Question about Mitsubishi Heating & Cooling
Error code E39 for Mitsubishi Heavy Industry Ceiling cassett type
After out door unit run on 3min ,Error code E39 appear on remote controller and then both indoor and outdoor shut down.
    Scholar:
  • 67 Answers
E39 Fault is thermister, Mitsubishi way of saying im not going to start because there is something wrong. Generlly it is compressor fault or short of gas. Im guessing if you turned the power out. Waited twenty seconds, turn it back on. Now if you go to the outdoor part. Wait exactly 3 mins. If you hear the compressor try to start and fail then it would more then likely be your compressor if you dont hear anything and the unit faults out it will either be a board or short of gas.
Either way If the unit is under five years old get a warrenty agent out to look at it.
Sorry I couldnt tell you for sure but MHI are very vague when it comes to fault codes
Posted on Mar 05, 2009
What does error code E39 mean
Hello friend, thanks for your post!
I see your asking for the meaning of an "E39" error code. Your appliance is listed under Electrolux range. Would you be able to provide me your model number so that I can verify the correct meaning for "E39"? On a range you can locate the serial tag (which lists your model number) on the lower storage drawer on the right hand side. On an induction cooktop it would be located on the outside of the appliance base possibly on the edge or bottom under the unit. I look forward to assisting you. -Matt
Jul 26, 2014 | Electrolux 30" Induction Built-In Range...
Mitsubishi Heavy Industries Cassette Out Door Model: FDC506HES. What is the BTU size?
1 ton of ac is 12000 btu. you should probably call mitsubishi they have a tech support that will help you with this. the number is usually in the paperwork that came with the unit. you may find it on the tag where you got the model number
Oct 15, 2013 | Mitsubishi MSZ-FE12NA MUZFE12NA Mr Slim...
Mitsubishi Error Codes what is a P8 error code on an under ceiling unit that is not cooling
P8 denotes a fault related with its power supply regulator board. If you wish to get more details about the error codes to Mitsubishi, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option
Oct 05, 2013 | Televison & Video
Hampton bay remote code
type in your remote and type in codes at the end
May 04, 2013 | Universal Remote Control Hampton Bay...
My airconditioner will not turn on using remote control
Check there will be error code: If not check power to indoor is perfect. Error code details as follows
Code E3
Error detail Remote control transmission error(transmitting error)
Inspected unit Remote control.
Code E4
Error detail Remote control transmission error (signalreceiving error)
Inspected unit Indoor.
Dec 10, 2010 | Mitsubishi MSZ-A15NA Split System Air...
I have a problem code...its says check EO
Signal transmitting/receiving
error
(Indoor controller does not
respond to remote controller
signal.)
During individual unit control
1) Bad contact of transmission
wire
2) Signal transmitting/receiving circuit
is abnormal.
1) Check the transmission wire.
2) Check with another remote controller. If "EO" is
still indicated, replace the indoor controller
board.
If other check code appears. replace the original
remote controller.
P3 Signal transmission error
(Remote controller does not
respond to indoor controller
signal.)
wire
is abnormal.
3) Wrong operation due to noise
wave emitted
Nov 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
P8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
May 31, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Bmw e39 business radio dashboard volume control knob doesnot adjust volume 2002 in the year. any suggestions?
if you have the unit w/cassette player...cassette player needs checking...i just ordered 1 today...cassette player guts control radio
Mar 21, 2009 | Car Audio & Video
LG Split system (ceiling cassette)
Check your remote control by using your camera or cellphone camera as your eyes. Point the remote control to the camera and "on" the remote control. If no lights emits in the remote control means that your remote control is defective If lights emits then the remote control is ok. Try also to locate the reset or rst button on the remote control if available and reset it, then try. If it wont work may be the receiver board in the unit is defective.
Jan 14, 2009 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
1,491 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
