Question about Canon MVX200 Mini DV Digital Camcorder
Unable to load a cassette.
When i try to close the cassette compartment without a tape inserted, the mechanism drops down and immediately rises. If i try to do this with a cassette in, the mechanism will not drop at all. THis means that i can not use the cam corder at all. Is there some psrt of the loading mechanism interlocked with the cover that may have become damaged?
Have not tried taking it to a shop or sending it off yet.
Hope someone can help.
SOURCE: Will Not Load Cassette
I have the zr850 which I have used less than a dozen times, and it does the same thing as you describe. Was told by canon tech people to try a maxell brand tape and a head cleaner tape. Have not tried their sugestion yet. camera is 3 months old.
Posted on Aug 04, 2007
  • 1894 Answers
SOURCE: Cassette Compartment on my Canon MV800i will not close to play tape
Posted on Mar 08, 2008
SOURCE: Canon MV800i tape would not eject.
Put pedalfoot in camera, shake vigorously.
Posted on May 13, 2008
this is the link to the solution
Posted on Aug 27, 2008
SOURCE: Put tape in cassette compartment push it closed -
I am having this same problem and I did a test. There appears to be some type of light sensor that fits in the tape when you try to close it. When there is no tape the loading mechanisim will work. If you put in a tape it covers the sensor and will reject the tape. I used a clear straw and covered the sensor and it closed. I then blocked the ligh from coming in the straw and covered the sensor and it ejected the same as having the tape in. Does anyone know where I get get this part?
Posted on Feb 06, 2010
Canon camrecorder will not load cassettes take
Believe it or not, but I found a possible solution for that in another forum. The suggestion was, to let the camera drop from about 0,5 m height onto the floor. Make sure, that there is a carpet underneath, which prevents the camera from severe damage.
This is no joke - I have let it drop once and the cassette was loaded and everything worked fine. There might have been a sensor problem or a little hickup in the mechanic.
Try it on your own risk - but what do you have to loose ? I wanted to sell the camera as broken on ebay, but now, I have a running camera again.
May 15, 2010 | Canon MV800i Mini DV Digital Camcorder
Canon ZR500 won't close cassette bay
If your camcorder experiences an error, you may be presented with a ?Remove the Cassette? message. There are several reasons that this message may appear, but it is essentially a safety warning that is designed to protect the camcorder and/or tape from damage. The camcorder?s tape drive mechanism is made up of many precision components that, once damaged, may cause further problems if the mechanism continues to operate. When a problem is detected the safety mechanism is activated. The ?Remove the Cassette? warning and the camcorder?s safety mode may be activated by a variety of conditions such as: 1. Condensation is detected ? If condensation is detected by the camcorder, the ?Remove the Cassette? warning may occur. 2. Component failure ? If an electrical or mechanical component in the camcorder fails, the safety mode may activate to prevent any further damage to the camcorder. 3. Sand or grit damage ? The camcorder?s tape drive mechanism consists of many tiny gears. Sand or grit can cause a gear to jam and stop turning. This will cause the camcorder's safety mode to activate. 4. Impact damage ? If a camcorder is accidentally dropped or bumped against a hard surface, it is possible that a misalignment of the tape drive mechanism may occur. 5. Liquid damage ? If either the camcorder or the tape is exposed to water or any other liquid, a variety of malfunctions may result. Please avoid this situation. 6. Improper videotape insertion ? If a tape is forced into the cassette compartment, or if the cassette compartment is pressed down while the tape is loading, damage may occur to the tape drive mechanism. Please refer to the User's Manual. 7. Damaged or defective tape ? If a tape becomes damaged, please discontinue its use. Operational Recovery Steps Depending on the conditions that caused this message to appear, it is possible that the camcorder operation may recover. Please follow these steps: 1. Eject the videotape Insert a new or known good videotape. If the message does not persist, it is possible that the tape was damaged. If the camcorder still displays the message with a new tape, please proceed to step 2. 2. If condensation had been detected causing the Remove the Cassette warning, remove the cassette, and allow at least one hour for the moisture to dry. If the "Remove the Cassette" message continues, the camcorder may require service. Please contact Canon USA's Tech Support Center at 1 (800) 828-4040. Technical support hours are Monday through Friday, 8:00am - 12:00 midnight; and Saturday 10:00am - 8:00pm (all times EST). Alternatively, if electronic support is preferred, please send your email to
Aug 27, 2007 | Canon ZR500 Mini DV Digital Camcorder
My sony trv37 cassette door won't close.
If this condition only occurs with as cassette inserted to load this may indicate a condition where the cylinder which holds the video heads is not spinning up when requested by the system control microprocessor.
If the door will not latch closed with/or without a cassette inserted this can indicated a mis-timed condition of the tape loading mechanism.
Try closing the door without a cassette loaded whilst the unit is powered from its AC Adaptor - under certain conditions this may allow the mechanism to reset and may allow the door to then close.
I trust that this information is of assistance! RHN
Jan 02, 2010 | Sony Handycam CCD-TRV37 Camcorder
The tape carrage wont load the tapes but it will go into the load position without.
I have a sony cam myself. If the cam is empty, you open the outer door(swings out), and the load/unload mechanism rises up and pops open allowing tape insertion. When a cassette is placed into the mechanism, you press where it says "push" and then the drive pulls the tape down and into the unit. Then the outer door is closed and you're ready to tape. IF YOU PUSH DOWN ON THE TAPE WHILE IT'S BEING PULLED INTO THE UNIT IT WILL STRIP GEARS INSIDE. The gears are made of nylon to prevent serious damage to motors and other circuitry. This transport setup cannot be forced at all. If any type of mis-alignment occurs, the mechanism is supposed to stop and back up--allowing the problem to be corrected. If it is damaged, the cam must be repaired. There is critical timing involved in replacing the tape carriage.---Rick
Sep 10, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
Wont load tape
HI, this is a mechanism fault beep you are hearing. the mechanism and load motor is damaged. you will need to send this unit to the Handy cam repair depot for this repair. you will need a new load motor and loading dock mechanism as well.
Jun 03, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Dec 10, 2008 | Sony Handycam HDR-HC7E DV Digital...
Mv800i camcorder
well there are certain cassettes made for that camcorder. i suggest you search for what the are called and then you can buy them
May 26, 2008 | Canon MV800i Mini DV Digital Camcorder
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Cassette warning
The switch is board monted and is actuated by the loading compartment when it is closed near the rear of the cabinet. It requires an extensive tear down to remove the board before the switch can be replaced. There are other problems that occur also. Does the drum spin up? If so, then the tape is rcognized but its another problem. Good luck, magic seadog
Aug 12, 2007 | JVC (GRAXM18US) Camcorder
Cannon ZR 60 camcoder Cassette copartment does not open
Loading unit problem is a common mechanical problem in camcorders. To remedy the problem, trained tech need to disassemble the mechanical system around the loading and replace few broken gears (plastics) and adjust it. Repair cost may run close to half of the new camcorder. If you really got to repair this camera for some sentimental reason or for special needs otherwise better to invest the repair charge into a new camcorder.
Mar 15, 2007 | Canon ZR60 Mini DV Digital Camcorder
Canon MVX200 Mini DV Digital Camcorder Logo
57 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
