I try to install Panda AdminSecure in to my Server 2003 and I start it but went the program begin to install get this massege.
Error 1406. Could not write value First Time to key
\software\Panda Software\PSAlertas. Verify that you
have sufficient access to that key.
What may be the problem.?
I will apreciate any help you can give me.
There is probably some remnant of panda on the system, perhaps in the registry. Also might be a service. Go in regedit to
hklm/system/currrent control set/services. Look for any service that starts with pav and delete. Be sure that it is panda by selecting it and look over on right side and make sure you see something over there that refers to 'panda'. Delete those references. Still under services, look for shlddrv. Delete if there. Reboot and rerun admin secure setup. If it still fails then we will have to look at a log file which is called log3inst located in the temp folder in the user profile. Go to start->run and enter %temp%. Log3inst is there and we would need to see that.
