Question about Saws
Hi, I can't get the lock to open on the saw. Can you help. Cheers.
  • nathan May 11, 2010
    which saw, what make, what lock?
  • Jim London
    Jim London May 11, 2010
    Hi, I need to know how it got that way. Was the spindle lock pushed and you were trying to get a blade off or on or was it pushed by accident when there was power to the saw?
  • 90 Answers
TIP TAKE A SCREW DRIVER AND LOCK THE BLADE ON THE CURVE OF THE BLADE NOT THE TEETH THEN TAKE THE WRENCH AND A PIPE TO FIT OVER IT AND LOOSEN.
Posted on Aug 04, 2009
Ridged wet saw beast how to raise blade
Hi John, The link below is a web page about ridged wet saw beast, J Hope this helps.....CHEERS..
Ridged wet saw beast Google Search
Apr 05, 2016 | Saws
Plz help open lock
Hi if you've locked your phone through entering an incorrect pin number 3 times then you need a Puk code, Ring your service provider and they will give you the FREE Puk code.....
If you lock your phone again some time in the future and you're still with the same service provider you can use that same Puk code.. CHEERS..
Mar 25, 2016 | Cell Phones
Craftsman 10" radial arm saw motor spins up fine with no blade when I put a blade on it starts turning slowly then pops overheat switch capacitor checked out fine is it the bearings?
Hi Joe Linda:
Great saws! Have one myself that is over 40 years old and still works fine.
What can sometimes happen is that dust will build up inside the motor and can foul the brushes/armature.
If you have an air compressor available, put on some safety glasses, grab the air nozzle, UNPLUG THE SAW, and blast away at every opening you can find. When the dust and spiders stop coming out, plug it in and give it a try.
The other problem I had with mine was that the ON/OFF switch contacts eventually fried and the switch is no longer available.
Solution was to bypass switch and wire switch into separate plug circuit fopr the saw.
Hope this is of some help.
Cheers.
Oct 09, 2015 | Craftsman Saws
Need a pushbutton off/on switch for toyang tile saw motor
Hi, you can purchase push buttons on amazon, click here and take a look: Amazon com Tile Saw switc. I hope this was helpful. Cheers
Aug 15, 2012 | Delta Saws
Owners manual for a 40-150 Delta scroll saw
Hi, I found something on amazon, take a look here: Amazon com Delta scroll saw manual. I hope this was helpful. cheers
Dec 17, 2010 | Delta 40 680 Electric Scroll Saws
Need parts for husky tile saw THD750l need bolt fence
Hi, Take a look at amazon for replacement parts: Amazon com Husky tile saw. Hope this was helpful. cheers
Sep 30, 2010 | Husky Wet Tile/Stone Saw with with Laser...
Can't get the handle of a mastercraft compound mitre saw to open
Hi, If you look on the left side of the saw near where you see that it pivots to go up and down. You will see some type of knob that you can pull out...you will need to push down on the saw handle to allow this to happen.
Hope this helps, RSMITH972278 P.S. PLEASE RATE MY ASSISTANCE
Dec 29, 2009 | Saws
Hi please can you help with my central locking system BMW318iSE saloon. It used to work fine but recently it fails to open but will close with the key. Using it manually the key will not also open all...
hi i have had the same problem, the things is your key has lost its coding to your car, is it the diamond shpe key with a open, lock and open boot on it if it is you can get in your car turn the ignition to the point before the engine starts,
take the key back out,
hold the unlock button,
whilst holding the unlock button press the lock button three times,
let go off all buttons then the locks should bounce to say the car key has recoded its self,
hope this helps cheers
Oct 07, 2009 | 1999 BMW 318 ti
Washer will not start cycle
and hi again,
Saw the review and the rating. Appreciate the kind words and glad to be of assistance.
Cheers.
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Bicycle Lock Problem
In order to break it you need a powerful tool you need to get something called a 'metal cutoff blade'. It will go straight through the lock, no problem. You can use it in a hand-held saw or a table saw.
To find a master key or open the lock you can also call a locksmith.
Good luck
Oct 29, 2008 | Master Lock Bicycle Lock
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
