Please follow the steps below to program your remote control to equipment other then your DISH receiver: Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control. 1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release. 2. Press the numbers 5-0-0 on the remote control. 3. Press the Pound (#) button on the remote. 4. Press and hold the correct Mode button until all mode button backlights illuminate, then release. 5. Press and release the Power button on the remote control. 6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off. 7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times. 8. To verify the code works try several different functions for that equipment. We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause. Let me know if this helps. Please rate this solution.Lone99star
Hi Gw, my name is Mike Houston a Social Media Representative at DISH. I understand you want to program your innvoage remote to our DISH receiver. When we send out our DISH receivers we will include our own DISH universal remotes that can control many different components like; HDTV, surround sound receivers and sound bars. We do not have the codes for other universal remotes to work with our system. I will provide you a link explaining in more detail on programming your remote: http://www.ehow.com/way_5501311_innovage-jumbo-universal-remote-instructions.html
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
HERE ARE A FEW SUGGESTIONS TO LOCATE A SUITABLE CODE FOR YOUR VIZIO BLU-RAY PLAYER, MODEL VBR231
HITATCHI CODES ~ VIZIO CODES WHICH MEANS YOU SHOULD TRY HITACHI BLU-RAY PLAYER CODE(S) LISTED IN THE DISH NET RC MANUAL.
FROM DISHSUPPORT.COM FORUM: Scott Greczkowski DISHSUPPORT STAFFhances are the 5.3 remote will not control that Blu-ray player.
What will work however is a DISH Network 21.0 remote which not only has
a better IR code database, but also is an IR learning remote. This
means if the code is not in the remotes database you can teach it to
learn all the functions of your Vizio Remote.The DISH 21.0 remote will also work fine with your 622/722.If you can't find a 21.0 remote then please PM me and I can tell you
where you can order one. They may also be available from DISH Network
directly.
*Configuring your devices with a "UNIVERSAL" Remote can sometimes be a stressful and frustrating experience. But it doesn't hafta be!*
Here are a few general
GUIDELINES TO UNIVERSAL REMOTE CODE SUCCESS
READ THE ENTIRE INSTRUCTION MANUAL THAT IS INCLUDED WITH YOUR UNIVERSAL REMOTE (OR DOWNLOAD ONE FROM THE VENDOR'S WEBSITE)
USE THE REMOTES "AUTO CODE SEARCH" FEATURE TO FIND A MATCH TO YOUR
DEVICE (IF A DEVICE HAS ONLY PARTIAL FUNCTIONALITY e.g. CHANNEL +/-
WORKS, BUT VOLUME +/- DOES NOT= CODE IS NOT THE BEST MATCH FOR YOUR
DEVICE)
PRACTICE PROGRAMMING (AN)OTHER DEVICE(S) IN YOUR HOME TO MASTER THE
PROCESS OF PROGRAMMING CODES WITH THEIR MATCHING DEVICES USING YOUR
UNIVERSAL REMOTE CONTROL. TRUST ME, IT BUILDS CONFIDENCE, ASSURES THAT
THE RIGHT PROCEDURE IS BEING FOLLOWED IN ORDER TO PROGRAM THE REMOTE,
AND PROMOTES EXPLORATION OF THE "UNIVERSAL" ASPECT OF THE CONTROLLER.
you will need your Dish network remote to program your dish network box. This universal will not work. but if you need the full codes for this remote to program to your tv then go download the full manual with codes here.
To program the remote to your TV we would need the model # on the back of the remote at the top. To do it yourself you can check out the link provided below to get the codes for TV manufacturers, DVD's, amplifiers, etc.
To program the remote to the TV 1. Turn TV on. 2. Hold TV button on top of remote until all the mode lights turn on. 3. Let go and the TV button will blink. Enter the code found at link below and hit #. 4. Try the use the remote, if it works then push SAT and you're good to go. If not repeat steps 2 and 3 to try a different code.
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, TiVo’s, DVD, Blu-Ray or even HD- DVD players. The learning remote is available at 866-965-3842
Dish Network
Remote Codes 506 or 127
could try Dish Network..Remote Codes 506 or 127 Satellite TV Systems
Dish Network
Dish Network
These are the codes for Sanyo TV'S for this remote. The newer TV codes are at the end so work in reverse order when inputting these codes. Thanks for using Fix Ya.
542, 589, 590, 591, 592, 609
Cable and Satellite content providers control the remote codes,
and we apologize for any confusion during the remote programming.
Please try the following codes 10019, 0178, 10178, 0030, 10030,
0835, 10835, or for Dish Network try 627, 659 or 505. For Fios
TV (Verizon), try the code 3264. These codes may not work on some
universal remotes. If there is another code listed for Element
Electronics in your universal remote control guide, please try that
code. Refer to the Remote Control Guide under your TV’s model
number for more information.
