Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Smell and "LE" error
The smell is mildew. I bought my machine used and it had the smell. I ran/run the "sanitize" cycle at least once a week and leave the door open to dry the machines interior whenever possible.
The "LE" error is "overload in motor." We just got this error today, which is why I'm on this site, and I intend to look into the issue. I know our loads are not excessive. We will see...
  • bodinsol29 Mar 03, 2009
    Smell solution: Run "sanitize" cycle as needed and leave door open for interior to dry.
    "LE" solution: Remove back panel and give the drum a spin. Worked for our "LE" error.
  • Anonymous Apr 05, 2009
    I also have the nasty smell. I never received a manual when I purchased this machine so I don't have any idea how to clean it. I use clorox for the door and around the gasket but the odor still remains, Can someone help me please!!!
I haven't been able to get rid of the smell for the 2+ years we have owned the washing machine!  I've tried everything.
We had a LE error light and they (the LG people) told us to unload the machine, unplug it for 30 minutes, plug it back in and then run it empty as follows: turn it on, select spin speed as "no spin" and then press start.  Run it that way twice.
Worked for us, but the smell remains.
Posted on Mar 17, 2009
How do I get rid of small pieces of mildew that appears after washing. Cleaned everything on washer I can see. Ran the cleaning cycle 3x, sanitizing cycle 1x
Mix vinegar and bleach put in spray bottle,wear rubber gloves,spray on the mildew,scrub it,then run a rinse cycle.
Jul 15, 2015 | Kenmore Washing Machines
How do I keep my front loading washer from smelling like mildew
Hi Cheyenne! There are a variety of ways to keep your machine smelling clean. The first and foremost is to make sure you are using the correct kind detergent for your machine.
Do you have a high efficiency washer? If so, be sure you should be using detergent that specifically states it's safe for use in a HE machine. There is a little HE emblem on the detergent bottle or box that clearly states it's safe for your machine, and the machine requires a very small amount when using the correct detergent. The wrong type can cause too many suds. The more suds = the more residue to get stuck in the nooks and crannies where mold can live and breed.
The next tip is to make sure you do not leave wet clothing in the washing machine, that isn't as easy as it sounds, I know ... but it is a big cause of mildew. Also try leaving the door open between washes to allow the interior to dry. With the door closed the water from the last load is unable to dissipate and will eventually mildew. But good news! Even if you've already developed that nasty smell, there are solutions!
Clean the inside of the machine by wiping the interior (drum, door, rubber seal...everything!) using bleach, white vinegar or your favorite household cleanser. They also sell tablets designed just for this problem in the same section you buy detergent and fabric softeners.
make sure you really scrub the the rubber seal, it is often the biggest culprit as there are a lot of nooks and crannies for the mildew to hide out in.
If you have an HE machine, remove the detergent tray and sterilize it
Finally, run a clean cycle on the machine by adding 1/4 cup of bleach or white vinegar to the detergent tray and run the machine through a hot wash cycle. Some machines have a "Sanitize Cycle, and this really does the job. Once that is done, air out the washer overnight: .
Another way to keep that smell from coming back is to put one tablespoon of baking soda in the drum after each load. This will continue to absorb smells while you aren't using the washer, and will be beneficial to the next load of laundry!
May 01, 2014 | Washing Machines
Hello there, We have mold which is hard to remove in the liner of our loader and it also drips down the front of the washer when we have ran it. Do you any advice for removal of mold and to stop the...
Hi Clare. Yours is a common complaint, but easily remedied. In your owners manual, you will find that it is recommended to run the "sanitize" cycle every 30 days. This will kill any mold or mildew inside the machine, and keep it from smelling inside. If you havent been doing this, it will be a little harder to get it clean. The sanitize cycle heats the water to 185 degrees ( approx.) My advice would be to run a sanitize cycle once a week for the next month. Put a cup of bleach in the detergent dispenser each time you run the sanitize cycle for the next 4 times ( without clothing inside). Also, leave the door open overnight after completing your wash. This will allow the internal wash drum to dry out and eliminate any chance of mold or mildew inside. When you see a drip down the front of the machine, it is usually lint or hair stuck to the bottom of the glass door where the seal contacts the bottom of the door. Keep this area clean and lint free and your leaking should stop.
