Question about GE Monogram ZDI15C Automatic Icemaker
Black specks in the ice
I just cleaned the unit, according to the directions. Had to do it twice. Now there are small black specks in the ice. Any suggestions?
I have city water and I have this SAME problem. My question is if it's what the other guy suggests it is; then why would why would I be having black specks in my ice then? And its only one ice cube at that, It's like the section where the certain cube is coming from has chipped paint from it. There is no pump of any sort in our house IE: sump pumps. Nor are there any kinds of drillings or any water work being performed at this time by the city in the neighborhood either. I thought it might just be plain old calcium deposits. But I haven't been able to find any one who knows anything about this stuff to tell me if I am going about it in the correct way. I certainly don't want to pay mega-bucks for someone to come out to the house and swab the inside of the ice maker with LCR, then tell me to let it run about three to four days without digesting any of the ice cubes or we could get very sick so that and then charge me $75.00 you know what I mean?
Posted on May 28, 2010
I have the same problem and haven't solved it yet. I have a brand new water heater. A retired carpenter/contractor (47 years) posted this, saying that he knew what it was right away. He said it was the deep well pump. (I do have a well). The seal in it had broke and was leaking oil into the water. Every time the pump would come on it would stir up the tiny bit of oil, enough to make it look like a barrel. I haven't had mine checked yet, but it certainly makes sense to me.
Posted on Mar 09, 2009
Black specks in flake ice
add a filter to your water in line
Jul 27, 2016 | Refrigerators
Brother HL 5140 has black specks on the page
There's probably something wrong with the drum unit. I would check the manual on how to change the drum unit. Good luck!
Dec 30, 2011 | Brother HL 5140 Laser Printer
Specks of blue on my printing.
Replace the cyan drum unit. If the specks are always in the same line there is small ding in the drum. If the specks are random then the cleaning blade inside the drum unit is bad. When ever the defect is just one color it usually is that color drum unit.
Apr 15, 2009 | Office Equipment & Supplies
Whirlpool ice dispenser not working, but water is
There are three common problems with icemakers:
There's no ice
Small or too few ice cubes
Specks in the cubes
Note: If your repair problem isn't listed, click here to email the RepairGuru. He will give you the help you need.
There's no ice If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Specks in the cubes If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
Apr 01, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker will not work
Apr 01, 2009 | Frigidaire Optional Icemaker Kit
Oil and black specks on floor underneath washer (middle)
Check the position of the oil mark and check your machine to find out which place was leaking and fix it, maybe you need tie the screw up a little bit.
Jul 21, 2008 | GE WBSR3140DW Top Load Washer
Small lines or specks on the right side of every page
Did you try cleaning the lense? You'll have to pull all the toners and open the little door below and wipe with a clean lint free cloth in ONE direction.
Nov 10, 2007 | Lexmark C510 Laser Printer
GE Monogram ZDI15C Automatic Icemaker Logo
259 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
