Question about Powerware 9120 UPS System
I have a Powerware 9120 2000 UPS battery failure message
I have a Powerware 9120 2000 UPS that I changed the batteries on, and I have a battery failure message on the unit that will not go away.
    Scholar:
  • 195 Answers
After you replaced the batteries did you perform a manual battery test?
If not do so.
Regards
Alan Hood
ami-man
UK
Posted on Mar 03, 2009
What does message :a #alarm 199: "batteries disconnected" means, and how to resolve this problem? thank's!
The charger board has failure. Model already obsolete. Propose to buy a new unit
Aug 23, 2013 | Powerware 9120 UPS System
Alarm #191 open cell voltage powerware 9130
Alarm error #191 comes from a battery test, where batteries are put under load for 25 seconds. (If the alarm is unexpected, you might have enabled the periodic 30-day battery test.)
#191 is test failure for battery internal resistance. So, need to locate and replace the bad battery, then run the battery test manually. If batteries are good, make sure no battery connector is corroded or loose.
Feb 04, 2013 | Powerware Series 9 9170 UPS System
I have a powerware 9120 (6kva) and about 1 week i replaced all 20 batteries after the UPS failed. but its displaying battery disconnected when i try to power it. i cant seem to figure the problem. i tried...
Did your UPS display "Battery disconnected" or did it display "Battery Failure"? If it was "Battery Failure", for some reason the Powerware 9120 will take almost 18 hours after plugging in to power after battery replacement to correct the Battery Failure indication. Charger has to charge up the batteries, followed by an automatic battery test by the UPS. If the indication was "Battery Disconnected", you will need to check the internal fuses to see if they are blown. If the UPS keeps blowing fuses, it will require a board repair.
Jun 12, 2011 | Powerware 9120 UPS System
I ave a powerware 9120 and get a Charger failure alarm
check your batery, may it was leaked, change it with new battery
Jan 17, 2011 | Powerware 9120 UPS System
Need to locate someone to install batteries into our UPS Powerware 2000. Location, Tempe, AZ (Phoenix, AZ)
Try contacting Eaton. They bought Powerware about 6 years ago and the personnel are trained on older Powerware systems. If you have the part number and serial number from the rating label on the UPS, that would be helpful.
Toll Free: 1 800 356 5737
E-mail: SinglePhaseTS@eaton.com
Nov 24, 2010 | Exide /Powerware PowerWare 2000 UPS...
Alarm and battery failure ; Powerware 9102
open the screws and disconnect the battery look the voltage written on it and AH (ampere/hour) e.g.12v & 7ah and purchase same value battery and connect look carefully the +ve &-ve polarity of battery and connect in proper way
Feb 24, 2010 | Powerware 9120 UPS System
Powerware 9120
Greetings!
How many years is your ups working? UPS is usually run by a battery, some of them are disposable and needs replacement. If it does not charge anymore it needs replacement of battery.
Thanks.
Nov 06, 2008 | Computers & Internet
Battery Failure
Hi
if the battery is bad you better to replace a new one!
Thanks!
Sep 23, 2008 | Powerware 9120 UPS System
9120 Battery Failure
sounds like inverter is unhappy(causing the input fuse to blow. maybe, just maybe, this Powerware 9120 has given up the ghost? The inverter can short for a variety of reasons. Try to take out the battery completely, and run it as just a power conditioner. If that works, then you have an unhappy inverter in there.
Feb 05, 2008 | Powerware 9120 UPS System
9120 battery failure
sometimes the battery tester is not enough to check the battery. battery also prone to tear and wear.because of charging ang discharging. replace the battery
Powerware 9120 UPS System Logo
949 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
