Question about GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker model JVM1660SHC01. It starts ok but after 2 seconds it's sound changed and tripped the circuit breaker. I 've restarted it several times, but it's futile. What can I do make this thing work?
  • GE Master
  • 9,086 Answers
I would suspect a shorted high voltage capacitor or high voltage transformer, but normally the internal fuse blows before the breaker does, unless the breaker is rated less than the interval 15A or 20A fuse.
You might also check the door switches & door switch mounts.
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I have a GE Spacemaker model JVM1660SHC01. It - d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/cap_test.html
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Mar 06, 2009
Breaker trips when using microwave. Electrician can't find electrical problem. Could it be the microwave itself?
Answered earlier, another tips is to disconnect the power to the board and see if the circuit breaker holds, if not check the main line circuit.
Jan 31, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
G.E. Spacemaker trips the breaker on the circuit it is pluged into if you open the door when it is running.
Check the door switches and the wires connected to them. I've seen at least one door switch that had bad contacts literally fall apart due to overheating. It's possible you have one that is broken and twists over to touch a grounded metal part when you open the door (also inspect the bracket that holds the switch for the same issue). The same switch doesn't trip the breaker when the oven is not running because there is no power going through it at that case.
Nov 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
Ge spacemaker microwave, new, keeps tripping the GFI but keeps running
The first thing you need to check is the GFI--when it trips, it definitely should shut off power to the circuit. It may be wired incorrectly, or is faulty. There should be a 20 amp breaker and wiring to the oven.It is also much better is the oven is the only appliance on this circuit. Hope this helps!
May 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JNM1541 GE Space Maker
If it's less than one year old, it should be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free or better still, if you've had it less than 30 days, I'd have the dealer replace it.
GE Customer Service is here.
It sounds like the door or door switch mounts are misaligned. It may have been damaged in shipping.
Jan 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Circuit breaker continually trips immediately when used
check for a shorted hi voltage capacieor ,transistor or shorted multiplier diode
Nov 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Model JVM 1650sho1
is there a fix for this problem mine does the same thing, i changed the powerstrip and it worked fine for a month, now it's doing it again runs for too minues or so then it trips the circuit breaker in the power strip
Aug 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
2 year old ge profile spacemaker Microwave lost all power
Inside unit is a cylinder fuse which can blow for a number of reasons. External cover needs to be removed to access. If you are confident in doing this and can find & check the fuse then it would be my first guess. If fuse is OK then you will need to have repaired. If fuse isblown & you replace then it blows again,you will need to have repaired. regards
Jul 25, 2007 | GE JVM2070 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
288 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
