Royal Copier 1500DF--replaced toner and now have ''zebra stripes''
After replacing toner, all pages are covered completely with a multitude of narrow black stripes.
    Scholar:
  • 136 Answers
Ok I seen this problem so many times it's ridiculas
Ok when you get black strips chances are your blade on your drum work out of your fuser could be bad, if thier voids then thast a different problem, you need to call a tech if your in ct then i could help you with this problem yea b
ut you need to call a service tech tell him a Copystar rep/Royal Copystar Rep informed him to bring alade with him and maybe be prepared to rebuilt your fuser- CALL A SERVICE TECH- we could use the business.
Posted on Mar 08, 2009
HP color laserjet CP 1510 printing stripes on the left
Is this for all colors or just one color? There are three color toner cartridges plus a black cartridge.
Mar 09, 2015 | HP CC378A Color LaserJet CP1518ni...
Dark copies
First remove toner crg and check the drum, if its covered with stripes or toner, replace toner crg.
It also could be fixing film fault.
Nov 16, 2010 | Canon imageCLASS D320 Digital Copier
I have replaced the toner cartridge on a Xerox XC 830 copier with several new cartridges. I still get light images and horizontal dark and light stripes where it should be a solid dark block.Drum was...
Have you attempted to print to the copier? Doing this completely bypasses the optics of the copier and therefore you are able to potentially narrow down the cause of the banding.
On cleaning optics: on the right hand side of the machine, near the top, or on the top, of the scan bed there should be two to four screws that hold a plastic cover in place. After removing the cover you should be able to gently lift the glass up and out of its housing. Using windex or any other sort of glass cleaner on the reflective mirrors will do the trick. However, this does not sound like an optics problem.
Have you inspected either the transfer belt, roller, or transfer corona wires? All of these parts can be accessed from the right side of the machine. Gently clean the thin wires with a rag and some sort of general cleaner.
-David.
Oct 30, 2010 | Xerox 8830 Copier
A vertical black stripe is printing on the left side of the page.
Have you tried replacing the toner cartridgein the printer? If you print a page then remove the toner cartridge, carefully open up the cover that covers the the drum on the toner cartrdige.You can often see a line that corresponds to the line printed on the page.
Oct 13, 2009 | HP LaserJet 1022n Printer
Canon IR3300 dark print out
You refilled the toner. Don't recommend refilling the toner. If you're going to spend the money on a copier. You should get genuine toner.
I suggest you make a service call and use genuine toner in future.
Aug 17, 2009 | Canon NP 6050 Copier
GRAY STRIPES ON COPIES FROM CANON IMAGERUNNER 210S
Have you replaced the drum unit resently? When you had the drum unit out did you see the lines on the drum it self? If so, you need a new drum... If you did not see lines on it the problem may be coming from the fixing film, most of the time if the film is bad you can rub the toner off the page... Good Luck...
May 28, 2009 | Canon imageRUNNER 210S Copier
Random blobs of toner on printed pages
the fuser has burbt toner on it most likely you will need to replace it.
Mar 26, 2009 | Brother HL 5250DN Laser Printer
Narrow streak down page
Take a look at the drum on you copier by opening up the right door. Do you see a line on the green drum? If so, your drum should be replaced.
Sep 15, 2008 | Sharp AR-153E Copier
Lanier 6735 Copier
Sounds like you need a new cleaning blade. It is located inside the process assy behind the drum.
Aug 10, 2007 | Lanier 1205 Copier
65 people viewed this question
jasbo
jasbo
