I have a motherboard that is not conected fully and i cant use the USB ports on the front of the computer or the jack points . The number onthe board is TDG1LA.
I also have the problem in that when I try to send a voice mail on WINlive, I get the message ''your voice clip was not sent because no sound was detected in the recording, I am conected into the rear ports. Could both problems be related.
SOURCE: Dell E-1705 Motherboard Replacement
Start by checking ControlPanel/System/Hardware/Device Manager. Look for yellow marks that indicate devices not installed properly. This is usually a driver issue, and Dell should have given you a disk with the drivers you need.
Are you getting any error messages?
SOURCE: My computer restarts before installation completes
Hi wabee,
I'll go out on a limb & ask you if the system was restarting before you tried to install, VIA Vinyl Audio? I'm guessing it did not.
Do not try to install any more. If possible try to run windows update. Here's why. Something does not agree with the download. Either the software Vinyl is corrupt, your current system configuration software does not agree with the software driver or your current hardware does not agree with Vinyl. Even though VIA created both Vinyl & AC97 audio. Its possible windows up might have a software fix or update that will repair or update your install of vinyl driver. If not...
Please uninstall the driver if at all possible & pray it did not over write too many system files. If you’re lucky you can uninstall the driver through add/remove programs.
If not than run windows System Restore.
Was this the link you downloaded from?
http://www.via.com.tw/en/products/audio/
wabee, when windows XP home edition first came out there were a lot of problems with sound drivers & programs like Rioax. They would restart the PC. Restarts are also common with
Certain driver files conflict with irq sharing & cause windows to restart. In your bios where it asks PnP OS, if you set it to yes than windows assigns irq's. If you set as no, than the bios sets the irq's. Do not change your current bios settings until your system is running correctly.
Let’s hope system restore works. Lastly you can turn off the auto-reboot by opening System control panel, click Advanced, startup & Recovery and untick 'Automatic reboot'. Then you can see Blue Screen and then diagnose the problem.
Blue screen fixes. http://aumha.org/a/stop.htm
Let me know how things turn out.
Have more questions, feel free to ask.
Best of luck!
Mike
SOURCE: i am trying to hook up front panel usb ports.
check out this diagram i think it might help you
http://attachments.techguy.org/attachments/107266d1180693321/standard-usb-pinout2.gif
or if the link is unavailable then here is the same info
pins 1,3,5,and 7 are one usb connection
pin 1 = +5V
pin 3 = D-
pin 5 = D+
pin 7 = GND
pins 2,4,6,and 8 are another usb connection
pin 2 = +5V
pin 4 = D-
pin 6 = D+
pin 8 = GND
pin 10 is not used
SOURCE: looking for manual for Asus motherboard A8V-VM SE
Here is a direct link to the manual for that motherboard. Hope it helps.
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8V-VM_SE/e2928_a8v-vm_se.pdf
SOURCE: asus p5kpl-am in USB and Sound not detectiing
try to make an adjustment on your bios i think usb is disable try to enable it and sure all your usb will work.
