Question about Maytag HAV3460AWW Top Load Washer
Maytag Washer Whats a washer tube?
  • Maytag Master
  • 19,396 Answers
It is the big container where you put the clothes inside, and you have an outer tube and an inner tube often called drum.
Move the mause on top of this diagram to identify washer parts.
Posted on Mar 03, 2009
Loud vibrating washer
What is the model number of the unit?
Mar 03, 2014 | Kenmore HE2 Plus Front Load Washer
My washer fills with water and keeps filling doesn't stop on the selected water level for the load. It doesn't wash because the water keeps filling. What's wrong with my washer? Help please (Maytag...
The problem is simple and easy to fix. Your washer has a tubing which runs from the base of the tub to the water pressure switch. It might have vibrated loose from the switch, or their can be some sediment in the tub. Blow out the tubing and reattach it securely to the switch and pump out the water in the tub. Then try it again. I wrote an article about this:
Help my washer is overflowing !!!
Jan 07, 2011 | Maytag PAV2300 Top Load Washer
Makes loud noise in spin cycle
The problem is that the seals are leaking and allowing water to attack the tub bearings.
You need new tub seals and bearings.....not as difficult as it may seem.
see u tube video on replacing maytag seals and bearings
Cheers Stan
Aug 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
Maytag Top loading Washer, fills but won't stop filling and then overflows and will not start the cycle
there is a small tubing about 12 inches or so that connect from the water level dail to the tub of the washer. sometimes the clamp on there gets loose and that interfers with the communication. try changing the tubing and or just tighting the clamps. you will need to lift the top of the washer off to get to it.
hope this helps
Mar 06, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer overflowing
Remove the tube from the water level switch. Blow it out so the sediment will stop blocking the tube. Re-attach it and pump out the water. Retry.
Jan 04, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer
check the timer. they have had a lot of problems with these.
Apr 24, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag HAV3460AWW Top Load Washer Logo
42 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
