Question about SanDisk Sansa c240 MP3 Player
Deleting file names in WMP
Hi
I've deleted files in WMP, but filenames remain when I go into "file".
Any ideas?
Boydsey
  • 75 Answers
Go to my computer. click on your mp3 player. right click. select format.this will remove everything except your opperating files.
Posted on Mar 03, 2009
I cannot delete the file "noConnect.png" from
Right click on noConnect.png and go to properties, go to security tab on the top, select advanced, go to owner tab and change owner to your own user name, click OK. On noConnect.png's properties click add and add your own user name. Click OK twice. Try deleting it again.
May 22, 2011 | Microsoft Windows XP Professional SP3 Full...
Tip
Unregistering DLLs
<p><b>Introduction:</b><br /> <p><b>What are DLL files?</b><br /> <p>DLLs are dynamically linked library files. DLL file contains a list of certain functions that can be used by various applications. Spool32.dll is a great example of how the things work: that file is used by various programs for print control within Windows 95 and Windows 98.<br /> <p><b>Why is it important to unregister malicious DLLs?</b><br /> <p>DLLs may contain information essential for a computer to function properly. Malicious programs may corrupt regular DLL files or they may install new DLLs instead of normal ones.<br /> <p>Deleting DLLs is a risky deal since it can affect computers performance and functionality of many applications. If a malicious DLL is somehow used by a regular application and the DLL file is removed, the application won't work normally even if the deleted DLL is not needed for a program to function. This is why you have to unregister DLLs before deleting them.<br /> <p><b>How to unregister malicious DLL files?</b><br /> <p><b>a) Open Command Prompt window</b><br />Click the "<b>Start</b>" button and select "<b>Run</b>" option. Type "<b>cmd</b>" into the "<b>Open</b>" field and click the "<b>OK</b>" button.<br /> <p><b>b) Unregister malicious DLL file<br /></b>Type "<b>regsvr32 /u filename.dll</b>" into the Comand Prompt window and click "<b>Enter</b>". "<b>Filename.dll</b>" should be the name of DLL file you want to unregister<br /> <p>
on Mar 15, 2011 | Computers & Internet
I have to upload a document on a site in word format,without any file extension, I have tried different ways but was not able to upload a file without having any extension?
I'm not sure why you'd have to upload a word document without the file extension, but you can do it by following these instructions:
Open Windows Explorer
Browse to the folder that has your document in it
Go to the Tools Menu (if there's none, press the ALT button)
Choose Folder Options
Select the 'View' tab
Make sure that the tickbox for 'Hide extensions for known file types' is NOT ticked
Click Ok until you are back to the folder with your document in it.
It should now have a name like Document.doc or Document.docx
Click on the file once, then once it is highlighted click again, and you can delete the .doc or .docx part.
Press enter when you are happy with the filename. Windows will give you a warning message saying it's not a good idea, but you can click ok past this.
OR
If you are trying to upload a file WITH a file extension, follow the same instructions above, and instead of deleting the .doc or .docx, simply add it to the end of the filename.
May 03, 2011 | Computers & Internet
Weird folder/filenames that will not delete There is a folder on my WD 250 GB Passport Flash drive who's properties show it to be using 157 GB of memory. The Read Only attribute was set, unchecked it. I...
Problem: Folders / files in USB flash drive got named with weird strange characters & those folder / files cannot be copied or deleted.
Reason: Virus infected
Solution:
1. Click on "Computer"
2. Right click on the drive that contains USB flash drive
3. Select "properties"
4. Click on "Tools"
5. Click on "Check Now"
6. Check disc options will appear on screen, put a tick mark in the box in front of Automatically fix file system errors
7. Tick mark in the box in front of Scan for & attempt recovery of bad sectors is not necessary.
8. Click on "Start"
9. Upon finishing of this task, screen will show message "Your device disc was successfully scanned" and bla bla. Close it.
10. After this process the undeletable folder in USB flash drive can be deleted by selecting it & deleting it. The contents of affected folders files cannot be recovered.
After lot of struggle I got this solution on my own by the grace of God.
Sure it will work for others too.
Thanks and regards Raju
Nov 25, 2009 | Western Digital Passport 320GB External...
Itunes wont open and says cant find needed file?
hi
This usually happens when you have either renamed the file, moved the file somwhere else, or deleted it all together. Sometimes you may forget editing the filename or moving it to a subfolder.
