Question about Canon Office Equipment & Supplies
I have a CANON MP780 all in one, I have just renewed all the ink absorbers but I still get the message"ink absorbers full" and a flashing lamp,it will not do anything else. How do I correct this ?
  • gerry536 Mar 03, 2009
    It did not work,I still get a flashing light and an error message "343"
  • gerry536 Mar 04, 2009
    Yes,it worked,thank you.
  • Canon Master
  • 19,396 Answers
Nice to know that you have fixed your problem, let us know if you need further help.
Thanks.
Posted on Mar 04, 2009
    Genius:
  • 1,550 Answers
Error code 343 means - "Ink Detection Waste Ink Tank Full"
You need to replace the ink pad and reset the eeprom counter to 0 .
To reset counter
PRESS
ADITIONAL FUNCTIONS
SCAN
COPY
SCAN
scroll to TESTMODE
scroll to PRINTER TEST
scroll to EEPROM CLEAR
and the press the numeric key 3 or and keys.
Select INK COUNT, and then press the
numeric key 0 or and keys to reset the waste ink capacity.
Press the [Stop/Reset] key and then the
[ON/OFF] key to end the test mode.
Hope this helps .
Source :fixyourownprinter.com
Posted on Mar 03, 2009
    Sergeant:
    Champion:
  • 315 Answers
Try this procedure:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s) according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.) [hth: I believe the power button has to be pressed once more after cycling the alarm button to complete the action. The power/resume-cancel button LEDs toggle to help you count.]
  • Roger Gantner Mar 03, 2009
    4 times Green (Power) Waste ink counter resetting
  • 916 Answers
Unplug the cords from the back of the machine wait 15 minutes then plug them back in. Once done Press the <Stop/Reset> button to cancel after the printer starts up. Also use any cleaning utilities on your computer that came with the printer and print a test page.
  • Canon Master
  • 13,433 Answers
The waste ink counter needs to be reset.
  • Ekse Mar 03, 2009
    int:
    - To select something... Use the '-' and '+' buttons and then the "OK" button.
    - To go back... Use the "Stop/Reset" button
    - To reset... Use the "On/Off" button (only after you've gone back as far as possible it seems)
    1. Service menu: Menu -> Scan -> Copy -> Scan (one at a time in sequence)
    2. Select "TEST MODE"
    3. Select "[8] ETC.."
    4. Select "[4] EEPROM CLEAR"
    5. Select "[1] INK COUNT"
    6. Press the [OK] button.
    7. Press the [Stop/Reset] button (returns you to the TEST MOD sub-menu))
    8. press the [ON/OFF] button (which resets the printer)
    TIP: Don't rush the printer as
    it can often take considerable time to respond to your commands.
    Frantic button pressing will just push the printer into snail mode (ie:
    slow as hell!).
Displaying error message: waste ink well almost full. What does this mean, & how do I fix it? Dave
Unfortunately you will need to take this type of printer into a Canon certified repair center. You have a total of 8 pads inside the printer located on the bottom of the printer and the only way to replace them and reset the waste ink counter is to take it in.
This is where you will want to debate the cost of repairing it or just buying a new printer. Depending on where you take it and how much they charge you for it will vary quite a bit. The company I work for does these but we charge roughly $89 an hour plus parts which alot of places dont keep in stock. So your looking at around a week for the absorber kit to be mailed out.
If your still able to print and its not saying that the ink absorber is full you can contact the nearest Canon repair center and have them pre order the absorber pads and when they come in you can just bring your printer in and they can change them out. It should not take them more then an hour to do this.
Here is the part numbers for each pad:
QC1-4264-000 ABSORBER, INK
QC1-4224-000 ABSORBER, INK
QC1-4223-000 ABSORBER, INK
QC1-4263-000 ABSORBER, INK
QC1-4257-000 ABSORBER, INK
QC1-4222-000 ABSORBER, INK
QC1-4864-000 ABSORBER, INK
QC1-4221-000 ABSORBER, INK
Best of luck!
Jun 30, 2010 | Canon PIXMA MP780 All-In-One InkJet...
My Canon pixma MP780 is flashing a message that the waste ink is full. What does this mean and how can I fix it?
Have to reset the waste ink counter & replace with new WASTE INK ABSORBER KIT. Only service centre can do the service job.
May 20, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Where is the waste ink tank?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
Waste Ink near full shows on screen. Won't print!
Hi ...
