Question about Microsoft Computers & Internet
In turbo C, what does this error mean?..
''COMPILER TABLE LIMIT EXCEEDED''
I'm not yet in the half of my program, is there a solution to add lines to the clipboard?, i think the solution is to add lines to the clipboard so i cant meet that **** error again.. please help me...
SOURCE: c compiler
lower your screen resolution to the minimum only while using c,c++.
Posted on May 21, 2008
SOURCE: looking for a vista compatible c/c++ compiler
As 32 bit vista does not support full screen 16 bit plarforms(like c/c++) nd not at all suportable by 64 bit vista. to install u have to install the display drivers of XP, that can be found at the site of the manufacturer of ur Laptop/PC(in some cases graphics card manufacturer). All the best...., further having any query , pLz fell free 2 ask
Posted on Aug 12, 2008
jtuckerj
  • 59 Answers
SOURCE: c++ problem BGI ERROR
The most probable reason why the program is not working is because your Turbo C++ BGI Graphics folder is not "c:\\tc\\bgi".
Correct the path and it should work.
If you're sure that your path is correct, press Alt+F5 and paste the error received.
Posted on Jan 23, 2009
ali_zulfikar
  • 156 Answers
SOURCE: turbo-c++ is not installed in full screen
Hi sagar,
Turbo C++ 3.0 is made for MS DOS 6.22 environment. In windows also we can run Turbo C because windows environment provides all native services of DOS. But in Windows VISTA some of the services are revoked. So to enable them either Vista is to be reconfigured or some add-ins are to me installed.
Other versions those can work in Vista are BOROLAND C++ 4.5, VISUAL C++ 6.0, and Visual Studio 2008. But in all these the graphics header file <graphics.h> will not work. Try to find an appropriate graphics header file or copy graphics.h in the cource directory and use #include "graphics.h" command in your C Program.
Please revert to me if having problems.
Zulfikar Ali
ali_zulfikar@yahoo.com
09899780221
Posted on Jan 31, 2009
asmymass
  • 3 Answers
so if rewrite the prog
Linker error:Unable to open file 'TCLASSS.LIB'
this is the basic lib class required by the compiler make sure your libs variable to pointing to the correct location the the libraries required by the compiler.
Sep 25, 2012 | Borland Turbo C++ 3.0 Full Version...
WHICH IS THE BEST C++ COMPILER FOR WINDOW 7
Turbo borland is a well known c++ compiler for both windows 7 and xp.Thanks for using FixYa.
Sep 02, 2011 | Borland Turbo C++ 4.5 Full Version for PC
My system does not support full screen mode for turbo c++ 3.0 compiler
Set your compiler on 16 bit.To do that, do the right click on desktop and select properties. Go to advanced setting and set to 16 bit version.
Dec 23, 2010 | Borland Turbo C++ 3.0 Full Version...
HOW TO RUN TURBO C IN 64 BIT WINDOWS 7
Turbo C/C++
64 Bit operating systems like Windows Xp64, Windows Vista64, and Window 7 will no longer run 16 bit applications and this includes Turbo C 2.01/Turbo C++ 3.0/3.1 or the programs they produce.
Turbo C 2.0 was first released in 1989, Turbo C++ 3.1 in 1991 making these programs nearly two decades old. They are just too old to run on modern PCs.
Upgrade To Modern Compiler
Note that Turbo C/C++ is very very very very old and produces 16 bit programs which no long run on many modern computers. So the best advice is to upgrade to a new compiler. There are many free compilers out there that you can use.
Free Compilers:
  • Microsoft Express 2008 -- Great compiler and comes with a nice IDE (Visual Studio)
  • MinGW -- Command line compiler but there are many IDEs that use it such as Code::Blocks, Eclipse, Dev-C++
  • Borland C++ 5.5 -- Will compile Turbo C++ programs (including graphics.h) but produces 32bit code (slightly better than Turbo C) Only includes command line tools.
