Question about Intertherm P3RA-048K Air Conditioner
Intertherm electric furace
My heat pump has ground short in compresser,does not work, my emergency heat is a backup system, my inside furance runs great, it heats for a little blows warm air and then still running the air will cool,it blows cold air, the unit cycles fine.I was going to check the heat coles what do you think?
    Scholar:
  • 144 Answers
It sounds like the coils are fine if you are getting heat. They are likely shutting down from overheating after being on for awhile. Check your filter and overall air flow to make sure it's adequate.
Posted on Mar 03, 2009
We have a interthem 2460 a furace and we need to know where to find a wiring diagram to show us how to connect it to the electric
If there is not a wiring diagram pasted inside the furnace somewhere, request it directly from Intertherm. Be sure to specify model 2460.
Dec 09, 2016 | Heating & Cooling
Is there any danger in running my Carrier HVAC in "Emergency Heat" mode all the time?
No theirs no danger in running the Emergency Heat all the time, Emergency Heat is your backup heat mode. when the Heat Pump is not working do to a malfunction or Defrost, the Emergency Heat kicks in. The Emergency Heat is usually electric heaters so your electric bill will be much higher.
Nov 07, 2016 | Carrier Heating & Cooling
Questions about a dual energy heating furnace
If you have a heat pump the electric heat is the emergency heat. Short explanation of a heat pump is it switches the jobs of the indoor and outdoor coils. So instead of taking heat from inside and moving it outside it works backwards picking up heat from outside and moving it indoors. Probably an electrical problem. 7_7_2014_5_33_51_pm.png
Mar 14, 2014 | Heating & Cooling
I JUST BOUGHT THIS UNIT IT HAS THE OUTSIDE UNIT AND THE INSIDE UNIT AND I WAS TOLD THAT THE HEAT PACKS IN THE INSIDE HANDLER IS FOR EMERGENCY HEAT ONLY...IS THIS TRUE?
Yes, if you are talking about a heat pump. It you have an electric furnace inside, the electric elements are for emergency heat. Otherwise, unless you switch it manually at the thermostat, the heatpump (outdoor unit) will run all year around. If you want to use your inside heater (electric heater) just switch your thermostat to "emergency heat" and it will turn on the electrical elements instead of the outdoor unit. This way will make your elec. bill higher tho. The heat pump is much more efficient. Hope this helps you , have good day
Jul 21, 2011 | Goodman Heating & Cooling
My heat pump is shot and is operating off the emergency heat. Can I just continue to use it this way or do I have to replace the heat pump?
You mean you are using the Emergency heat setting instead of the heat pump????...You're using Natural gas only now tn emergency heat????That's fine...I wouldn't replace a heat pump if you have Natural gas....it's too expensive compared to Gas....you may be able to still use the heat pump as an Air Conditioner only , it depends on what's wrong with it...otherwise you will have to get a Central Air unit instead...cheaper and just use the Gas for heat
Oct 29, 2009 | Amana PTH123B25AJ Heat Pump Air...
Abbreviation definitions.
Economy Mode = EM
Auxelary Mode = AUX
in em mode heat pump does most of the work in aux either an electric heating element is used or gas depending on if it is gas or all electric
Oct 16, 2009 | Ruud Central System Air Conditioner
As I was cutting weeds away from my outdoor ac unit, I accidentaly cut through a small wire that has a red and white inside of it, we wired them back together and still have no ac or heat or air, we just...
first try turning off the power to the furace for 15 sec and tunr it back on (reset the computer) you may have blown a control fuse on the contol board inside the furnace, turn off power and becareful of hazardous voltage conditions
Aug 15, 2009 | Intertherm P3RA-048K Air Conditioner
Amana Heat Pump Tripping Breaker
My guess I would say, you either have a wire that is short to ground or if the contacter pulls in, then I would say the compresser is short to ground.There also could be some capacitors that could be short.
Apr 07, 2009 | Amana PTH123B25AJ Heat Pump Air...
No heat new thermostat
you have a short in the wireing.disconnect at air handler and hook-up short t-stat wire to t-stat,ifok chk wire to condenser
Jan 10, 2009 | Heating & Cooling
Intertherm heat pump
FIRST YOUR OUTSIDE UNIT PROVIDES HEAT BY USING A REVERSING VALVE TO CHANGE THE REFRIGERANT FLOW.THERE IS NO HEAT STRIPS OUTSIDE SECOND YOUR EMERGENCY HEAT TURNS ON ELECTRIC ELEMENTS INSIDE YOUR AIRHANDLER UNIT.IT SOUNDS LIKE SOMEONE HAS WIRED YOUR UNIT WRONG OR HAS THE THERMOSTAT SET IMPROPERLY.WHEN THE HEAT PUMP CANNOT SATTISFY THE SETPOINT THE THERMOSTAT IS SUPPOSED TO TURN ON YOUR ELEC. HEAT UNTILL THE LOAD HAS BEEN REACHED AND THE HEAT PUMP CAN CONTINUE TO MAINTAIN IT.
Nov 28, 2007 | Heating & Cooling
Intertherm P3RA-048K Air Conditioner Logo
121 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
