Question about Tools & Hardware - Others
Lincoln log bit??
I want to make lincoln logs. Can you recommend the correct router bit for the edges. Using 1/4" shank.
Thanks
dp
I have the answer to your question... there is a lincoln log bit in Rock http://www.rockler.com/product.cfm?page=5713&filter=22597&pn=22597 on this page it doesnt quite look like the right bit.. but in the catalog it shows a picture of lincoln logs, next to this bit... if you use the right size stock (wood) it will work .. like I said.. " in the catalog it shows lincoln logs stacked up using this bit) Page 32...
Posted on Feb 24, 2010
    President:
  • 1,996 Answers
I haven't seen a lincoln log in a long time, but I'd say something in the neighborhood of 3/8" round over bit would do it. It's going to depend on the size of stock you round off. Take off 1/2 or a little less than 1/2 the width of your square "blanks", and use that number as the radius of the roundover bit. If you want not a full 1/4 of a circle profile, use a little bit larger bit and don't raise it all the way out of the base to cut.
By the way, I'd recommend you use a router table to run these pieces, or you're not going to have much left to rest on for the final pass. With a router table, you can leave a square bit on each end that you don't route, (and cut off later), that guides the piece against the table and fence.
Much safer IMHO.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
  • efs_perpends
    efs_perpends Apr 02, 2009
    Much safer IMHO.
I have a B&D Router KW850E. It has collars and collet nut to take bits with 1/4 inch and 5/16th's shank. Can I get a collet nut and collar for 12mm or 1/2 inch?
probably not as the shanks of the router bits fit in the spindle shaft of the router which is around 1/2" dia
could always talk with manufacturer as to find an adaptor or like bit of equipment
Jan 19, 2017 | BITS Tools & Hardware - Others
Router bits wont fit on my router collet nut is to small.
The two sizes (in the US) for router bit shanks (and collets) are 1/4 inch and 1/2 inch. Some routers use only a 1/4 inch collet. Routers with a 1/2 inch collet also come with a 1/4 inch collet. You need a 1/2 inch collet to hold a 1/2 inch shank. Good luck.
Jan 16, 2013 | Tools & Hardware - Others
Router bits
Mike, The fit is just a little more snug than you expect. The collet is springy, and will expand to fit your bits, even if they were oversize (which is very unlikely). Put on a leather glove and just push the shank of the bit into the collet. Do not try to file down the shank of your router bits, you will only make them run eccentric. You don't need to remove the collet. Just loosen the locking nut about a half turn after it is easy to turn. Good luck. Thanks for using FixYa. Al Kupchella
Apr 20, 2010 | Freud FT2000E 3 Router
How to connect 1/2 inch router bit into dewalt router
Are you asking how to put a router bit with a 1/2 inch shank into a router with a 1/4 inch collet? You need a 1/2 inch collet. Most routers with a 1/2 inch collet can also use a 1/4 inch collet. But smaller routers cannot use a 1/2 inch collet.
If this isn't clear, please ask again.
Al K
Mar 29, 2010 | Dewalt DW621 Routers
I would like to change the access code so that my neighbours are unable to use my wireless. Security is already enabled but they have the password so I want to change it.
Hello.
First you will need to log on the routers homepage,
type 192.168.100.1
Log into the configuration page using your username and password.
Default password is motorola default username is admin
Select wireless tab,then select network.
change the essid from motorola to a different name.press save changes
next select the security tab,on the encryption select enable64 bit.
Now select key 1 radio button and enter a 10 digit number.WRITE THIS DOWN. when done select save changes and log off.You will need to enter this number into any wireless devices you may have in the house.
good luck and thanks.
Jan 22, 2010 | Arris SURFboard SBG900 Wireless Router...
I need to have a background in my facebook cuase i dont have friendster ok
This is the instruction on how to place the code above into your frienster.
1. Log into friendster
2. Click on profile
3. Click on edit profile
4. Click on customize
5. Then go scroll down he page to Advanced Customization(customize css)
6. In the box below the Advanced Customization(customize css)
7. Paste the copied code for your background into the box.
8. Then save
9. Then click on (view your profile now) to see your new background.
You can find background codes at http://www.informationzoo.com/Friendster.html
Dec 29, 2009 | Freud 10 Degree X 1" Height Bevel Bowl...
The router bits will not fit in the collet. When the collet snaps into the collet nut the bit does not fit.
The collet is loosely screwed on, correct?
Is it close, or 1/4" off. You may need an adapter for different sized bits.
I have noticed, particularly with Freud bits, that they seem a bit oversized. Try putting the bit in the collet before you insert the collet into the router.
If you're very careful, you can use fine emory cloth (like 400 grit or higher) to polish the bit by cutting a long strip and clamping the bit in a vice, then gently polish the shank a little to allow it to fit into the collet. Pull back and forth on the ends of the sandpaper like you were buffing shoes, but I would only recommend this if you can use a micrometer to check the shank and it is in fact oversize.
You could create a dangerous situation if you polish too much and the bit is not held securely in the collet and flies out when the router is under load.
Another technique is to sand a slight chamfer on the end of the bit to help it slide into the collet.
Or return it and try another brand.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 15, 2009 | Freud FT2000E 3 Router
Cisco router 857
hey you are saying that you want to configure the router,, but rommon mode is for breaking the password....do u forget the password of the router......can you explain why u need to log in through rommon mode
Nov 30, 2008 | Cisco 857W (882658019555) Router
Different Bit shanks
Those with larger bit shanks can hold larger blades. For large joinery cuts, buy a router with a large bit-shank diameter.
Aug 27, 2008 | Dewalt DW618PK Factory Reconditioned 2 1/4...
Can't print
try unplugging the printer and router and restart them your ip- my be used by other device. quicway.com
Aug 17, 2007 | D-Link DP 303 (DP-303) Print Server
Tools & Hardware - Others Logo
781 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
