Question about American Standard 2748.002 Town Square Soaker 5' x 42" Bath Tub
My whirlpool bathtub button has to be pressed very hard to start. sometimes it takes two or three pushes to get it going. is there an easy way to fix this?
  • 125 Answers
Sounds like the button may have a bad bellows inside. You will need to change the button out.
US Parts Center you can find one there.
Posted on Mar 04, 2009
The button is hard to push to start the pump.
if you can remove the center of the air button, take some soft emery cloth and run it around the outside of the button and the inside of the air button body to remove the calcium built up there.
that usually will save you about $20 from having to change out the air button completely.
Rod
www.uspartscenter.com
Jan 30, 2013 | Home
I have a Royal Whirlpool bathtub. After I fill the tub with water, I push the button for the jets to start and the jets only work while i am pushing the button. The button is a air button. Feels like I am...
You have a bad neumatic switch. Or a small hole in the air line. Try pushing the button fast and hard to see if it will stay on. if so , it is a hole in the tube. if not it is your neumatic switch
Mar 23, 2011 | Home
Our cetra jacuzzi tub start button is very hard to push. My husband can get it to come on but I can't. What need to be replaced?
if you can remove the center bezel and trim ring, get some emery cloth from the plumbing store and run it on the inside of the button body where the bezel goes up/down and then do the same thing to the outside of the bezel. You probably have calcium deposits on it making it a little too tight for the button bezel to go up and down.
Jan 21, 2011 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
When we press the button nothing happens. It has worked perfect until just recently. Tub is two years old.
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight. Good luck
Jan 09, 2010 | Home
Only used my Royal whirlpool bathtub about three times
My jetted tub will not work, and it used to work just fine. Nothing happens when i push the button to turn it on. Could this be a switch problem? Also do not hear the motor doing anything when button is pushed. Dou you think I just need to get a new pump??
Dec 30, 2009 | Home
Whirlpool bath won't turn on.
Be sure to check the connection at the motor too. Good luck
Nov 30, 2009 | Jacuzzi Amiga, Soaking Bathtub - 9180
I hooked up a Jacuzzi bathtub and pump won't stay on
I bought a new house and I have a jacuzzi bathtube . and all the sudden stopped working .. where or how I can locate the pumpe ? the only thing I see is the button to turn it on or off and now it does'nt go on ?!! I checked the circute praker and everything seems okay to me.... help please.
Mar 08, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Air actuator button hard to push in.
the best plave for you to get a diagram is wholsey.. tell them name brand and size of your tub. and they should be able to help you.
Jan 12, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
American Standard 2748.002 Town Square Soaker 5' x 42" Bath Tub Logo
198 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
