Lan card need help please help me out I DONT SEE NO LANCARD ADATORS IN NETWORK ADAPTOR UNDER DEVICE MANAGER IN PROPERTIES OF COMPUTER NOR IS THERE ANY YELLOW MARK WHICH STATS THAT ANY DRIVER IS MISSING
  • lahariarishi May 11, 2010
    please verify it is connected to your motherboard....
  • 38 Answers
First of all are you sure there is one inside the computer? Secondly if it is installed inside the pc itself there may be a problem / driver not loaded. Make sure to install the drivers before trying to use your network adapter. Most of the time they come with a disk or you can download software from another computer!Have you tried another Lan Card? Just like any other PC component they can get fried.
Posted on Mar 05, 2009
What ethernet driver do I need for dell optiplex gx260. There is no ethernet card. Just a slot for the enthernet cable.
check the Device Manager,
Go to Desktop/My Computer/Right Click/Properties/System Properties/Hardware Tab/Device Manager/look for Network Adaptor/ Expand it by clicking the + sign/Do u c any Ethernet Adaptor there or any yellow ? mark there....
If u dont c any Netwrok Adaptor then u dont have a network card installed in ur PC, if u have one then it will show up there, and if u dont ahve the correct driver or if's not installe dproperly then u will have the yellow ? amrk or an ! mark....
then in that case u will need the corect driver for the card to work....normaly Windows installs the required drivers for netwrork cards.....
Dec 17, 2009 | Dell OptiPlex GX260 PC Desktop
My dell pc can't activate the connection
try to use a 3com lancard it is the most compatible lancard for dell i hope this will help
Sep 17, 2009 | Dell Ethernet Card Network Adapter
Need help please help me out I DONT SEE NO LANCARD ADATORS IN NETWORK ADAPTOR UNDER DEVICE MANAGER IN PROPERTIES OF COMPUTER NOR IS THERE ANY YELLOW MARK WHICH STATS THAT ANY DRIVER IS MISSING
- Check the LAN card if properly inserted to the PCI slot of the computer
- If you a yellow mark under device manager, you'll needing to install the driver of the adapter.
- Check for the latest update driver of the adapter.
- There are two ways to install the driver:
*Install the driver using the wizard.
*Force install the driver by right clicking on the icon that has the yellow mark and click update driver.
Note: There are compatibility issue for operating system and driver using any adapters.
Mar 03, 2009 | Computers & Internet
How to setup network adaptor
Technically you should provide 'IP Address" to your network card. Generally IP address is provided by the ISP (Internet Service Provider) provider you are using.
Once you get the ip address you can configure it by right clicking on the my network>properties>TCP/IP setting.
This will work.
Regards
Feb 15, 2009 | Acer Aspire RC500 PC Desktop
LAN CARD ADAPTOR IS MISSING AFTER FORMATING TO XP PRO
Not sure I understand you what you mean. Let me recap:
1) Your LAN adaptor was working before you reloaded Windows XP Pro.
2) Now it’s not showing up in “Device Manager”.
If this is the case, there must be some software driver missing. Make sure there are no other devices that have an error. Double check Dell’s website at www.support.dell.com and select "I'm looking for drivers and downloads". If you don't have the proper version of Adobe you will be prompted to install it. Once installed return to "drivers and downloads" and enter the "service tag", (serial number) of the laptop. Dell keeps a listing of drivers for every customer's computer they sell.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 03, 2008 | Dell Inspiron 1100 Notebook
Lan card is not showing in network adpators for dell inspiron 110
hi gangesh click on the start button......connect to.....go to all connections......the choose your lan connection right click and go to properties........then make sure the bottom two boxes are checked...the one that says show icon in the notification are when connected......and the one that says notify me when me i have limited connectition.
this will give the icons in the tasbar.....
now if you want to put in a manual ip address ect...then in that properties page click on tcp/ip then click the properties button....
there put in your ip and subnet mask and gateway and dns.
hope that helps.
Lancard
I am not clear whether your card is lost or lancard is not getting detected by computer
>>If it is lost then you can connect your computer by USB Cable by installing the drivers for the USB if the USB is not getting detected.
>>If your computer is not able to detect the Lan Card.
1)Check the computer in safe mode with networking by pressing the F8 or any Function key whether the card is showing in Device manager or not
>> Steps for Device manager:
Click start> Click run> Type devmgmt.msc> check under network adapters or in other devices
2) Check whether the Card is properly plugged in the Mother Board of the computer
3) If it is then check the Lan Card by plugging it into another slot
Jun 03, 2008 | Boca LANCard 2000+ BEN400ITR Network...
Belkin mimo G network card
I think in your Pc Wireless lancard is disable,Pls enable the wireless lancard,
1. just check the lan card is enbled
example:my network place --right click---properties---wireless lan card,
2. check the R u getting ip address,
example: start---run---cmd----ipconfig
May 20, 2008 | Belkin Dual-Band Wireless A+G Desktop...
Lan ports dont work
Where you able to check the Network adapter on the Windows Device manager?
How to verify your Network card is working properly
If you are unable to resolve the problem with your intergrated lancard then you can add additional LAN CARD on your computer or you can also buy USB to LAN CARD adapter.
http://www.techdeals.eu/electronics-store/images/tduc0205-1.jpg
Mar 07, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Boot by Lancard.
The D-Link DFE-530TX+ network card does not support booting from LAN (also called Ethernet boot or PXE boot) without the addition of an optional boot ROM chip. You'd need to purchase and install the optional ROM chip before you could use this card to boot your computer from the LAN.
Dec 09, 2007 | D-Link DFE-530TX+ Ethernet ED100W Network...
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
