Question about Garmin North America GPS Map Update Maps Software
Nuvi 200 downloaded 2008 City street for East USA update took 1.5 hrs. Attempted to install. After it went thru install I attempted to start my GPS up and said no maps found. What did I do wrong?
    Problem Solver:
  • 7 Answers
Did you unlock it? if not you need to.
Posted on May 19, 2009
Hi, I have a Nuvi 255 (205 series) gps, three years old. Last week the screen went blank, came back grey with 'crosshairs' and a black dot in the middle indicating 'press here'. I did so and the dot moved...
Graham - what your describing sounds like you somehow managed to erase the street level maps and POIs in your Nuvi.
If you connect the GPS to the computer with your USB cable, you should at the contents of the Nuvi directories and find a file called GMAPPROM.IMG or GMAPSUPP.IMG. These are the street level map files. Generally, these are found in the root directory of the Nuvi - or if yours has / and you use a memory card slot for maps - find it in the /GARMIN directory. GMAPPROM.IMG is the name of the first map set and GMAPSUPP.IMG is the name of the supplementary or second map set (if you purchased & installed one). You will likely have only one of these files - and may be named either. The size of this file depends on the area and age of the map. Current maps of the entire US run over 1 GB in size. If you do not have any maps named GMAPPROM or GMAPSUPP, you will not see any street level maps.
Something happened to delete the maps. Garmin will probably NOT provide free replacement maps for you, unless under warranty. If the devices is trashing maps and other files, you probably want to replace the unit under warranty or not. Garmin will, upon return of your old Nuvi - replace it with a factory refurbished unit with the latest maps installed, for $79. You can take advantage of this service by following this link to Garmin Service.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 23, 2011 | Garmin nuvi 205 GPS Receiver
My garmin nuvi 200 gives me a different street name before I can type in the correct one...
If the unit is suggesting a different street name, try re-entering the address. When you get to the city, hit, "Search All." Then enter the address as normal. It is possible the address is listed as being in a different city, due to the ZIP code. Let me know if this helps.
Mar 21, 2010 | Garmin nuvi 200W GPS Receiver
How do i up date the maps garman nuvi 200w/250w
The Garmin GPS are among the easiest to use and they have the most complete mapping on the market. To update the mapping, there are several versions of the software integrated into these road gps. To name a few, city navigator version 8 and City Navigator 2008. With a newer version, you have the most recently built streets, new shops, new parking lots, etc.. To update, there are several ways to proceed. First, before you update your maps, I recommend you check if there is a newer version of the maps, visit garmin and download the plugin. You can also view the maps version directly on your gps.
Nov 03, 2009 | Garmin nuvi 200W GPS Receiver
GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
I had the same issue..what a pain in the ****.
I came up with a solution that worked for me.
After the update i deleted gmapprom.img and then created my own map using the garmin MapInstall program. start>programs>garmin>mapinstall
Apr 11, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200 ...enter a Start and End destination!
Yes, you can enter in a specific address as follows:
Press "Where to"
Press "Address"
Select State
Spell City
Enter House Number
Enter Street
Press Save
Press Go
If your Nuvi has acquired a satellite lock, you will then be ready to go.
- Jim
Nov 29, 2008 | Garmin nuvi 200W GPS Receiver
GPS won't use the nthew maps I've downloaded.
I think the update is for the lower 48 states only NT 2009
Jul 16, 2008 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200 2009 Map Update
Here's what worked for me. Nuvi 200 brand new w/2008 trying to upgrade to 2009.
After registering and download the map 2009, I started the install. I go to a point where I was told I needed 37MB more room. I went thru windows explorer and looked in the Nuvi. I went into the language folder and moved all of the languages I didn't need to my hard drive. I then went into the HELP folder of the Nuvi and again removed the all of the languages I did not need. I then went back to the install program and hit retry. All good from there. I hope this helps.
Jul 03, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200w map update 2009
Delete all the vehicles and voices that you don't use as well.
Btw, beware that the "City Navigator Lower 49 States+PR NT 2010.10, Deluxe, Apr 09" for nuvi 200/205 is BUSTED, it probably will not work (I just spent 2+hrs on the phone with garmin tech support to fix it.) Search these forums for "nuvi 205 no detailed maps" for more details.
Jun 17, 2008 | GPS
Nuvi 660
Spell county? Never seen a county option on a GPS. Usually its zip or city, street, street number.
Apr 28, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin North America GPS Map Update  Maps Software Logo
236 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