Feb 21, 2011 | Miele W 4800 Front Load Washer
Washer makes clothes smell like dog
Hello there:
please follow these simple steps
Instructions Things You'll Need:
  1. Step 1 Balance your washing machine. Standing water breeds mildew and mold. A washing machine that isn't level to the ground stands a higher chance of not draining completely. Take a level and place it on the top of the machine along the front from side to side and then again along the side from front to back. If the machine is very off, you can adjust the feet to compensate or add something under one of the feet if it is not flat against the ground. Portable washing machines are especially prone to have standing water because they are moved around and not leveled each time.
  2. Step 2 Promptly remove your clothes at the end of a wash cycle. If you regularly leave the damp clothes in the washing machine for an extended period at the end of the cycle, you will have mildew in your clothes and your machine. The same is true if you put clean clothes in the dryer and they are not completely dry when the cycle ends and you don't go back for a few days to pull them out. Damp clothes in an enclosed space for days will mildew.
  3. Step 3 Leave your washing machine door open in between uses which gives the machine the opportunity to fully dry out.
  4. Step 4 Use white distilled vinegar in an empty machine. Run a load with only hot water and two cups of vinegar to clean out the machine and freshen the scent. Vinegar naturally eliminates odors and reduces the buildup of soap residue in the washer which contributes to mildew development. You can also add baking soda and/or bleach to the load for both their sanitizing properties as well as assisting in ridding the smell of mildew.
  5. Step 5 Regularly use vinegar when you wash your clothes. Add 1 cup of white distilled vinegar to the last rinse cycle. Vinegar has acidic properties but it is mild enough that it will not harm your fabric. It does dissolve alkalines in laundry detergent which makes for cleaner and softer clothes. The reduction of detergent buildup in your machine will help to also reduce the incidence of mildew.
  6. Step 6 If you have a front load washer, they are particularly prone to mildew and mold. Follow the manufacturers suggestion as to how much and what type of detergent should be used. It is generally less than the traditional top load washing machines. Once again, additional soap residue helps to breed mold and mildew. Also, pull the seals back from around the door and make sure there isn't a build up underneath them that needs to be cleaned out.
  7. Step 7 Finally, if you have done all of the above and nothing seems to work there are commercial products available that are recommended.
Dec 26, 2009 | Samsung WF338AAB 4.0 cu. ft. Front Load...
What is the sanitation cycle for on Model
Typically "sanitation" cycles require hot water....then they add more heat to the washer during the cycle. It is not 212 degrees, but it is very hot and does kill most germs.
The mildew smell is normally caused by water remaining in the system lines - because the water drain pipe is too high and keeps too much water inside after the system pumps the interior pan. Suggest that you just pour in some bleach after the last load...that should kill all mildew. Please do not overdo it. Only about 1/8th to 1/4 cup is needed to keep the mildew smell under control
Oct 11, 2009 | Washing Machines
Mildew in ge front load washer
Try two things: Add several cups bleach to the tub and run it a complete cycle. When not in use, leave the door open so it will air out.
Jun 04, 2009 | GE WBVH6240F Front Load Washer
Maytag Neptune/ clothes smell like mildew
Go out and buy a box of "AFFRESH". Run it according to the directions.
May 28, 2009 | Maytag Neptune Washer
Hi, I have a hoover front loading washing machine and inside the drum seal there was a lot of mildew as I accidentally left some damp tea cloths inside the drum and the machine wasn't used for 2 weeks....
Run your washer with 2 cups of bleach, maximum hot water. After it starts agitating for a minute, stop the washer & let it remain for 2 hours. Then continue the wash.
Apr 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front loading Maytag Neptune doesnt drain all water
the washer has a low level of water in it at all times. it will never completely drain out unless you pump it. this is one of the reasons there is such a smell with these washers, i use vinegar in rinse cycle and i use bleach once sometimes twice a month to keep mold and mildew smell away.
Mar 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Disgusting odor
I had the same problem, except it wasn't just towels. It was everything. I did some research and found that this is a common problem and nothing a tech can fix. I was about to go out this weekend and spend $1000 on a new washer because I couldn't use this washer on my clothes anymore. I did one more search for a solution and THANK GOODNESS found a solution on another site. A woman had the same problem and, after much trouble, someone at Best Buy finally told her to never use liquid detergent in the machine, not even HE. So I cleaned the inside of my machine, around the door, the rubber seal, etc. I ran the tub clean cycle with bleach and vinegar. The smell was gone and I have been using powder Tide ever since, and the smell hasn't come back!!!!!
Mar 12, 2008 | LG WM2688H Front Load Washer
Washing Machines Logo
219 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
