Question about Hitachi 42HDS69 42 in. Plasma Television
Very odd tv problem
**This is actually about the Hitachi 42HDF39 model which wasn't listed in the product list.**
I only have local channels which I receive with a powered indoor antenna. Last night I was watching tv and switched to a certain channel and it acted as though it couldn't receive the signal so I tried to change the channel to something else but the tv had just ''frozen'' up. The ONLY button on the remote and/or tv itself that would work was the ON/OFF. This has never happened before when the antenna seemed to have a reception problem. The ONLY thing I could do was turn off the tv and the antenna just so I could access my av inputs and all that, which I tested and all are working just fine. I tried several ways to get around this problem but had no luck. I called 1-800-HITACHI and the rep was unable to help me after a number of possible solutions. This morning the problem was still there so I tried something different: I shut off the tv and antenna, turned the tv back on, accessed the DTV menu, and locked out that channel. When I turned the antenna on it acted like it simply couldn't receive that channel and I was able to change the channels and even use the other buttons as if nothing were wrong. If I were to unlock that channel and attempt to receive it, the problem will come back. By the way, the other channels are working just fine. I don't understand how this one certain channel issue is causing the tv to completely freeze up.
On another note, I did lose another channel about a month ago and I haven't been able to receive it at all since then. My next door neighbor also uses an indoor antenna that's weaker than mine and he is able to receive this channel. It was working just fine until we had that ice storm that ran through the eastern coast so I assumed their tower was down, until I spoke with my neighbor and discovered that I was wrong. Is this possibly related to my current issue? I didn't have the current freezing problem when I lost that channel though and attempted to receive it. Very odd. Any ideas?
  • Anonymous Mar 04, 2009
    The info you gave me was helpful in that I didn't know about the need to reboot the receiver if necessary. Unfortunately it didn't work. The signal strength should be fine as I've been watching that channel in digital for months now. I did notice that a couple of times during my experiments the last few days that I would receive a small bit of audio that played over and over like a stuck record, but I haven't seen any video at all, even just a still picture. I tried a different receiver with the same result. I emailed Hitachi to see if this was a software/hardware problem with the tv. Now I just have to wait it out. Many thanks for the help!
  • Anonymous Mar 06, 2009
    The antenna I have is a Philips MANT510 with a gain max of 50dB which can be adjusted in 10dB increments. The channel that is causing the issue (channel 3) has always been a fairly reliable signal and I've had no real problems receiving it. With this channel, anything more than 30dB would mess up the signal reception and 30dB seems to be the magic number for all the channels I can receive. I've tried increasing and decreasing the gain on the antenna for channel 3 without any luck. And this issue still occurs when I use a different powered antenna that I had for the analog signals, which can receive my digital signals just as well as the Philips. So, this makes me think that the problem isn't with the antennas.
    I also noticed in the last few weeks - mainly with American Idol which is on a different channel (11) - that it occasionally causes a reception problem and sticks like a broken record, but doesn't freeze the tv as with channel 3. Even stranger is that American Idol seems to be the only show that does this on channel 11. Other shows are received without issue. The problem has yet to occur on the only other channel I can receive now. In each case there is no video and the only audio plays like a broken record. Could the tv's digital decoder be freaking out?
    And I've yet to hear from Hitachi. Don't think I will be either. Time for another phone call, I guess.
  • 124 Answers
Digital receivers whether external to the TV (converter box, satellite) or built in are digital processors(computers). Just like computers there are times when they freeze up. This can happen if the data stream is corrupted too much to render the picture, but enough signal to lock. The processor attempts to "wait" long enough to gather enough information to begin. Just like computers, these need to be re-booted by turning on or off and sometimes unplugged and plugged in. You have either too low of signal quality or too high of signal strength, which is a problem with digital receivers.
Posted on Mar 03, 2009
  • Jeffrey Johnston
    Jeffrey Johnston Mar 04, 2009
    One last option...you said the signal was fine...is it one of your strongest? The last thing I mentioned (too high of signal strength) might be the problem. Can you access the signal meter and see what it reads? If it reads very high, you can add an attenuator (10db) to lessen the signal. These digital systems have an upper limit of signal where they will drop out or not come in at all. Make sure to check that before you have to spend any money!
  • Jeffrey Johnston
    Jeffrey Johnston Jan 19, 2010
    Yes, after reviewing the comments, it is likely that you have too much signal with the amplified antenna. But, since it worked for some time, you may be witnessing the starting of a slow antenna death spiral.
Hi I got a free Hitachi 54 inch TV from a guy on Craig's list. He said it works great, but I can't seem to get a pic. It was made in 2004 model number is 57F510. I've tried scanning channels nothing.
You've been trapped. A good friend indeed; who gave it to you. !!!!!!!!!!!
Give it up; man. Otherwise, you might have to sell your home to make this TV to get repaired.
Jan 07, 2016 | Hitachi Televison & Video
Tv keeps asking for installation when switching on hitachi L19DG07UJ
Tune the TV in properly. Do a Full Factory Reset tuning rather than just a rescan.
Rescan simply looks at the place holders where the old channels were stored and refreshes them. A Factory Reset (A.K.A. Shipping Condition) wipes the channel memories and starts again fresh.
Sep 03, 2014 | Hitachi Televison & Video
Channel numbers missing
local channels are usually below a channel 1000. they are always on same assigned channel. If your cable box or tv has it, it has option to not display channels with no service on them. you can't reassign the channel numbers. they are channels but not being displayed.
Apr 10, 2014 | Televison & Video
Adding elusive local TV channel?
hi go into your menu do a first time install. follow all instructions. put in your post code should come for your region then.
Nov 30, 2013 | Televison & Video
I have a Hitachi CT 2018 that wont receive signal (picture nor Sound)
Its not a projection set with the model that is listed here. It is a older set also from the model number? You get a lit screen with what?
Also does it have a manual channel selector with a knob?
Dec 21, 2012 | Televison & Video
How to hook a pc
hi just hooked up the VGA cable from your PC into the VGA port of the tv unit and then select pc in the source menu. if it is hdmi or dvi you must need a converter , like vga to dvi or dvi to hdmi etc.
Sep 18, 2012 | Hitachi 42HDF39 Television
Froze
To see if the problem is with your remote control, go to the receiver and use the channel up/down buttons on the receiver itself. If you can change your channels with the buttons on the receiver, the batteries in your remote control probably need to be changed.
If you can't change channels from the receiver, turn off the receiver. Then unplug it for at least 15 seconds. Plug the receiver back it and turn it on. Again, try changing channels from the receiver itself.
Tune to a channel, and while programming is playing, try tuning to the missing channel by entering the channel number on the remote control keypad to see if channels change. Do not try to select the channel from a channel list, program guide, or favorites list.
If this approach takes you to the correct channel, you need to adjust your favorites list function. Press the "guide" button on your remote. Look for a button on your remote called "fav" or "list." Press it several times and watch for an indication at the top of the guide that you are moving from "all channels" to a particular favorites list.
If you are locked on one channel only, your Channel Lock feature is likely active. Consult your owner's manual to unlock the rest of your channels. See your owner's manual for information on managing favorite channel lists and locking out channels. Enter your password, if necessary.
Jul 30, 2012 | Coby TFTV1925 19 in. LCD TV
Hitachi 42HDS69 42 in. Plasma Television Logo
295 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
