Question about Pyle 15 in. LCD TV/DVD Combo
Need remote code for Plye 15" TV combo
I need the remote code for this TV combo in order to work with Dish Network.
  • michael584 Mar 03, 2009
    It didn't work :-(
  • 362 Answers
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Let me know if this helps.
Please rate this solution. Lone99star
Posted on Mar 03, 2009
  • Jason Morris Mar 03, 2009
    Sorry this didn't work, the directions are straight from Dish, they have a disclaimer at the bottom stating that the remote will not work on some tv's.
    I have researched your tv to see if I could find a similar code that would at least make some functions work, no luck.
    A universal learning remote would be your only option.
    Let me know if I can help with anything else.
    Lone99star
Need remote code for Coby TFDVD1595
Hi Anna, my name is Kimberly and I form part of the Social Media department with DISH. I have listed the steps below to assist with programming the remote to your TV. If you have any other questions, let me know at Kimberly.escobar@dish.com!
You can lookup codes if needed here: http://www.mydish.com/support/apps/remotecodes.aspx?WT.svl=leftnav
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code.
Kimberly Escobar
Social Media Representative
DISH L.L.C
Feb 14, 2014 | Coby TFDVD1595 15 in LCD TVDVD Combo
Need tv codes for a memorex mltd3222 tv/dvd combo for my direct tv remote
The Dish remote like others only has about 50 possible codes in it--these combo units use odd codes so that remote may just not be able to be programmed for this unit---the remote should have a search mode that allows you to try one at a time every possible code it contains.
May 16, 2012 | Televison & Video
I need to find out what the remote access code is for this device so I can program my dish network remote
Hello! My name is Becki Barned, and I am with DISH Network. I have provided some steps to program your remote. Because I do not know the model number of your remote, there are a few codes to try. I hope this helps!!!
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
764
672
777
Becki Barned
DISH Network Customer Service
Mar 13, 2011 | Sylvania SRTD413 13 in. TV/DVD Combo
Need remote code for gpx tv/dvd combo
I have a code of 749 for it,if not ,try this,press and hold TV button until all the lights come on,press and release the POWER button,press the up button once a second while pointing the remote at the TV,when the remote has found the correct code,the TV will turn on or off,press the pound # button, if it is correct, it will blink three times. ..hope this helps..
Mar 29, 2010 | RCA RCU403 Remote Control
Can't get the tv/input button to work on dish remote control with vizio tv. need it to view local channels run off antenna
Hi there! This is Kimberly Escobar with Dish Network. Just ran across your post and wanted to help. In order to get the remote to possibly work the Inputs on your T.V the remote needs to be programmed to your Vizio T.V. In order to do this we have certain codes that can be integrated into the remote. Some of the codes for a Vizio T.V are 505, 671, and 627. The procedure is press and hold the clear T.V buttton located at the top of your remote until you see all the other buttons light up in red, once they are lid up enter one of your codes followed by the pound key for example: 505#. The T.V button should light up 3 times you can then try the remote to see if it works your T.V
Unfortunately we cannot promise it will completely function the T.V so it might bu that input button does not work. If you need any help please contact us directly at 1800-333-DISH.
Oct 19, 2009 | DISH Network IR Remote Control
Need Sanyo TV code numbers
These are the codes for Sanyo TV'S for this remote. The newer TV codes are at the end so work in reverse order when inputting these codes. Thanks for using Fix Ya.
542, 589, 590, 591, 592, 609
May 22, 2009 | DISH Network IR Remote Control
Need code for wanlida tv/dvd combo
None of Dish's remotes are compatible with your TV make. Most combo units are not supported for some reason. Thanks for using Fix Ya.
Mar 10, 2009 | DISH Network IR Remote Control
Dish Network remote code for RCA 20F510TD TV/DVD
hello and please help.
want to know the codes and way to program this rca dish remote model RCR500SAM1 for my Toshiba tv.
ive done it a few years ago but forgot.
so i need the codes for toshiba tv and way to program this rca dish network remote.
grateful,
kay
Jul 26, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Code for trutech
dish network remotes dont work with very many tv/vcr or tv/dvd combo units
Jul 11, 2008 | DISH Network IR Remote Control
Pyle 15 in. LCD TV/DVD Combo Logo
334 people viewed this question
Top Pyle Televison & Video Experts
Jason Morris
Kev wh
Level 1 Expert
Are you a Pyle Televison and Video Expert? Answer questions, earn points and help others
