Question about GE Energy Star SDL20KCSBS Bottom Freezer Refrigerator
Slow condenser and evaporator fans on SDL20KCSABS
  • 3 more comments
  • beerslayer24 Mar 03, 2009
    Thanks MNTECH, I purchased the refrigerator in April '06. The fans seem to be running slower than normal and cooling performance seems lower. Fan noise is definitely lower than usual from this unit, as I remember.Temperature in the cabinet has risen to 45F from 38F.
    OK, now we are getting somewhere. I unplugged for 20 minutes. No excess water or dripping during the 20 minutes. Both fans seem to be still running on low speed after plugging back in. I would guess that the voltage could be checked at the fan or the board. Any suggestions as to where to start first? I found the condenser fan WR84X10055 rated at 11.5V, 2.54W. Thanks for your help. It's great fun to fix things.
  • beerslayer24 Mar 04, 2009
    I have performed the VDC measurements. On the J2 connector, pin 4 (yellow on my machine) to pin 3 (white) is 7.50 VDC and for the condenser fan, pin 8 (red) to pin 5 (pink) is 7.98 VDC. Is the .48 VDC difference between the two fans is significant? The tests would seem to indicate a new board is in order. By the way, I never did find the wiring diagram.
    After performing the first set of VDC readings, it occurred to me that maybe the cabinet was not sufficiently warm to activate the higher fan speeds. So, I opened the door and allowed the cabinet to reach about 60F, 5-10 minutes. Sure enough, after closing the door and waiting a few more minutes, I could here increased evaporator fan noise but the condenser fan was still in slow mode. The VDC tests were performed again and pin 4 to pin 3, (evap. fan) is 12.64 VDC, while pin 8 to pin 5 (cond. fan) remained at 7.98 VDC. Does this still indicate main control board replacement? I wonder if there is another sensor or system that would override high speed running of the condeser fan.
  • beerslayer24 Mar 09, 2009
    Yes MNTECH, life can get hectic sometimes, some days are just not long enough. Fortunately for me, the refrigerator has regained efficiency after all this testing. Of course now there is not a dust bunny to be found and the fan blades have been cleaned **** and span. Temperature is now running 35-37F, instead of 45F, which set off my alarm bells. I had a surprise when testing the fan votlages with the J2 connector removed. Evap fan, pins 3&4, was 13.6 VDC, as expected, but, the cond fan, pins 8&5, indicated 0 (zero) VDC. I was expecting to read the 8 VDC I see with the J2 connector in place. What do you think?
  • 1,543 Answers
Newer GE refrigerators use variable speed DC fan motors to improve energy efficiency. Fan speed is determined by the electronic control board. Your refrig is working as designed.
Please don't rate solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Posted on Mar 03, 2009
  • 1 more comment
  • Carl Schulzetenberg
    Carl Schulzetenberg Mar 03, 2009
    I have seen on a few rare occasions that the main control board (part number WR55X10656 for your model) no longer puts out the high speed voltage level. (If I remember correctly off the top of my head that is about 12 to 15 VDC, low speed around 6 to 8 VDC) Before replacing board, try unplugging for at least 30 seconds to reset electronic board. (That may save you the cost of a board) Air flow and thermistors are other possiblities, like a frost blocked evaporator, but if both fans seem to be running slow, it seems to be pointing to the electronic board. Good luck.
    Carl Schulzetenberg Mar 04, 2009
    A typical check for this would be to take the cover off the main control board on the back of the refrig and check the J2 connector, pin 4 (yellow/black wire) to pin 3 (white wire) for the evap fan motor and pin 5 (yellow wire) to pin 8 (red wire) for condenser fan motor to look for about 13 VDC for high speed when the refrig temp is warm. (about 8 VDC for low). if not getting the 13 VDC, replace the board. YOUR PLUG, PINS NUMBERS, AND WIRE COLORS MAY BE DIFFERENT than this example. Find your electrical diagram to see for sure. It is usually printed on a thin plastic sheet folded up and tucked in where the wires hook up to the temperature controls.
