Question about Euro-Pro 473
No matter how small or large my needle is, it breaks frequently. It is as if it does not always move straight up and down because it slams into the "plate" which is now all rough. I purchased my machine used, and it seemed to have had the problem before I got it. I have had it cleaned (was full of lint) and oiled, but the problem persists. It also breaks the thread frequently! I would love it if it would just stop doing these 2 things.
    Problem Solver:
  • 4 Answers
Seems as though the needle bar may be bent check this by turning the machine by hand, without a needle, if there are tight spots, then the bar may be bent. Try a thinner needle and go threough the sew cycle by hand, this can tell you a lot.
The thread is snapping because of all the needle breakages making the hole in the needle plate full of sharp edges, get rid of these by removing the needle plate and using strips of fine wet'n'dry paper to smooth them down. aceck the bobbin case for sharp notches too.
Get the timing fixed and your machine should be working ok
Posted on Mar 03, 2009
When using the zig zag stitch, why does the top thread keep breaking?
These are suggestions to try. Clean the lint, dust, thread pieces from the bobbin area, the feed dogs, and under the needle plate. Oil the machine according to the manual--use only fresh, good quality sewing machine oil.
First, make sure to install a brand new needle and verify that it is installed facing the correct direction. Confirm that the needle you are using is compatible with the thread and fabric of your project. Spend a couple extra dollars for good quality needles. You don't have to buy Schmetz, as there many other good needles on the market. Avoid the generic or cheaper brands.
All About Needles (see the troubleshooting guide especially)
Check that the thread is not too large for the needle's eye. If the thread is shredding and eventually breaking, it could be old or poor quality thread or the needle is shredding the thread. Some needles have a larger groove (scarf) on the back above the eye that protects the thread as it pierces the fabric over and over. Sometimes, coarse fabric will tend to shred the thread because it acts much like sandpaper.
Try a different brand of thread--preferably a good quality brand of thread. Avoid using old or bargain bin thread. Some machines can be very finicky so some experimentation may be needed to determine the brand of thread that works best.
When threading the machine, ALWAYS RAISE the presser foot throughout the process so the thread will seat properly in the tension disk. Confirm with the owner's threading instructions that the thread follows the correct path and does not skip any guides or wraps around something. Also check that the thread spool does not have any nicks or burrs that may be snagging the thread as it unwinds. May seem trivial, but confirm the thread spool is unwinding in the correct direction on the spool pin. Thread is twisted when it is made. If it comes off the spool in the wrong direction, it will reverse the twisting, making it loop, knot, and weaken as the fibers untwist.
When sewing zig-zag, generally the tension needs to be loosened more than straight-stitch, otherwise it can cause the fabric to create a "tunnel" between the zig & zag stitches. If the fabric tunnels, the tension is too tight. The tension is correct when both the upper and bobbin threads meet in the middle of the fabric. It doesn't matter if your tension is set @ 5 or 2 as long as the upper & bobbin threads meet where they should. The upper tension setting is not static. It is meant to be adjusted, probably every time you change needle, thread, or fabric. Always test the tension on a piece of scrap fabric from your project. Duplicate the situation you plan to sew, ie use the same needle, thread, fabric, the number of layers of fabric, stabilizers, etc. on your test. Then when you sew your project, you will know that it is set correctly.
http://www.craftsy.com/blog/2015/03/how-to-adjust-sewing-machine-tension/
One last thing to check--look for any nicks or burrs in the bobbin area, ie the hook, the needle plate. Frequently, when a needle breaks, it will create a notch or nick where it has hit the hook or plate. That nick will tend to catch thread and cause it to break or stitch improperly. You can wrap your finger in a piece of hosiery or other fine fabric and run your finger around the metal parts to see if it snags anywhere. If it does, sometimes if the nick is small it can be smoothed with a fine emery board or sandpaper. However, if the nick is large, you will most likely need to replace the part or take the machine to a technician.
Apr 14, 2016 | Sewing Machines
Why does the fabric get stuck in the feed dog plate?
try changing the needle it could be blunt
also make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin are for lint
Mar 24, 2016 | Brother Se425 Computerized Embroidery &...
Keeps breaking needles
Slow down and watch what you sew over.
No needle is going to sew through the metal part of a zipper.
With many layers of fabric you have to slow down. If you have multiple layers of a thick fabric you may have to resort to using the hand wheel to get through the layers.
Another tip would be to not pull on the fabric. The machine is capable of "feeding" the fabric at the rate it requires. When sewing with many yards of fabric the weight of the fabric may create a pull on the needle. If the needle is pulled so that it no longer goes through the need plate properly it will hit the metal of the needle plate and break. Instead rest your hands on either side of the fabric and gently steer the fabric. Do not pull it out of the back of the machine or shove it into the needle. With large yardages wad up the fabric around the machine so that the weight of the fabric isn't causing strain around the needle.
One other tip. If you have a needle plate in your machine that only supports straight stiching, that is one with a needle hole that is just big enough for the needle to move up and down, and you switch to a zig-zag stitch, you will break the needle. Most factory installed needle plates have a needle hole large enough to support the largest zig-zag that the machine can support. But some machines have custom needle plates (for quilting) that only support a straight stitch.
Dec 08, 2014 | Sewing Machines
Needle hits something and breaks on my pfaff 2140
check that the selector button is fully down on the straight stitch. It should matter if the needle is straight and you have a zig zag plate on the machine. The other option is that the needle is bent and a new one may fix the problem. They dont need to be out by much but you said you had broken needles so it might even be a timing problem and hitting the bobbin case rather than taking the thread to be picked up by the racer.
Mar 26, 2014 | Sewing Machines
Needle keeps breaking Model 150 Euro=Pro Sew Machine
broken needles can happen if you are pulling the fabric through rather thsn letting feed dogs move it, or if stitch setting needs a wide hole foot but you have straight stitch foot on. could also mean timing between needle and shuttle is out of sync.
or needle size is too small for weight of fabric you are sewing.
check out www.sewing.about.com for needle size info and use new needle for each new project.
if yoy suspect timing out take to technician for fulk service.
Jun 16, 2011 | Euro-Pro Sewing Machines
I can start working withmy baby lock, the needle brokes verytime i runthe machine , and i can not sew
If this machine has a needle position adjustment and it is on the center position -
and you are sewing a zig-zag stitch and using a presser foot with a narrow opening this could break the needle
and the needle plate is a single hole, this will break the needle.
and you are sewing a straight stitch with a new needle and it breaks, the machine needs to go in for servicing.
Feb 13, 2010 | Baby Lock Sewing Machines
How to thread my sewing machine? Husqvarna Classica 95
Suggest you contact an authorized Husqvarna Viking dealer. They can order you a user manual. Authorized dealers can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Brief description of probably how to thread from looking at a picture of a Classica 90 machine which should be similar -
Thread sits on spindle on backside. Pull thread straight across to upper left backside and fit in the metal guide. It should pull easily with only a little resistance. Pull thread forward across top toward you. Let thread fall between the metal disks (doesn't matter which one if more than one) and pull thread straight down. Pull thread slightly to the left to fit under a hook of some type and back up to fit through the large hook that moves up and down when the handwheel is turned. Come straight back down to needle and thread through eye of the needle. Just above the needle should be a thread guide (sideways hooking looking metal piece), slip the thread through it to hold thread close to needle. Hope this helps. Otherwise a local authorized Husqvarna Viking dealer will be glad to help you. Good luck.
Sep 19, 2009 | Husqvarna Viking 1
Thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Dec 16, 2008 | Simplicity American Denim SA1100...
Euro-Pro 473 Logo
74 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
