Question about Emerson Insinkerator 2.5 Gallon Water Heater - W152
THE INSTA HEATER KEEPS TRIPPING THE BREAKER? - Emerson Insinkerator 2.5 Gallon Water Heater - W152
  • 659 Answers
Is this a new install or is this something that has just come up? If it is a new install, the amperage on the breaker is too low. You will have to call an electrician to come in and check to see if the romex wire is large enough to handle a higher amp breaker. If not, it could be that the breaker has become weak and tripps prematurely. If it's not the breaker its self then the heating element is bad on the unit.
Posted on Mar 19, 2009
2 Suggested Answers
  • 408 Answers
SOURCE: THE INSTA HOT HEATER KEEPS TRIPPING THE BREAKER?
Hire an electrician.  The breaker needs to be replaced or the wiring in your house is not able to handle it.  I believe most need 2-30amp breakers.
Posted on Mar 04, 2009
My Rinnai tankless water heater keeps tripping the breaker then when turned back on, it begins to beep and displays a code 12. What is causing this? It is new and this is the first time any code came.
Go to Rinnai and get a manual with the error codes... for example a shorted element will trip breaker... wiring problems can cause breaker to trip... anything that causes heat on wire to exceed amp rating of breaker will cause it to trip...
http://waterheatertimer.org/Water-heater-is-tripping-breaker.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 12, 2017 | Rinnai Water Heaters
Keeps tripping the breaker
Breaker keeps tripping means short in wire or heat element
Shut power off . use ohm meter and go from ground to each wire on elements and if you get continuity. there is short pull wire off element check wires to ground not continuity bad element.
still shorted follow all wires may have bare wire shorted against cabinet Or by new heater
Jul 02, 2015 | Water Heaters
Water heater tripping the breaker
Copy following link for troubleshoot walk-thru for electric water heater tripping breaker:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Aug 11, 2012 | Rheem Water Heaters
Titan SCR4 tankless water heater. Breaker on water heater itself keeps kicking. Not in breaker box. I have 2 double breakers, 50 amps each in box, no problem there. On the water heater there are 2...
Breaker trips when heat on wire exceeds amp rating, or when breaker is bad.
Most breaker are slow acting, and do not trip immediately.
Shorted elect could cause problem.
Oct 15, 2017 | Water Heaters
Keeps tripping the breaker. i have replaced the e...
It may be a weak breaker. If you have replaced all the components on the water heater. I would suggest calling an electrician to check out the breaker.
May 17, 2010 | Water Heaters
My ariston electric hot water heater keeps tripping off
Tripping off at the water heater or at the breaker box?
Jan 24, 2010 | Bosch GL4Ti Ariston Pro Ti Electric...
Rheem 50 gal keeps tripping breaker. What is the problem?
Do not touch water heater that is tripping breaker.
Open following link for troubleshooting steps:
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 05, 2009 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Mar 03, 2009 | Emerson Insinkerator 2.5 Gallon Water...
Emerson Insinkerator 2.5 Gallon Water Heater - W152 Logo
277 people viewed this question
Top Emerson Water Heaters Experts
Gil Shultz
ray gallant
Are you an Emerson Water Heater Expert? Answer questions, earn points and help others
