Question about Canon imageRUNNER 400S Copier
I CANNOT GO TO *28*PROGRAMME MODE
In my machine *28* programme mode is not working what is the solution for it
    Sergeant:
  • 199 Answers
Are you confirm that star and 2,8 key is working, then can you press 28 same time or in serial.(for the process press star then press 2 & 8 same time then press star)
Posted on Mar 04, 2009
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
Tip
How to make older programmes run on xp.
Find the launch file that you want to run. its normally the main executable programme or shortcut.
right click the icon and select the properties.
click on the compatibility tab and place a check next to the text labeled "run this programm in compatitbility mode,"
select the operating system that the program was designed for.
you may need to adjust the display settings also for this program.
click apply
then restart the programme see how it goes.
if the programme does not work try differnt compatibility modes.
on Dec 01, 2009 | Computers & Internet
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
Candy Futura CDF 325 beeping alarm
Is there a sequence to the beeps?
Jun 04, 2013 | Candy Dishwashers
'washing machine miele w1714 lock on Message demo programme how i do unlock?
Demonstration Mode (Dealer Displays)
Initial requirements
- Switch off the machine.
- Close the door.
Note
Once you begin the access procedure, it must be completed within
10 seconds.
Accessing
1. Press and hold the Start Button while switching the unit on with
the On/Off Button.
2. As soon as the Start LED lights up, release the Start Button.
3. Immediately press and hold the Start Button, until the Start
LED turns off.
Deactivation
Repeat the accessing procedure.
Note
The Demonstration Mode is NOT deactivated when the power is
shut off with the On/Off Button, or by unplugging the appliance.
Nov 04, 2012 | Washing Machines
Casio se-s300. Pressing the cash button no longer works in register mode, it just beeps!
Firstly, try this:
turn key to program mode.
0
CASH
SUBTOTAL
SUBTOTAL
0
CASH
SUBTOTAL
turn back to REG mode and try it.
Oct 23, 2012 | Casio Parts Cash Register PC Desktop
Plug in byron sx83 stops working,when you take it out the socket then replace it works for a short whill then stops again
I have a different problem with the same model.
Firstly, I think the reason yours stops working is because when you first plug-in / switch-on the power, for the first 10-seconds, the bell is in 'programme' mode. Press the button to connect with the bell and it is then programmed. Sorted. However, if you unplug, have a power-cut, etc. then the button is no longer connected to the bell and needs to be programmed again.
FYI - when in programme mode almost any remote (which is what the button is) can be programmed to ring the bell (e.g. television remote)... so ensure you don't press any other buttons within the 10-seconds 'programme' mode!
My problem is, even after I programme my button to connect, it stops working after a short while. Please let me know if this is happening with yours and if you ahve any solutions.
Thanks,
Jason
Jul 05, 2012 | Cars & Trucks
Need to set time on 1500e lathem
Hello
To enter the programme setting mode, you should plug the AC adapter to AC outlet and remove the cover. Thereafter press 'Select' button once. The the clock goes into the programme mode showing "UP Arrow" on the display positioned at "Time"
Function of three control buttons.
'SELECT": You can select the desired programme setting modes by pressing "Select" buton. Selected programme setting mode is indicated by the "upward arrow" mark on the display.
"CHANGE": When you press "Change" button, you can increment the set value.
"SET": You can set the value selected on the display by pressing the "Set" button. Thereafter you press this 'Set" button again, you can return the clock to normal operation mode. OK.
Dec 14, 2011 | Audio Players & Recorders
I have managed to change my mode button to menu, and now i cant get it back to the mode button because i cant get into mode and reprogram that particular button, please help!!1
Mode button is very important to change the mode.If you have delete it by mistake then you have to use Casio software- cv-10, cv11 or cv33 to download all the programme and initialize qt-6000 with initialization method and reload individual programmes which you need and don't load function keys through your saved programme. Then configure the function keys manually in programm-4
Apr 29, 2010 | Casio QT 6000 Point of Sale Terminal
I PURCHASED LEGO ISLAND AND TRIED TO INSTALL IT ON MY COMPUTER WHICH HAS VISTA AND IT IS NOT WORKING. I ALSO CAN'T UNINSTALL WHAT DID GO ON.
what you need to do is run the programme in compatability mode for XP service pack 2, you can do this by right clicking on the desktop icon and choose the compatibility tab, if the game still won't work you may have to start the machine in safe mode (press F8 on boot up) to remove the programme
good luck
Nov 16, 2008 | Computers & Internet
Canon imageRUNNER 400S Copier Logo
73 people viewed this question
old marine
old marine
