Question about Brother IntelliFax-2820 Laser Fax
How do I clean the drum of a brother fax machine?
The fax is coming up saying that the drum needs cleaning and it won't do anything until we do it, but I don't know what to do! Could you help please?
thanks
    Genius:
  • 2,120 Answers
Move the blue slider on top of the cartridge side to side 10 times.
Posted on Mar 04, 2009
I have a Brother Intelifax 2820 that when you fax anything it puts a black line down the middle of the page. I have taken a soft dry cloth and cleanded the corona wire and that didnt seem to help.
the corona wire, which is on the drum unit only comes into play when you are receiving faxes. if i read right and its only on sent faxes, you need to clean the scan glass. that is located underneath your control panel where your originals to fax out get fed. open up your control panel and locate piece of glass that goes left to right across machine. clean that good as you probably have white out or something similar on that.
hth,
razors
Sep 21, 2011 | Brother IntelliFax-2820 Laser Fax
We have a Brother MFC-8840D It states that we need to clean the drum - how do we go about that? Turning the machine off and then on it now says that the toner is low. Are these two separate problems or...
t probably told you to clean the drum because it can't sense toner. I would deal with the toner issue first.
You have about 150 prints @ 7% coverage before it won't let you do anything.
Feb 07, 2011 | Brother Office Equipment & Supplies
The fax machine is saying remove the drum there is dust on the corona wire.
Use the corona cleaning wire to clean the dust off. Open the front cover. Remove the drum/toner unit. look on the right side of the drum portion above the toner unit for a plastic tab with a triangle arrow that points to the left. Slide this tab back and forth several times. Move the tab back to the right. Reinstall the drum/toner unit. Close the front cover.
Clean the corona wire in this manner every time you change the toner/drum.
May 21, 2010 | Brother IntelliFAX 4100 Laser Fax
Fax message says dust on the drum - clean the corona wire
You should find a BLUE SLIDER on top of the Drum Unit, work it back and forth 10 times.
Feb 02, 2010 | Brother IntelliFax-2820 Laser Fax
Fax machine has a message that says "open front cover to remove the drum. Clean the corona wire located on the drum."
The fax machine instruction must be done to erase the
message. The corona wire located on the drum needs to be cleaned.
Sep 24, 2009 | Brother IntelliFax-2820 Laser Fax
Incoming faxes are too dark
u r using refilled cartridge?
remove the drum unit and u can find one blue lever on the right side of the drum unit . slide it 4,5 times then put it back . take a test copy
Jul 15, 2009 | Brother IntelliFax-2820 Laser Fax
Print Quality Problem with Brother 2820 Fax
sounds like you are using generic drum and toner. try OEM (brother brand). you say copies are coming out completely gray. try printing an internal report from the control panel. if that is gray or received faxes are gray, then the problem is not in your scanner area, and i would wager you are using "generic" supplies.
hth,
razors
Apr 10, 2009 | Brother IntelliFax-2820 Laser Fax
HELP
dust on drum you mean? the drum is what holds the toner cartridge of your brother machine. you should clean the blue tab located on the top of the drum when you removed it from the unit. if it still doesnt clear the message,REPLACE the drum with a GENUINE BROTHER DRUM
Nov 17, 2008 | Brother IntelliFax-2820 Laser Fax
LINE GOING THREW ALL FAXES
you have replace the drum and the toner or refill?
Jan 15, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
587 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
