Question about Sony ICD-B200 Digital Voice Recorder
My SONY IC -B600 is stuck in the hold position. I removed the battery and put it back in. The problem persists.
SOURCE: Sony IC Recorder ICD B600
To transfer recordings from the Sony ICD-B600 to Windows first buy a Radio Shack #42-2497 cable. Connect the cable from the recorder headphone jack to the computer microphone jack. In Windows XP follow the path: start, All Programs, Accessories, Entertainment, Sound Recorder. This small window will allow you to record 60 seconds of sound to a file. Get Article #82215 from the Microsoft web site. It will tell you how to make extended recordings. I was able to record 45 minutes continuously. The recorder is turned on by moving the 'HOLD' switch down. The recorder is turned off by moving the 'HOLD' switch up and waiting 2.5 seconds. Have fun.
Posted on Oct 27, 2008
welcomejee
  • 10594 Answers
SOURCE: Need basic operating instruction
Download user manual of ICD-B600 from Sony Support.
Posted on Dec 09, 2008
  • 102366 Answers
SOURCE: i lost my instruction manual for sony ic recorder
Here's the manual: http://esupport.sony.com/US/perl/model-documents.pl?mdl=ICDB600&LOC=3
Posted on Feb 16, 2010
tunde007
  • 2382 Answers
SOURCE: How do I recover deleted
Hi, am sorry you cannot retrieve any deleted recording on it because the unit has an in-built flash memory and once you delete on it, you cannot retrieve again.....
Posted on Mar 28, 2011
  • 102366 Answers
SOURCE: I just need the manual
You can download the manual from the manufacturer's web site at
I can't email it to you since you didn't publish an email address.
Posted on Aug 05, 2011
My Sony DSC-S60 camera lens in stuck open and my camera is stuck on access. It tells me turn off camera then back on. I have done that several times with no luck
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Sep 10, 2011 | Sony Cyber-Shot DSC-S60 Digital Camera
I just need the manual for the ICD-B600 Sony IC Recorder. Could you just e-mail me a copy?
Jul 26, 2011 | Sony ICDB600 Digital Voice Recorder
Sony cybershot DSC T90 got wet in rucksack one day when we went out walking. Now it won't turn on. Is this fixable?
Please try to power reset the camera and try. To reset, please remove the battery and press n hold the power button to on position for 1 minute. Then, release the button and insert the battery. If the issue persists, please contact service center.
www.eservice.sony.com
Oct 18, 2009 | Sony Cameras
Sony cyber camera
The Camera is displaying the Turn the power Off and On again message when the Lens in the Camera is stuck or when any internal malfunction happened.
To resolve the issue turn the power off and on several times. If the issue persists, try power resetting the Camera. To power reset the Camera, remove the battery from the Camera.
Press and hold the power button on the Camera for 30 seconds.
Remain the camera without power for 60 seconds and re-insert the battery.
Also try resetting the Camera back to factory default. Press the RESET button located at the lower right corner of the control buttons using a sharp pointed object.
Good Luck
Thanks for using FixYa
Nov 19, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Jul 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
May 08, 2008 | Sony ICD-B200 Digital Voice Recorder
Digital voice recorder completely 'locked-up'
Any time an electronic device lockup there is two main reasons. The first is a data error. A data error happens when incorrect digital information enter certain IC chips, and cause the chip to lock up. This is sometimes called system busy. Similar to when a computer freezes up due to corrupt software or a computer virus. To fix you remove all power to the IC chips. Removing the batteries is not enough, due to the fact that circuit boards have components on them that hold voltage. Additional batteries, coils, capacitors. You have to remove the covers and take the main digital board out. Check to make sure there is no other battery on the board. Some boards have an additional battery source for storing date and time and other info. remove that battery. Either short all capacitors and coils. or let them dissipate, sit for a day of two . Install board back in machine this should clear any system busy type problems. If the problem remains, the digital IC chip or chips are bad and have to be replaced. So boards may have a way of reset the circuits. A technical manual or a call to tech support is required.
May 04, 2007 | Sony ICD-B200 Digital Voice Recorder
71 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
