Question about Logitech Cordless Optical Keyboard/Mouse ND9670910403
Batteries in mouse
I have to replace the batteries in the mouse at least once a month. The batteries in the keyboard are the ones I put in when it was new (about 3 months).
  • 1,602 Answers
THERE MUST BE A DEFECTIVE PART IN THE MOUSE BECAUSE YOU SOULDNT HAVE TO CHANGE THE MOUSE BATTERY ONCE EVERY 6 MONTH TO A YEAR, AND THE KB THE SAME 6 MONTHS TO A YEAR.
YOU CAN GO ON LINE EMIAL LOGITECH AND ASK THEM WHAT THE PROBLEM IS, HERE IS THE WEB SITE:
WWW.LOGITECH.COM/SERVICE
RODGANDYSR
Posted on Mar 05, 2009
Batteries ran down in the optical mouse. I put in new batteries and now I can't get the mouse to work. it's frozen
Remove the battery off and keep aside from within the mouse. Now disconnect the USB - optical detector to the PC. Shut down the PC . Replace battery once again and power the PC, then connect the USB to see if the mouse is detected.
If not remove off installed software of the optical device and reinsert once again so that it gets detected.
Nov 25, 2010 | Innovations kb985w RF Wireless Keyboard
I have a wireless HP Keyboard/mouse. (SPS # 481019-001. The receiver (usb) # is 481021-001. My problem is that the keyboard works great and the mouse does not work at all. I have no idea why. I put new...
From the manufacturer's web-site:
http://h10025.www1.hp.com/ewfrf/wc/product?product=3807046&lc=en
the specifications state:
•Energy efficient : Conserve energy with PC sleep button. Monitor battery level with convenient on screen battery level indicator. Long battery life (keyboard - 12 months typical, mouse - 4 months typical).
So, the mouse _DOES_ need a new battery. Take it to a computer-store, to get them to sell you a new battery, after showing you how to remove the old battery.
Nov 06, 2010 | HP Wireless Optical Mouse
Is there abattery? how do you replace it?
Turn the mouse over. On the bottom near the ball there is a panel on the bottom. There should be a ribbed spot. Put your thumbs there and push the panel towards the button end of the mouse. It will slide maybe a 1/4 inch or 6mm and then will be free. You can lift it off. Under the panel is the mouse ball and the batteries. You need two AAA batteries. Take the old ones out and put the new ones in. There is a little engraving showing which end goes where. Once those are in put the cover panel back on and slide it back away from the button end to lock it into place. Normally it will just start working again but once in a while you have to push the connect buttons. Use the tip of a pen to push the one on the bottom of the mouse. after that you should be up and running. If is reaaaaly being annoying you may have to push the one on the triangle antenna or base first then the one on the mouse. The mouse batteries are a bit more annoying then the keyboard ones as it will just stop without any warning. they keyboard usually acts up a bit just before the batteries go. You learn to have some spares around after a while. ;-]
Oct 28, 2010 | Logitech Cordless Mouse
How to activiate iball wireless keyboard and mouse
My keyboard and mouse are microsoft, But, I think they all sync the same, Look on the bottom of the mouse and the keyboard, you should find a small button, one on the reciever also, these need to be pushed in a certain sequence, Mine is the keyboard first, then the reciever, watch the active light on the reciever, it should flash a few times then stay on, then it's synced, Do the same with the mouse, Your's could be different though, it could be mouse first. One more thing they need to be less than a couple feet apart when you do this. so that's it Good luck. Bob
Aug 01, 2010 | Computers & Internet
Where do I replace the battery for a cordless mouse that came with my MK300 keyboard
Q: Changing the batteries in my MK300 trnsp.gif 13634.1.0.jpg How do I change the batteries in my MK300?
Wireless Desktop MK300
Model Number:
Y-R0002 (Keyboard)
M-R0006 (Mouse)
trnsp.gif Battery Requirements:
Keyboard:
  • Requires 2 AAA alkaline batteries.
  • Expected battery life is up to 15 months.
Mouse:
  • Requires 2 AA alkaline batteries.
  • Expected battery life is up to 8 months.
Installing New Batteries
Install the batteries for your mouse and keyboard by making sure the batteries face the correct direction as shown in the image below.
Battery Replacement Tips
  • For best battery performance, always use quality alkaline batteries.
  • When replacing batteries, make sure the replacement batteries are new and are within the manufacturer's expiration date.
  • Do not mix old and new batteries.
  • Do not mix batteries of different brands.
  • Do not use rechargeable batteries in this product.
Jul 25, 2010 | Logitech Cordless Mouse
Friggin thing just stopped working no warning what now
try change the batterys conect first the mouse and then put batterys in the keyboard and all shoud work fine again if not working then contact your seller or manufacture company
good luck i just done my one today after 8 month and now all work just fine
Jun 09, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Logitech wireless mouse and keyboard
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Sep 26, 2008 | Logitech Cordless Desktop MX 3000...
I have a nx2 nexxtech remote mouse. I replaced the 2 batteries (AAA) and it lights up, but does not work on the laptop. Any ideas what is wrong?
First, put charged batteries into your keyboard and/or mouse. Then, plug the adapter into the USB port. Then, press the big, round button on top of the adapter and the CONNECT button on the bottom of the mouse (not simultaneously). Then, press the big, round button on the adapter, and the connect button on the bottom of the keyboard (not simultaneously). Once the computer is on, click the mouse once, and everything should be working fine. If the mouse and/or keyboard do stop working, then either click the mouse once, try the connection process above again, or change your batteries.
P.S. The connection process is only meant for whichever part is not working (i.e. If the keyboard works, but the mouse doesn't, then only do it for the mouse.)
Jul 20, 2008 | Computers & Internet
Mini cordless notebook mouse
You both need to go here, click the link below;
http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=us,en
If you can not find your Mini mouse look to the right for - Contact Technical Support. One or the other will help you acheive a fix for your mini mouse.
Good Luck & kind Regards.
& please vote.
Mar 03, 2008 | Logitech Cordless Mouse
Computers & Internet Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
