Question about LG GL6000ER Air Conditioner
MY AIRCON OUTDOOR MODE IS ON...AND ITS NOT COOLING
  • LG Master
  • 3,361 Answers
Apparently the outdoor fan is on.
Verify that the compressor is on.
Could be a bad capacitor or a bad compressor or justb a bad wire.
Check the refrigerant charge.
Low refrigerant= no cooling.
If the compressor is running refrigerant pressure on the low side (suction side)should be at least 68 pounds of pressure.
Posted on Mar 03, 2009
New aircon but doesnt seem to be cooling
Hi Donna,
Check outdoor unit is running - the larger pipe/fitting of the two should be cool to touch after about 20 minutes, and the small one should be hot - if not either the system is short of refrigerant or the compressor is not running.
Check to make sure the settings are correct - snowflake for cooling - not for wintertime
Good luck
Dec 31, 2015 | Heating & Cooling
How can we make our Airtech Elite portable aircon's wind cooler? It's cool, but not cold!!
the temperature should be close to 20 degrees difference between the return and supply air of the aircon. Proper maintenance includes free airflow on the outdoor unit, hose the radiator down with water, clean it.
Oct 09, 2015 | Heating & Cooling
Hi, I have an LG artcool A09AHD aircon unit and after a while on the heat cycle, the unit stops and shows a circle with a snowflake and a waterdrop within the circle. Does anybody know what alarm tjis is?...
This may just be the defrost cycle for the outdoor unit. In the heat mode, the outdoor unit builds frost on the coil. The outdoor unit senses how much frost has built up on the coil and reverses the refrigerant cycle to allow the outdoor coil to warm up and defrost it. After a short period, the unit then restores itself to the heat cycle. This is normal operation and nothing to worry about. During the defrost cycle, you may feel some cool air inside your home.
Oct 26, 2013 | LG Heating & Cooling
Yapmagic split unit aircon
if the indoor unit is throwing air but no cooling then check if outdoor is throwing hot air or not. May be the refrigerant has leaked. call a technician.
Jun 20, 2013 | Heating & Cooling
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
My air conditioner is only 3 months old and the tempperature never goes down to cool the house. I set the temperature and it goes right back to 90
There are a few answers to this problem. Firstly you should make sure that the ac unit is correctly sized for the heat load. In my part of the world this is calculated at around 650BTU (British Thermal Units) per square meter. The second solution could be as simple as being sure that the unit is actually set to cooling mode. If this is all correct, then it is also possible that the aircon is short of refrigerant. You can check this by feeling the thicker of the two copper tubes at the outdoor unit, it should be cool. If it is cool, then you should have someone check the thermostat. Hope that this information helps you in some way.
Aug 20, 2009 | Heating & Cooling
Airconditioner LG LSk181-N2 shutting off
Sounds like your aircon is stuck on heating mode. Or. The outdoor fan speed is affected by ambient temperature, or low refrigerant. In heating mode the indoor fan will come on for a while to sense temperature and will then wait for the outdoor unit to pump up pressure and build up heat.
Feb 01, 2009 | LG LS-K1830CL Cool Mini Split Air...
Heating Problem
put it in heat mode and check the pipes to outdoor unit,if the pipes are white from ice then the problem is to outdoor unit and is the coil of 4valve.its like a cube with 2 cables,change it.
Aug 15, 2008 | Samsung AS18A6RB Air Conditioner
LG GL6000ER Air Conditioner Logo
208 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
