There are lots of ways you can try to update iOS6 & 7 to latest version. Follow one of them.
If a message says that an update is available, you could then click "Install Now" button to start to update your iPhone iOS software. Also, you could manually check whether there is an iPhone iOS update or not on your iPhone. The below steps would show you how to update iPhone software wirelessly:
Before you update iPhone software via WiFi connection, you need to make sure your iPhone has enough storage and battery to support the iPhone update.
Connect your iPhone to a WiFi network.
Tap "Settings > General > Software Update" successively.
Tap "Download and Install" option when your iPhone has detects an update available. If a message asks to temporarily remove apps because iOS needs more space for the update, tap Continue or Cancel. Later, iOS will reinstall apps that it removed.
Then iPhone would start to download and install iOS update immediately. You only need to wait for the update complete.
Before you can charge your iPhone on the computer, your computer needs to install the drivers for it. You might have to reinstall the drivers for it. A good way to check if the drivers are incorrectly installed is to see if iTunes detects it. Try updating your iTunes since the old version of iTunes won't work with ios6 and all iPhone 5 are shipped with ios6
You can do it via following steps.1.Update iTunes to the latest version if you have not updated recently. To find out if you need to update, launch iTunes and click "File" followed by "Check for updates." If you are on a Mac, click "iTunes" followed by "Check for updates." If you do not have the latest version installed, a dialog box will appear asking you if you want to download the latest version. Click the "Download iTunes" button. 2.Connect your iPhone to your computer using the USB cable that came with your iPhone. iTunes will automatically recognize your iPhone and an icon will appear in the left-hand column of iTunes. 3.Click the iPhone icon and the "Summary" pane will appear. 4.Click the "Contacts" tab located across the top of iTunes. 5.Click the check box next to the "Sync contacts with" field. 6.Click the drop-down menu in the "Sync contacts with" field and select a program to sync your contacts with. If you are on a Windows machine, you can choose from four options: Yahoo! address book, Windows address book, Google contacts, or Outlook. If you are on a Mac, your contacts will be synced with the Address Book utility. 7.Click the "Sync" button and all of the contacts on your iPhone will be saved to your computer's address book. Included in every contact will be the contact's phone number. Subsequent syncing will add any new contacts you have entered manually on your iPhone. Hope it can help you.
Hi, You can import phone data from a Subscriber Identity Module (SIM) card to the address book application on your BlackBerry smartphone.
Contacts in the address book can be saved to the SIM card individually. You cannot import data from the address book to the SIM card. To import a single contact, complete the following steps: 1)On the BlackBerry smartphone Home screen, open the Address Book. 2) Display the menu and select SIM Phone Book. The SIM phone book is loaded. 3) Select the contact you want to import, then select Add to Address Book. 4) In the New Address screen, add any additional information. Import all contacts, complete the following steps: 1) On the BlackBerry smartphone Home screen, open the Address Book. 2) Display the menu and select SIM Phone Book. The SIM phone book is loaded. 3) Display the menu and select Copy All To Address Book. 4) Go back to the Address Book and make sure all the entries are displayed. After adding information to ddress book you can able to veiw contact list, I hope this information will be helpfull.
To add your SIM contacts to your BlackBerry Address Book.
1. Press the 'Menu' key. 2. Highlight 'Contacts' and select (press the trackball). 3. Press the 'Menu' key. 4. Highlight 'SIM Phone Book' and select (press the trackball). 5. Press the 'Menu' key. 6. Highlight 'Copy All to Contacts' and select (press the trackball).
To add your Black Berry Address Book contacts to your SIM.
1. Press the 'Menu' key. 2. Highlight 'Contacts' and select (press the trackball). 3. Highlight the contact you wish to move and press the trackball. 4. Highlight the number and then press the trackball. 5. Press the 'Menu' key. 6. Highlight 'Copy to SIM Phone B...' and press the trackball. 7. Press the trackball and highlight save and press the trackball again.
From the standby screen, press Menu. Scroll to and select Address Book. Scroll to and select Contact List. Scroll to desired contact, press Options Scroll to and select Edit Edit the desired fields, press Save
If you have an unblocked iphone and have put your old sim card in, then your iphone won't read the sim. All phone numbers are stored on the iphone not your sim.
Ive tried a few ways to read it but no success. Sorry.
