Re: belling synergie oven - main oven won't come on.
Hi
check the timmer clock is not in auto mode as this will stop the oven from turning on. if clock ok then fault could poss be the thermostat
hope this helps you
Hi . Sounds like the oven thermostat is faulty., This gives a supply to the element . The temp indicator should be lit, if it is not, then I would suggest repl;acing the oven thermostat.
I suspect tha the oven element is faulty.
To access it, you will find it located at the rear of the oven compartment behind a removeable cover.
Hope this helps you.
When you turn the main oven on, does the oven fan switch on?
When you turn the main oven on does the cooling fan come on?
Does the dial illuminate when the oven is turned on?
Does the oven thermostat neon come on the the oven is switched on?
Have you had a power failure recently and have not set the clock?
Are you sure that the clock/timer is NOT set and in manual mode?
On my Belling it was the oven multi function switch that was faulty. I replaced it - carefully (lots of coloured wires) and it works fine now. Hope this helps
I have the same problem. I have inherited a Belling Synergie multifunction double oven. The Model No is worn out - yet there is a specification 492SS which isn't. I am going to purchase the element with this number and hope this works.
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