    Carl Schulzetenberg Mar 08, 2009
    Sorry I was not able to respond sooner. My last few days have been very hectic. The .5 VDC difference in output fan voltage is not significant. That was a good idea to let the refrig warm to test the board output voltages with a warm refrig interior. Both fan should have been seeing the aprox 13 VDC at that point. Considering that you did not get the higher voltage to the condenser fan, I would replace the board. (with warm refrig, you should really disconnect the J2 plug and test voltage output from the pins on the board, not just the wires with the plug still attached to the board)
Commercial fan on evaporator cuts off after starting
There is an overheat klixon on the evaporator that stops the fan running until the coil gets below -11c This can take some time after startup. if the freezer runs more than an hour before the fan starting, check the klixon isn't faulty, and you have power to the fan. Also check the condenser grille is nice and clean as it will slow down the freezing process.
Apr 17, 2014 | True Freezers
Why would evap fan running slow
If u turn the fan by hand and it turn then u need a new fan, and i think u are mixing up the fans, the fan inside the refrigerator would be the evaporator fan if that was broken then your compressor would be cold, the fan inside the compressor section would be the condenser fan, if that was defective then your compressor would be hot causing the compressor to short cycle. change the fan and clean your condenser coil and your problem should be gone,
Jan 17, 2013 | True TSSU-27-12M-B Commercial Refrigerator
WRS6R3EW8 Refrigerator and freezer not cooling. Evaporator coil 60 deg. only. Compressor, evaporator fan and condenser fan running. Some frost on the tubing coming from condenser at the evaporator. ...
Where is it frosting, condenser or evaporator? If you mean frosting on evaporator line to compressor, probably iced up evaporator. If you mean frosting after condenser by capillary, unit short of gas/ blocked.
Apr 27, 2012 | Refrigerators
Frig leaking from the bottom, a slow leak.
Most likely defrost water not evaporating and running over drip pan onto lloor.
Check the bottom coils... Dirty coils can block air flow and prevent defrost water evaporation. Also check fan. Air pulled across defrost water evaporates it. If fan is not running, refrigerator will also be inefficient, as refrigerant condenser needs air flow over the coils to work properly.
Jun 15, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerator is not cooling
Dirty condenser, condenser fan or evaporator fan motor are not running, Ice build up on evaporator and restricted the air flow. If compressor, condenser fan and evaporator fan motor are running but not cooling, then either compressor or sealed system problem.
Mar 07, 2010 | Refrigerators
Refrigerator and freezer are not cold
possible causes: bad door seals or condensate drain plugged causing evaporator coils (in freezer) to ice up, condenser or evaporator fans not on, condenser coils dirty, compressor not working, or a freon leak. if the back wall of your freezer is frosty or super cold, the coils are iced up. remove the back wall and defrost it with a hair dryer. if the water doesn't drain, unclog the drain tube. check the door seals for gaps. replace if necessary. check the fan in the freezer and the fan in the back. both should come on when the compressor is on. if not, check the fuses on the main board. replace if needed. if all that is fine, and there is no frost, you have a slow leak or a bad compressor. call in a pro or get a new fridge.
Nov 12, 2009 | Kenmore 57029 Side by Side Refrigerator
My maytag bottom freezer works but the fridge is not cooling all of a sudden. Just had the compressor replaced
Nov 12, 2009 | Jenn-Air JCD2389G Side by Side...
Kenmore 18 top freezer doesnt freeze completely. refigerator cools to 48 f .
Nov 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
My samsung rb 1855sl is having an issue where freezer is not working.
Nov 12, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Evaporator fan turns on. compressor and condenser fan do not turn on.
Sounds like low on refrigerant charge. Low pressure switch keeping the compressor and condenser fan from running.
Jun 05, 2009 | Carrier Heating & Cooling
GE Energy Star SDL20KCSBS Bottom Freezer Refrigerator Logo
629 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
