer service centre to book an engineer.
Here is the Hoover site.
http://service.hoover.co.uk/advice-centre/dishwashers/
Error codes Hotpoint
Jun 19, 2016 | Hoover 24 in. HD97E Free-standing...
I have an hotpoint sdw60 dish washer that is flashing 2 yellow lights, these are numbers 5 and 7 (fast and dry 40c) and (delicate 50c) can anybody tell me what this means.thankyou
Hotpoint Indesit dishwasher flashing lights fault error codes ...
? 15:08
www.youtube.com/watch?v=FRLbrBPHcnE
May 3, 2015 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/hotpoint-aquarius-fdm-dishwasher-flashing-lights-and-there-fault-codes ...
Oct 02, 2015 | Hotpoint Dishwashers
Whirlpool quiet partners II normal light flashing
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Dec 18, 2013 | KitchenAid 24 in. KUDI02IR Built-in...
HOTPOINT DISHWASHER BFI 620 ERROR CODE LED FLASHING 1 & 3
Check the end of your drain hose for the clog.
Feb 17, 2013 | Dishwashers
Hi My BFI 680 trips the electricity at the mains just as you put it on. Have cleaned the filters. Any ideas ?
Dec 31, 2009 | Hotpoint 23 in. BFI68 Built-in Dishwasher
Function buttons do not work on off button does
Jan 06, 2009 | Hotpoint 23 in. BFI68 Built-in Dishwasher
Hotpoint Dishwasher BF1620
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Mar 21, 2008 | Dishwashers
Jul 21, 2007 | Hotpoint 23 in. BFI68 Built-in Dishwasher
Open Questions:
See all Hotpoint 23 in. BFI68 Built-in Dishwasher Questions
Hotpoint 23 in. BFI68 Built-in Dishwasher Logo
113 people viewed this question
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
bosch5
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
