Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
At high speed spin cycle sounds like a jet engine...
Cabrio WTW6600SW2
little over 1 1/2 old
could basket hud be bad?
  • Anonymous Mar 12, 2014
    very loud noise whenever the washer is in the spin mode. SOunds like a bearing is going bad.
  • Anonymous Mar 28, 2014
    whirlpool WTW6600SW2 will not spin. displayed 5d code. growling noise.
  • 240 Answers
If your thinking bearing, its part of tub assm not basket hub. $200 part
Posted on Mar 14, 2009
Cabrio washer wtw5500xw0 loud spin and grease on floor
FIXED Cabrio has loud noise during spin - ApplianceBlog
www.applianceblog.com/.../16339-Cabrio-has-loud-noise-during-spin
Aug 21, 2009 - 10 posts - ‎5 authors
Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
How to tell if your bearings are bad on a Whirlpool Cabrio ...
? 1:01
https://www.youtube.com/watch?v=5rHn13lKjzc
Jan 19, 2012 - Uploaded by RenewAppliance
http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
Jan 16, 2016 | Washing Machines
F54 code after repair
Okay F54 is a motor over current doubt if bearing was original problem this a rotor stator setup you should get a little resistance with the motor installed since the rotor has magnets, this code can drive you nuts there could be a crack in the rotor magnets are they rusty did the original seal leak,check the stator resistance on the control board ohm out the 3 wires on terminal P5 1 to 3, 2 to 3 you should get 31 ohms +/- 5 to get into diagnostic make sure machine is off use any button except power, start,stop, pause/cancel press and hold for 3 seconds, release for 3 seconds do this till 88 displays press the same button within 5 seconds of 88 should hear a beep you are now in manual diagnostic slowly rotate the basket the wash, rinse and spin light should flash as you rotate if all of the checks are good you have either a bad rotor or a bad control hopes this helps.
Jan 29, 2014 | Whirlpool Washing Machines
Need to know what the error codes mean on a whirlpool cabrio model wtw6400sw3 F54,F82,F83,F84. Please help.
you may have something between the tubs or your bearing is going bad . does it sound like a jet plane in spin cycle?
Feb 20, 2013 | Whirlpool Washing Machines
My whirlpool cabrio washer makes a loud noise when it spins
The bearing is probably going bad, spin it with your hand if it makes noise or you feel a vibration its bad Parts for Whirlpool WTW6600SW2 Motor Basket and Tub Parts
May 27, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I need the service manual for a Whirlpool Cabrio WTW6600SW2 to find out what the code F50 mean and how to replace RPS sensor.
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Jun 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio won't spin
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation. ➔ Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction
its SD not 5D
Sd is displayed when the machine/motor control, by analyzing drag on the basket, detects a suds-lock condition, and is steady on while the control then runs a mini-clean out cycle. If the clean out cycle is unable to correct the over-sudsing problem, the cycle ends and Sd flashes in the display. This may signify: ➔ Load is bunched or twisted around agitator. ➔ Excessive detergent usage. ➔ Basket cannot engage during drain step. ➔ Mechanical friction on drive mechanism, not allowing basket to engage.
Jul 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Sounds like a jet engine at full spin cycle
These things are notorious for sucking clothing under the the drum , it could cause it to be noisy spin slow and have drain problems . This is such a poor design . Try removing the drum and see if there is an article of clothing under it , mine sucked up a mans large shirt . Even if the drum seems to spin freely it still could be the problem .
Mar 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio washer keeps flashing code F50
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
Jan 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,442 people viewed this question
Dan Webster
Dan Webster
Sal De
