Question about Acer Aspire 5315 Notebook
Used restore to another date, still locked in this process,
Have 5315 acer laptop bought may 2008 please help still restoring files and system since 9pm last night what can I do please, vista was installed on laptop when purchased and have no back up cd.
learning to use this, in my late 50s.
Linda
    Scholar:
  • 82 Answers
Hi Linda,
It sounds like the restore failed , try powering the PC off by holding the power button down for at least 5 seconds. Then reboot.
Hopefully that will let you back into Windows, if you continue to have problems , try the following.
Make sure you have your data backed up.
Turn on the computer and when you see the white Acer screen fully loaded, press and hold Alt+F10 to do the reboot.
This should start the recovery process from the recovery partition on your PC.
If that fails , you will need the recovery disks, unfortunately , acer does not provide them and expects you to make them by going to Acer eRecovery Management's "System backup to optical disc" feature to burn a backup image to CD or DVD.
Since you cant get into Windows , if you havent already made them , you need to order them from Acer.
Yes they make you pay for them.
You can order them here.
https://secure3.tx.acer.com/RCD/Main.aspx
Good luck.
Posted on Mar 03, 2009
I have an aspire 5315. Acer Arcade has disappeared and I can't seem to find a way to recover or re-install
Start -> Search -> Acer Arcade -> Start search -> when application is found single left click to highlight it -> right click on highlighted area -> send to -> Desktop (create shortcut) -> double click on new Acer Arcade` desktop icon to test the program.
If the above does not fix the problem:
start -> all programs -> accessories -> system tools -> system restore -> restore my computer to an earlier time -> next -> select a bold date on the calendar to the left and an even in the event schedule to the right that both precede/predate whatever change in settings that caused your application's icon or file directory to change configuration -> restore -> restart computer without interrupting to complete restore process -> look for the lost program in its usual place.
If none of these resolve the problem, then the programs may have accidentally been deleted by yourself or perhaps by another user, without your knowledge.
The following Site has links to download and install your lost application or, alternatively, the deluxe version:
http://komku.blogspot.com/2008/05/download-acer-arcade-deluxe-for-windows.html
Nov 22, 2011 | Acer Aspire 5315 Notebook
I have an Acer Aspire 5315 and the webcam is saying not found but the drivers and software is installed and up to date...Please help
When was the last time it worked?
Make sure that there is no other application running that also uses the webcam.
Try to do a system restore.
Click start->go to All programs-> go to Accessories-> go to System Tools -> System Restore
Restore it to a date when you were sure it was working.
Hope this helps!
Apr 13, 2011 | Acer Aspire 5315 Notebook
Hi i have a trojan on my acer 5315 laptop how do i restore it to factory settings thanks
Welcome to Fixya. Here is the standard Acer Recovery Instructions
1. Power on the machine
2. At the white ACER BIOS screen, hold the Alt key and press the F10 key simultaneously to start Acer eRecovery
3. Once eRecovery has loaded, click Restore to Factory Default Settings
4. Click OK to continue
5. From here, the eRecovery process will update all the data on the C: drive and restore a fully functional factory image (approximately 10 minutes).
6. Once eRecovery has run, press OK to reboot unit
If this wont work you need to use the recovery cd of your system. Take note that if you do the reocvery process all files will be deleted and the system will go back to default or factory state.
Thanks for using Fixya.
Mar 03, 2011 | Acer Aspire 5315 Notebook
I used my acer aspire 5315 and restored to factory default using empowering technology and now everytime i start up it keep trying to reinstall the restore programe that came with the computer
There are two basic ways to restore Acer 5315 PC Notebook to the original setting. The first method you can try to pressing the key Alt + F10 for 5 times while startup process appears on the Acer screen. Usually this way will restore the original setting automatically.
And the next method you may need to use system restore at the first time you’ve got your Acer 5315 laptop. Here are steps to follow:
Log on as the Administrator => Start => All Programs => Accessories => System Tools => and click the System Restore. System restore will run and here you should see the Welcome System Restore page appear. Click Restore my computer button to an early time if it’s not already
selected. Click next to continue the steps.
There is on your Acer 5315 laptop screen a Restore Point page appear, you can select it and then click the most recent system checkpoint it, click a restore point list. After you click the Next button, System Restore message may appear that lists configuration changes that
System Restore will create. Click OK.
For the last step click next button on the Confirm Restore Point Selection page. Now the ‘System Restore’ will restore the previous Windows XP configuration on your Acer 5315 OS system. Just finish it by restarts your Acer laptop.
Now log on again to your Acer 5315 PC Notebook as Administrator and watch the System Restore Restoration Complete page
JAIN_IT {INDIA}
Sep 14, 2010 | Computers & Internet
Need to restore my acer aspire to factory setting but never got a recovery disc at purchase,how do I go about doing this as i am not that technically minded
"Restoring a system should be a last ditch effort in trying to repair a computer, since restoration causes all programs and many files to be lost forever. Restoring an Acer computer to its original factory settings can be done in a few easy steps."
  1. Click “Start” menu.
  2. Click “Programs.”
  3. Click “Acer Recovery Management.”
  4. Click the “Restore” button on the bottom of the dialog box that opens.
  5. Click “Restore System to Factory Default.”
  6. Click “Yes” in the warning dialog box which asks if you wish to continue the recovery process.
  7. Click “Start” to restore the computer to the default factory settings.
Dec 31, 2009 | Acer Aspire 5315 Notebook
How 2 factory reset an acer aspire 5315 laptop
Now log on again to your Acer 5315 PC Notebook as Administrator and watch the System Restore Restoration Complete page appears. Click OK.
Dec 30, 2009 | Acer Aspire 5315 Notebook
How do i do recovery on my acer aspire 5315-2153
There is on your Acer 5315 laptop screen a Restore Point page appear, you can select it and then click the most recent system checkpoint it, click a restore point list. After you click the Next button,System Restore message may appear that lists configuration changes that
For the last step click next button on the Confirm Restore PointSelection page. Now the ‘System Restore’ will restore the previous Windows XP configuration on your Acer 5315 OS system. Just finish it by restarts your Acer laptop.
Oct 29, 2009 | Acer Aspire 5315 Notebook
Resetore back to fac. settings
Dec 05, 2008 | Acer Aspire 5315 Notebook
Need to Restore My Acer Aspire 5315
Turn on your laptop...as soon as it turns you push thepower botton start pressing F8, this will take you to the system recovery screen. You will need to pick the option that says system restore. Dont pick the option that says restore to a restore point, you will need to pick the one that say destructive restore. usually u get this option by pressing the advanced options. It will give you a warning about the system being reformatted...are you sure...yada yada yada... click ok and it should reformat the system and then reinstall the original facotry software
Nov 09, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
