Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
I have a Monitor 30, it comes on and just runs, it will not lite until I lift the primer once or twice, then it heats fine. I checked the filter and made sure the tank was high enough for a 5 gallon gravity feed
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Rob,
You have some kind of fuel problem. When you mention 5 gals of fuel, that leads me to think you need more fuel ( more pressure). If you have a large tank and only have 5 gals you may no have enough head pressure to push the fuel through the line and all the filters in the system. That being said the Monitor 30 is the oldest vented heater around. Parts have not been available for 15 years. The thing that scares me about the M30 is the flame safety circuit. I don't think it is adequate. If you rely on this heater to keep pipes thawed I would get a new Monitor or Toyo.
Tom Hawkins
hawkins111@gci.net
Posted on Mar 03, 2009
I have a monitor 422 the burner status lite blinks but it wont lite
Posted on Nov 01, 2009
1995 international flat six diesel 466 wont run changed fuel filter losend lines bleed out air wont run squirt eathier starts dies
Make sure you pre fill the filters with clean fuel. Locate the hand primer usually near the fuel lift pump. Unscrew the top till it pops up. Pump repeatedly until it gets hard to pump. You can crack the injector lines while pumping till fuel comes out or have someone crank the engine with the starter while you continue to pump the hand primer. Make sure after it's running the pump is pushed all the way down and tightened back up
Nov 27, 2014 | Cars & Trucks
Dryer wont stay lit
if the flame is liting most likely problem is bad air movement.go outside with thedryer running and check the hood to see how strong the air is blowing out,if there's a cage or anything blocking the hood remove it,if the vent line is a long run remove the vent line from the back of the dryer,stick a leaf blower into it and blow out the lint to the outside.also with the dryer unplugged,remove the bottom panel,remove the lint filter and metal duct the filter slides into,clean that out and blow out the blower wheel with a shop vac,you can blow out the gas tube where the flame ignites to make sure it's clean blow off the motor and the cabinet and vac up all lint that blows forwards.you can try running the dryer with the vent line removed to see if it runs any better.when the dryer first heats up the flame will come on until the temp. is reached and it will shut down,one more thing to check,when gas coils start to fail you'll have heat for like the first 15 to 30 minutes,then when the coils heat up the ignitor will glow but no flame,after the coils cool down they will work again.how are you running it on timed dry or more or less dry,if you run it on auto or more or less dry there's a sensor inside where the lint filter is,try cleaning it up or try running it on timed dry to see if it runs any different,when on auto the heat comes on,when it reaches temp. the heat stops and the timer will advance,when it calls for heat the timer stops and the heat comes back on,it will do this until the clothes are dry.your model has an even heat board in it that can also cause problems but if the flame is liting it sounds like you have a block somewhere.go here this will tell you a little more about your model dryer.
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
May 23, 2013 | Dryers
I have a McCulloch Model FR 2.3 18 in. chainsaw that will fire up and run for approx 30 secs. and then shut off. If I pump the primer bulb twice, it will fire up again for approx 30 secs. I'm ve
This is oviously fuel starvation, the first thing to do before speding too much time on it is to replace the fuel filter in the fuel tank, hook the hose out with a piece of bent wire, pull the filter off and replace, as a quick test pull the filter off, let the fuel hose go back into the tank, make sure the tank is full, now try. Do not leave like this you must fit a new filter.
Mar 30, 2013 | Garden
Husqvarna 125B will start and run but once it heats up it stalls and will not start until it cools down
sounds like it's going lean lack of fuel check for cracked fuel lines,primer bulb or leaky carb to engine gasket
Aug 25, 2012 | Husqvarna Garden
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
My yard machine Edger 3.5 hp wont stay runing if i put ges in the air filter hole it runs for a few sec. if I put my hand completly over the hole on the air filter it will run on low idle but as soon as i...
remove the gas can carefully the pulsa primer carburetor sits on top. Once you remove the tank open the cap and pour out the gas. THen carefully unscrew the five screws holding the carb on. Carefully lift the carb up leaving the gasket in place and clean the small 4 chambered bowl with starter fliud. Replace all parts put gas in it, push the primer until you see gas squirt into carb then pull the handle.
Sep 03, 2010 | Yard Machines Red Edger
Carburator issue?
Check the fuel line...it may be damaged as well. mine had a small crack in it and it was just replaced and now runs fine.
Jul 11, 2010 | Homelite Mighty Lite Lawn Trimmer
1995 Daewoo Racer, Stops suddenly for no apparent reason.
Check heat level of your at that time. A sensor is installed in its Radiator, which automatically turn off the vehicle (as the Temperature needle crosses 3/4) until its temperature falls. In case it is true, then; 1) clean its radiator 2) Check the sensor installed in its radiator. (this sensor was not available in 1993 model)
Aug 05, 2009 | 2001 Daewoo Lanos
Air in fuel line?
get a container with fuel(about 4 liters will do). put a hose from the Primer to the fuel container and another hose from the injection pump return line to the container. if it works fine then the air leak is between the tank and the primer.
Jun 03, 2009 | 1987 Mitsubishi Passenger
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
423 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
