Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch washer--won't spin at all
Drum is loose when moved--as though it is unhinged
  • 150 Answers
Investigate the drum bearing.
Posted on Mar 03, 2009
Bosch Washer: drum hits heating element
A picture of the damaged element would help. How old is the washer? Perhaps the washer timer or control board is feeding current to the element at the the wrong time, without water in the tub, causing the element to deform and burn out.
Are you certain that the replaced element is sitting in the support groove and not above them inside the tub? Take a flashlight and have a look before inserting the new element.
Oct 30, 2017 | Bosch WFL 2463 Front Load Washer
Start wash program, fills with water, then drum does not turn.. Tried rinse progam, water ,does not turn.. Can hear relays clicking but nothin moving. But the time carries on counting down. It does drain...
If the motor is not spinning, you may have a burnt out motor or faulty Motor Control Board. Else, if the motor is spinning, fix the belt from the motor to the drum.
Oct 29, 2011 | Bosch Exxcel WFX 3267 Front Load Washer
I have a WFMC5801UC Bosch washer It will fill and it will drain the door locks and unlocks but the drum will not spin and the belt is not broken every thing seems fine but it just won't move anymore
Check all socket plugs on all harnesses, motor, printed circuit cards, after unpluging unit. Are there any flashing lights on the circuit boards.
Sep 01, 2011 | Washing Machines
Drum won't move
take the back panel off make sure power is off and check if the belt has come off or broken and also check the pulley that spins belt is tight and if all that is ok then it sounds like the motor might need to be looked at
Jul 05, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch WFL 2060 makes loud noises when spinning. The drum seems to be very loose and it crashes to the sides of the hull when it spins. i can't find any means to fix it in its position? What can i do?
Welcome to FixYa.
Based on what you`re describing you need a major ocerhaul...or at the very least a rear bearing and inner basket assembly.
This is a major job any way you slice it, however if you want to attempt or are capable of performing the repair I can send you a complete service manual via email.
That means you`ll need to reply to me here and post your email address and I`ll send it in a "pdf" attachment.
I would recommend an authorized B/S/H/ service provider though as it is quite involved, but that`s not my place to say if you feel you can do it.
The part`s are...
# 215113 - Inner Drum/Basket
# 236013 - Outer - rear tank/tub assy.
you could try to replace individual bearings and the seals, but believe me it won`t save you much because either way the inner drum is going to be shot, specifically the spindle, and by the time you try to repair all that you may a well have done the outer tub & basket routs.
Let me know how you make out. Like I said I can send you the info on "how to" but you`ll need to do the work or hire a pro.
Good luck.
macmarkus :)
Jul 29, 2010 | Bosch Axxis WFL 2060 Front Load Washer
My bosch washing machine keeps moving across the floor - we have tried to balance but on the spin cycle - it still moves
either ur drum is loose or ur floor is realy bacd. Dont forget that most macianie have adjustement screewed
Nov 19, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Maytag Neptune Front Load Washer has Loose Drum, Bangs, Walks
Check the concrete blocks for cracks or peace broken off the shock will not cause it to do it that bad also check for movement up and down on the inside tub like a lose bearing
Mar 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Bosch Axxis WFR 2460 Front Washer Drum/Cycles Not Working
hi sounds like the motor brushs are worn down,some bosch models you can change them without removing the motor ,but others its best to remove it,they just twist out,and to refit use a small blade flat blade screwdriver to tuck tab in,thanks
Aug 04, 2017 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
Oct 16, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
246 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
