Question about Samsung SCX-6320F All-In-One Laser Printer
Printer prints very light
Printer SAMSUNG SCX-6320F has started to print very light copies. I have changed to a BRAND NEW CARTRIDGE and it still prints light. I even changed the Darkness contol to darkest setting but it had no effect. Any suggestions?
  • 56 Answers
Its may be happend due to the Dust in the LSU unit.
remove the LSU from machine and open. Then after clean all the mirrors and polygon .
after that your problem should be solved.
Posted on Feb 26, 2010
Samsung scx 3200 prints dark but xerox copies are so light that they cant be read
HI PLEASE CLEAN THE CCDUNIT .YOUR PRINTER CCD UNIT IS VERY LOTS OF DEST.AFTER CLEANING CCD THEY PRINT SAMSE SO REPLACE CCD UNIT WITH CABLE
Feb 14, 2014 | Samsung SCX Office Equipment & Supplies
Cannot print 4521f
cartridge inserted poriton ( fuser unit bottom portion ) you can see a small "L" shadped liver fixed with a screw, removed that from there and try with new cartridge.
Jan 15, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Side problem in samsung 4521
ok, if new catrdge doesn\'t correct the problem,, surely it might be laser window . clean slit glass just above the drum place. if copy only defective print ok,, it may be other case; but both c&p bad, cent% laser obstruction. clean as above, all the best!!!
Dec 21, 2013 | Samsung SCX 4521F All-In-One Laser Printer
When photocopying, leftside print missing/text
it is only happned when you takes only photocopy ? or Printing... The same will be affect while printing and copying may be the problem related to Laser Supply unit, open the LSU and clean the LSU mirror with a cotton waste. Your issues must be solve....
before that pls. check your cartridge unit...
Apr 24, 2010 | Samsung SCX 4200 All-In-One Laser Printer
I have used new toner so many times may be in within 500 copies the prints gets light pliz can help me identify the problem, verytime i change its working fine but after that much prints its light but the...
please you service your copier laser unite.
clear your copier cartridge wast toner unite
or setting toner save mode if you are saw on setting off
thanks
Tareq
Aug 26, 2009 | Samsung SCX-4521FG All-In-One Laser...
Toner exhausted replace toner in Laser Printer SCX-4300
My laser Printer shows a message and do not prints any document. When i try to print any document. My printer shows a message "Toner Exhausted, Replace Toner". Plz tell me how can i solve my this printer's solution.
Mar 25, 2009 | Samsung SCX-4300 Monochrome Laser...
Samsung 6320f black copies
There is no power supply in a charge system. Check the contacts. Check voltages according service manual.
Nov 17, 2008 | Samsung SCX-6320F All-In-One Laser Printer
Printer will not print
Some thoughts.
When you plug it into the computer that it will not print to, Does it tell you there is a new USB device found?
2. I am sure you have tried different USB ports on the computer.
3. Right click your printer to access the properties on the driver and select Ports and see if that somehow was changed.
4. Just delete the printer from the "printers" page in control panel.
Then click add printer and search for it.
5. Make sure the computer does not have a firewall that is blocking the printer.
6. Make sure there is no job error in the print queue.
7. Be sure the printer is selected as the "Default" printer. If there is another printer loaded on the computer, is the wrong one selected?
8 Make sure Print Pause is not selected.
I do suspect once you open the properties on the driver page you will find the problem. Unless of course your USB port or ports on the computer have failed.
Dec 14, 2007 | Samsung SCX-6320F All-In-One Laser Printer
SCX-6320F Samsung
Dear ,
Do u need to pull out the paper or  it comes on it's know,
THE ADF SENSOR OR
THE ADF ASSEMBLY CABLE SEEMS FAULTY..
PLEASE REPLACE AND CHECK..
HAPPY FAXING/COPYING/PRINTING
OMNIPRESENT
Oct 10, 2007 | Samsung SCX-6320F All-In-One Laser Printer
Printer prints lightly after changing a cartridge
i guess you have problem with the poor quality ink.
faced same problem.
i re-filled with best ink in the market and the problem was gone..
i hope that helps
Mar 21, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Samsung SCX-6320F All-In-One Laser Printer Logo
256 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