  • DigitalMars -- Its still old but at least it produces 32bit programs (better than Turbo C). You might stumble across D++ which is a very powerful language derivative of C++.
  • OpenWacom -- Again, nearly as old as Turbo C, but it produces more modern 32bit applications! (this project is still active too).
If you are just working with C there is:
  • Pelles -- and excellent modern C compiler and IDE. Pelles also has the new TR1 libraries available so you can use regex and other new features. As well as support for many older libraries.
  • LCC-Win32 -- Used as the basis for many of the research compilers.
  • Tiny C -- is said to produce very fast programs.
All of the above are Free and all excellent replacements for Turbo C which is so old it will not even run on your computer.
Regards.
May 24, 2010 | Microsoft Windows Vista Ultimate Edition
How to run tc++ 3.0 in x86 based system
UPDATE: If you get the error Linker Error: Unable to open include file ‘C0S.OBJ’, please try copying the C0S.OBJ from the OBJ folder into the main folder of the compiler. The downloadable archive has been updated with this fix.
The procedures on this post were based on a Windows XP computer. They may or may not be applicable if your operating system is not Windows XP.
Note: Please make sure you followed the instructions carefully before saying that the archive doesn’t work. Thank you.
The download page for Turbo C++ 3.0 was the most, or second most popular page in poochycat.com, my blog whose domain name is about to expire. I’m moving the downloads here. icon_smile.gif
(The rest of this post must be viewed to find the download links and installation instructions)
The Download Link:Turbo C++ Compiler version 3.0 (On MediaFire) (2931) That’s the C program compiler I used to use during my early college terms.
Installation Instructions Download the archive from the link(s) provided somewhere at the top of this post.
  1. Unzip it and place the contents of the archive into a folder inside your Drive C. (e.g., C:\YourFolder)
  2. Please observe:
    This is the TC.EXE file that you MUST run.
    This is the TC Shortcut file, don’t use it.
    The compiler is the file named TC.EXE. Don’t confuse it with the TC shortcut! Simply double click on that and the compiler will run.
  3. Just before you type your program code, please make sure you have the correct path for the INCLUDE Directory and LIBRARY Directory. You can check by clicking on Options -> Directories
  4. The path for the INCLUDE Directory must be C:\YourFolder\INCLUDE.
  5. And the path for the LIBRARY Directory must be C:\YourFolder\LIB.
  6. Remember to change the YourFolder into the name of the folder you are using for your Turbo C++.
Mar 05, 2010 | Microsoft Windows XP Professional with...
How to install c++ compiler in windows xp pc if already c compiler existed?
Un-install the existing compiler (Control Pannel > Add or Remove programs).
Feb 12, 2010 | Borland Turbo C++ 2006 Professional Full...
Color options in turbo c/c++
How Not to Program in C++
How Not to Program in C++: 111 Broken Programs and 3 Working Ones, or Why Does 2+2=5986
Publisher: No Starch Press | ISBN: 1886411956 | edition 2003 | CHM | 280 pages | 1,2 mb
How Not to Program in C++ is a puzzle book with over 100 challenges. Readers must find errors in up to 40 lines of code. By learning to detect the errors, readers become more efficient programmers. Based on real-world programs, readers solve puzzles ranging from easy (one wrong character) to difficult (errors with multiple threads). Clues help along the way, and answers are at the back of the book.
Free Computer eBooks Link:
Download
May 06, 2009 | Borland Turbo C++ 4.5 Full Version for PC
Turbo-c++ is not installed in full screen
Hi sagar,
Zulfikar Ali
09899780221
Jan 31, 2009 | Microsoft Windows Vista Ultimate Edition
When i write the program exception handling in c++. it give the error try and catch keyword. how to handle the Exception handling in c++
You might be using old compiler. Use a latest compiler such as Turbo C++ 4.5 or later. The older versions 2.0 and 3.0 does not support exceptions.
Jan 21, 2009 | Computers & Internet
Computers & Internet Logo
78 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