Cannon Pixma MP780 have an absorber and this error is related to this absorber.
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <Stop/Reset> button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset.
I would suggest that you take your printer to the nearest cannon service centre and get it repaired.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My Canon Pixma MP780 is saying "waste ink absorber is near full"
Under the place where the inks park is a tray full of asorbent pads. It was the most awful thing to get to in my Pixma ip 2000. If you have a day to spare, and a work table, and some long needle nose pliers or maybe hemostats, and the usual tools, you can take the machine apart to get at it. Note which pads (and parts) go where, everything has to go back where it came from. The pads will rinse out with water, lots of it.
Apr 29, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Wast ink
Your MP780 printer has decided you have too much ink from the cleaning cycles in the absorbent pad inside the printer. Go to www.fixyour ownprinter.com and put "MP780 waste ink" into the search function. Follow the leads to find out how to clean the waste ink out and more important to find the code to reset the printer to get rid of the waste ink message.
Apr 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon mp780 -waste ink near full??
Dear mr perfect,
Few days ago I have answered the same question about this for Canon MP700. Here is my answer:
Waste ink absorber capacity of your printer has rise to about 90-95 %. Tentatively, you can continue printing by pressing STOP/RESET button. When ink absorber capacity reach about 100%, the printer stop working and message 'Waste Ink Tank is Full' appears.
To fix this problem, you need to reset waste ink counter. It strongly recommended that you replace waste ink absorber after resetting waste ink counter.
Here are steps resetting waste ink counter of this printer:
  • With the machine power off, while pressing STOP/RESET button, press and hold the ON/OFF button. (Do not release the buttons).
  • While holding ON/OFF button, release the STOP/RESET button. (Do not release the ON/OFF button).
  • While holding the ON/OFF button, press the STOP/RESET 2 times and then release all buttons. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • When the COPY button lights in green, press STOP/RESET button 4 times. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • Turn off the printer.
Your printer should work normally now.
Regards,
Source:
Canon IJ Forum
Dec 06, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Thanks!
Hi there, valleylee. I am not sure if you got this information, so I wanted to check...
The link is at the below location, but you will have to type in "waste ink" (without quotes). Since Canon links brings up generic pages, I have reproduced their instructions for you below the link. If you choose to take on this procedure yourself (which is against their advice), they will not provide the procedure.
I would also suggest that you see if it makes sense to you that it would be full and require replacement; in other words, have you had substantial use yet? If not, on that same page, you will see an indication that the printer may need repair as well.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10444
---------------------from Canon-----------------------------
Issue: ERROR LCD: WASTE INK NEAR FULL
Solution: Ink absorber replacement options - MP780
Ink Absorber Replacement Options This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <Stop/Reset> button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
If you feel your product might require service, Canon has excellent service options, and we are eager to provide any assistance you may need. Click the link below to locate an authorized service facility and obtain further instructions.
Find a Service Location
If you still have questions about the issue you are experiencing, a Technical Support Representative will be happy to answer any question you may have. You can contact us through the email link or phone numbers listed below.
  • Obtain Support by Email
  • For toll-free technical support*, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidays).
    * There will be a pay for support charge if your product is out of warranty (see next section, below).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
  • Technical Support is available for Customers in Canada at 1-800-OK-CANON
If your printer is no longer under warranty :
  • For technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidays). Pay for support is required on all units outside their original warranty, unless covered by a Canon Extended Service Plan. The charge will be $9.99. If it is determined that the problem you are experiencing is due to a failure of the printer's hardware, the pay for support charge will be canceled. If your out of warranty printer is determined to have a hardware problem, you have the option to purchase, at discounted pricing and free next business day shipping , a new or refurbished product from our current product line, which includes units with Canon?s new ChromaLife inks, PIXMA Technology, and a limited manufacturer?s warranty.
So we may better assist you, please make sure that you can access your Canon product and have the following information available when you call:
  • Product model name and serial number.
  • Computer's operating system; for example Windows XP.
  • Message displayed when the problem occurred.
  • Steps you've already taken to try to solve the problem.
We look forward to helping you rectify the issue you are experiencing and are always available to provide any assistance you may need.
Please post back if you need further help, otherwise thank you for rating FixYa!
May 15, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Please help!
You will have to have these replaced by Canon because it is a difficult and messy job.
Nov 07, 2007 | Canon PIXMA MP780 All-In-One InkJet...
24 people viewed this question
old marine
old marine
