Question about LG WFT1071TP Top Load Washer
My wf-t8016tp Top loader gives an AE error message. It is not described in the usermanual.
  • 83 Answers
SOURCE: Dead LG WF-T8016TP washing machine
Is there any other appliance plugged in the same power point, and does it work?
Otherwise, plug another appliance in it to test that the power point is actually working.
If it is not, possibly a fuse has blown or breaker switched off in your meter box outside.
Let me know
Posted on Sep 16, 2008
SOURCE: I have a WF-T556 top loader with a de error.
There sure should be....why, because mine stopped working as well. Found magnet inside machine after getting rid of water on spin cycle (thankfully it still allows the water drain to occur). Put magnet back on and hey presto, all good.....if only I had taped it on as 5-6 washes later and it has fallen off and I can't find it - hopefully a standard magnet will be enough to fix from shops - I am sure LG or proper repair place sells them for a fortune :(
Posted on Aug 07, 2010
  • 3230 Answers
SOURCE: I am getting error DE
HI there,
Well most of the times problem is in the door lock may be it's faulty. or it could be the door lack has failed/is failing or the control board, try closing the door properly and see if it works....... If further you have the same problem then you need to change the door lock (switch).
Good Luck
Thanks for using FixYa!!
Posted on Dec 03, 2010
  • 330 Answers
SOURCE: my machine lg top loader
this means door error there is a magnet in the lid that falls of and this is how the computer knows the lid is shut lg dont sell the magnet you have to replace the whole lid sorry.
Posted on Jan 11, 2011
SOURCE: my model is WF T8016TP
-Unplug the machine
-Remove the pressure sensor, a 3 inche round piece under the back of the top-cover.
-Clean it, by pushing whater in the small hold. (I used what we could find a the drugstore for ears cleaning.)
-Start the machine Without putting them back and wait for the error message. (like we do for PC hardware)
-Replace the sensor, start your machine and the error message should be gone.
Hope it works.
Posted on Jun 18, 2011
Fault PE....How do I replace the pressure sensor on an LG fuzzy logic 5kg wf-t502 top loader and where can I purchase this part?
PE Means pressure sensor error this spares is very rare to defect 1st check full pressure sensor the wiring harness any damage or wire cut means the error will show in display
Mar 26, 2015 | LG Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
My model is WF T8016TP I am having the PE Error when i start the washer
-Unplug the machine
Hope it works.
Jan 31, 2011 | LG Washing Machines
My machine lg top loader wf-t7050tp gives me a dE error what does that mean
Jan 11, 2011 | Washing Machines
I am getting error DE in my washing machine, need solution for this. Kindly give me the service error code for LG WF-T7516HN top loader
HI there,
Good Luck
Dec 03, 2010 | LG Washing Machines
I have lg top loader washing machine model wf583spc if i start any program after 30sec the De error blinking please give the guide line also drain clear & door ok but always show same problem
I HAVE LG WF-583 FULLY AUTO W/M AND MAIN CONTROL PCB IS DEAD IN THIS M/C. WHERE SHOULD I GET REPAIRED/ REPLACED THIS PCB AND WHAT WILL BE EXPECTED COST?
Aug 17, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Well I found the problem - fuse had blown.
There is a circuit diagram on the back of the washer that allowed me to locate the fuse. Take off the rear top plastic panel (behind the folding lid) by removing the two screws on the back. Inside close to the power cord you will find a fuse holder and an in-line ceramic fuse, 125V 12A. I checked mine for continuity and it had blown (as to why, I don't know yet - maybe the motor drew too much current with a large wash load?) - anyways, I replaced the fuse and everything works now!
Sep 16, 2008 | LG WFT1071TP Top Load Washer
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
LG WFT1071TP Top Load Washer Logo
95 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