Whenever you do this be sure to go to itunes and either add the file again and delete the old one from the database or "Get Info" and update the current file. tho u ve not mentioned any specific name of the file i m tryin to give u an example..suppose u are cant locate the music file m sure the files are where they are supposed to be then they must have been renamed. You can verify this - Find a track with an exclamation mark next to it
Open your iTunes Music Library.xml file with Notepad (the iTunes Music Library.xml file is usually in C:\Documents and Settings\YOURNAME\My Documents\My Music\iTunes).
Search for the track name
A dozen or so lines below the track name will be the full path to the file and the filename.
Compare this to where you know the file to be. If it is different then that would show that something/someone has moved/renamed the file. hope u will b sorted out wth ur problem... all the best regards.
Jul 15, 2009 | Apple iTunes
Cannot delete my bad files...
Could be a process issue stopping you deleting the files. Try downloading unlocker (http://ccollomb.free.fr/unlocker/) and see if this helps.
If not it might be an 8.3 naming convention issue. Go to DOS prompt to a "dir /x /a". Rename the file to less than 8 characters using the SHORT name only. Then try deleting the file.
Apr 01, 2009 | Microsoft Windows XP Professional
Annoying files cannot be deleted...
First I recommend you try deleting the files from the Windows safe mode... it might work, or you an use the deleting software Unlocker
http://www.softpedia.com/get/System/System-Miscellaneous/Unlocker.shtml
Mar 20, 2009 | Microsoft Windows XP Professional
SAmsung YP-K3 MP3 player - Corrupted library ? cannot delete songs or synch
i would like to download other songs but i dont know how?and i have to delete all of them!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Oct 09, 2008 | Samsung YP-K3 MP3 Player
Microsoft Outlook 2003 sycn with yahoo email
Windows 95, 98, and ME syntax
Deletes one or more files.
DEL [drive:][path]filename [/P]
ERASE [drive:][path]filename [/P]
[drive:][path]filenameSpecifies the file(s) to delete. Specify multiple files by using wildcards./PPrompts for confirmation before deleting each file.Windows 2000 and Windows XP syntax
DEL [/P] [/F] [/S] [/Q] [/A[[:]attributes]] names
ERASE [/P] [/F] [/S] [/Q] [/A[[:]attributes]] names
namesSpecifies a list of one or more files or directories. Wildcards may be used to delete multiple files. If a directory is specified, all files within the directory will be deleted./PPrompts for confirmation before deleting each file./FForce deleting of read-only files./SDelete specified files from all subdirectories./QQuiet mode, do not ask if ok to delete on global wildcard/ASelects files to delete based on attributesattributesR Read-only files S System filesH Hidden files A Files ready for archiving- Prefix meaning notIf Command Extensions are enabled DEL and ERASE change as follows:
The display semantics of the /S switch are reversed in that it shows you only the files that are deleted, not the ones it could not find.
Windows 2000 and Windows XP recovery console syntax
Deletes one file.
del [drive:][path]filename
delete [drive:][path]filename
[drive:][path]filenameSpecifies the file to delete.
Delete only operates within the system directories of the current Windows installation, removable media, the root directory of any hard disk partition, or the local installation sources.
Del and delete do not support replaceable parameters (wild cards).
Examples
Notice: Users who are running Microsoft Windows 95 and are used to deleted items going to the recycle bin need to keep in mind that deleting files from MS-DOS does not send files to the recycle bin. del test.tmp = Deletes the test.tmp in the directory that you currently are in, if the file exists.
del c:windows est.tmp = Delete the c:windows est.tmp in the windows directory if it exists.
del c:windows emp*.* = (* is for wild character(s)) *.* indicates that you would like to delete all files in the c:windows emp directory.
del c:windows emp?est.tmp = (? is a single wild character for one letter) This command would delete any file ending with est.tmp such as pest.tmp or zest.tmp...
You may also configure your outlook express to auto delete Emails by creating a rule for them.
Illustration.
If you can not see the illustrations properly , youtube has excellent tutorials.
http://www.youtube.com/watch?v=wcb7x7ErtO4
Thank you for choosing FixYa!
Az.
Sep 19, 2008 | Microsoft Office Outlook 2003 for PC
Possible Incompatibility with WMP 11: Deleting Recorded Files
Its Nothing YouCan Do I Tried Everything...This MP3Was Set Up For The Older Version Of WMP Because At Work I Have WMP 10 And It Works But A Home I Got WMP 11 And It Doesnt Work...Its Just Something To Kee You Coming Back TO Buy Their Items
Dec 08, 2007 | Samsung Yepp YP-T7JX MP3 Player
SanDisk Sansa c240 MP3 Player Logo
41 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
