Question about Refrigerators
Water that should be evaporatin is collecting in the bottom of the refrigerator. Sometimes it puddles on the floor. The fan seems to be running well.
  • 400 Answers
This may be caused by a number of things. Your unit may be short of refrigerant so it does not get to the setpoint temperature and causes excessive amounts of condensate, too much to evaporate. Or check your door gasket is sealing properly. Or check there should be a drainpan in the compressor area, if not you have a problem, if there is one, make sure it is not leaking.
Posted on Mar 05, 2009
My french door freezer side water is dripping collect in the bottom of the freezer. its frozen solid and then melts and drips out the front of freezer onto the floor making a puddle of water
Your drainage hole is blocked.. empty the bottom half of the fridge and freezer .. you will see a V shaped moulding in the back panel INSIDE each compartment.. smack bag in the middle is a hole that allows the condensate to run away, but sometimes a pea or other obstruction clogs it, so the water cannot run away, but is held back.. where it refreezes, blocking the tube further, and causing the next cycle to run the water into the bottom of the appliance, where it refreezes.. but later thaws and floods.... I suggest you pull out the appliance so you can check the drainage tube(s) by eye.. use a chopstick, and if you can find a cheap shop selling 'bottle brushes' about the width of your little finger, push that up and down it a few times to properly clean it..
Apr 24, 2017 | Refrigerators
Water is not turned on at wall, water is coming out of the freezer section from bottom of coils at back. Large ice puddle in bottom of freezer unit. water is continually coming out of the unit with large...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 29, 2011 | Refrigerators
Ice collecting in bottom of Kenmore Coldspot freezer side and then melting and ending up on the floor. It was first discovered by a puddle on the floor. This model--"59282990"--has...
Leo Ponder
imufo2
Aug 09, 2011 | Refrigerators
Freezer is cold, fridge side is not. Fan runs, compressor seems to run. water puddle on the floor on fridge side. anything available for DIY?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 01, 2011 | Amana ASD2620HRZ Side by Side Refrigerator
Puddle of water in front of the refrigerator--
Ur colling unit is etheir broken or not at the right setting
Nov 19, 2009 | Samsung RS2556 Side by Side Refrigerator
My whirlpool Gold is having condensation and it is puddling in the floor causing damage to my cabnets that surrond it. Can you suggest any solutions?
This water is accumulated during the automatic defrost cycle, which occurs every 24-hours. A fan is supposed to pull air over it to evaporate it.
Clean all the dust and lint accumulation from under the unit, remove the condensation collection pan and clean it, and make sure the bottom fan is running.
I can't emphasize strongly enough how much of an enemy the accumulation of dirt and dust under a refrigerator can be its worst enemy. It can make the refrigerator exhibit symptoms of much more serious problems. Sometimes a good cleaning can have it operating like new with no real 'repairs' whatsoever.
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Aug 29, 2009 | Refrigerators
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
