Question about Liebherr KELB 2840 Premium biofresh Refrigerator
Liebherr fridge 3150 keeps freezing
The fridge keeps freezing food. I have cleared the drainage hole into the evaporator but still keeps freezing. Can anyone help? Chris
  • 400 Answers
The problem is the thermostat, not the drainhole. The thermostat should stop the compressor when a setpoint temperature has been reached, this gives the unit a chance for a small defrost.
Posted on Mar 05, 2009
My bottom freezer just started having ice build up. Unable to find source as to why. Ice is now forming on my food. SEARCH
Freezer /fridge water/ice in fridge
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Mar 06, 2015 | Refrigerators
GE PSDS5YGXCFSS - Water keeps pooling in fresh food section
Freezer /fridge water/ice in fridge and or freezer
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
God is so good: so this is why I give free advice so please thank him not me.
Nov 06, 2013 | General Refrigerators
We have a hotpoint RLA 34 ( MICROBAN ) FRIDGE . water keeps seeping into the bottom , under the crisper box tried turnining temp down , made sure it's level , no blocked drainage hole . door shuts tight...
You said no blocked drainage hole, where was the drainage hole that you checked located? Did you pour water down this drain, and furthermore did you check that the water you poured into the drain flowed into the condensate pan on the outside of the fridge? Unless you have a problem with an ice maker leaking water, it sounds very much like you do have a blocked drainage hole, otherwise known as a defrost drain. the drain system begins underneath the evaporator coil inside the freezer, this is where the water that is collected in the defrost cycle flows into a drain tube that leads the water down to the condensate pan. The best and safest way to clear out this drain is to blow it out with compressed air, after you remove any and all ice at the beginning of the drainage system, in other words, the hole located underneath the evaporator coil.
Nov 09, 2010 | Hotpoint RLA31 Compact Refrigerator
Fridge is freezing food
I have had the same issue with thick frost/ice at the back of my Fridge and almost called an engineer and considered replacing it.. BUT you don't want to so that: Do this:
1. Take freezer draws out and empty fridge so it is lighter and easier to move Fridge Freezer out
2. Chuck some warm soapy water down the drainage hole in back of fridge to ensure it is not blocked
3. Pull the plug. Leave it off for 5-10 mins.
4. Plug it in, reload her
5. Next morning.. perfect all back to normal
I think the unplugging just resets the thermostat and gets your machine back to life.
Jan 13, 2010 | Hoover Refrigerators
Tube that drains water from freezer is clogged with styrofoam from insulation. The drain tube cannot be removed so that it can be cleared. Water collects in fridge and it doesn't keep food cold.
you should open the evaparator and from the compressor compartment use a cable from the drainge pipe to reach the evaporator by doing this you can clear the inside of the drainage tube.
Sep 26, 2009 | Kenmore Refrigerators
My fridge is too cold
I wrote under "guest" earlier on Aug 5th. I jave since discovered that the problem is a manufacturer problem. Apparently Liebherr had problems with their sensors, which they have since corrected, but they were put in all the earlier fridge/biofresh. I contacted the Liebherr agent in Melbourne Australia where mine came from (Andi-Co), and they have sent someone out to replace the sensor free of charge (mine has been out of warranty since March 2008). The sensor tells the compressor when to shut off, and when faulty does not do this so the compressor keeps running and freezes everything. I did have to make a bit of a fuss though and write them a letter before they came out. I printed out this page as evidence that it was clearly a manufacturing problem, which they have now confirmed. So I suggest you ask your supplier to fix the problem free of charge. Good Luck!
Apr 30, 2008 | Liebherr K 4260 Refrigerator
Fridge
ok pull the cover off the back wall of the freezer compartment where the evaporator fan is after look under the evaporator should see an aluminum pan with a hole there that's the drain hole for the defrost system if its frozen and that hole is stopped up then every time it defrosts the water will run in the freezer and freeze and also drip into the fridge remove the ice and clear the hole also check the drain tube in the back to make sure its clean
Jan 18, 2008 | Refrigerators
Liebherr KELB 2840 Premium biofresh Refrigerator Logo
1,210 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
