Question about Sharp AR 201 Copier
Incomplete copy Sharp AR-201- the bar that travels the length of the page to be copied goes 3/4 of the way and then back.
  • 29 Answers
The paper is set to 8.5-11 and you are running letter r paper u must set the copier tray to the proper size
Posted on Mar 09, 2009
How do I print both sides of a document on legal size paper?
tell the copier you have a two side orginal. then scan one side then scan the other
try this site
http://siica.sharpusa.com/product-downloads
Dec 02, 2014 | Sharp Ar-202nt Toner Cartridge Ar 162,...
Paper jam during copy
need complete report where jaming and after how many copies
Feb 05, 2011 | Sharp AR 201 Copier
Arm 205 display error F5 02 what this the solution for resetting ???/
the error F5 02 means that the copy lamp lighting is abnormal.
This is what is in the service manual:
F5 02 Content Copy lamp lighting abnormality
Details The copy lamp does not light up.
Cause Copy lamp error
Copy lamp harness abnormality
CCD PWB harness abnormality
Check and remedy
Check the copy lamp (SIM 5-3)
When the lamp lights:
Check the harnesses and connectors
between the CCD unit and the MCU PWB.
When the lamp does not light:
Check the harness and connector
between the copy lamp and the MCU PWB.
Replace the copy lamp unit.
Replace the MCU PWB.
Remarks Copy lamp disconnection
Cable is not attached.
You must call a tech to solv your problem.
Dec 01, 2010 | Sharp AR 201 Copier
A brod white patch on centre con copy Sharp AR 163
check the developer in the developing unit maybe the developer is empty,then also check the charging assembly maybe its pour of toner just try to clean
Sep 03, 2010 | Sharp AR 201 Copier
My sharp copier ar 5316 has printed 0nly les than 1600 pages and now showing toner cartridge low, even les than 10%
please check the devoloper , if the quantity is lessthan the specified the same quantity will be filled with toner.
Oct 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR201 COPIER
Hey Robert,
Sounds like it could be in need of a maintenece kit. The ghostinf is usually caused from the fuser or transfer roller. And that would also apply to the band down the page.
Feb 13, 2009 | Sharp AR 201 Copier
Sharp AR-207 copier puts .5 inch black line across entire bottom of copy
does the line only show up when making copies from the adf or both when you put it on the glass. if only when thru the adf the **** glass is dirty. that is the glass that is only about an inch wide. be carefull of the two pieces of tape that are on both the front and back of that glass they fall off easly.
Oct 18, 2008 | Sharp AR-207 Copier
AR201 displays e7
Could you be more specific? e7-03 is trouble in your laser unit, e7-04 is dirt on your inside white strip which helps your copy lamp find the home position, and e7-05 is trouble with your copy lens.
Apr 28, 2008 | Sharp AR 201 Copier
Sharp AR 201 Copier Logo
50 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
