Question about Kenmore 22422 Top Load Washer
Water keeps flowing non-stop with my old Kenmore washer
I have an old Kenmore washer (90 series plus) that recently started having the problem - water keeps filling non-stop and flooded my laundry room.
I suppose it could either the sensor or the switch? How to tell which has the problem?
  • 188 Answers
Check the pressure switch and the pressure switch hose.
Remove the end caps on the console and remove the 2 screws that hold it down. Pull slightly from the bottom of the console and flip it up. On the left side you should see the pressure switch (water level switch) with a few wires and a small hose connected to it. The hose should be connected between the pressure switch and the tub. In most cases the pressure switch hose sometimes falls off over time due to vibration.
Replace the hose if it is damaged. If there are no visible holes or cracks in the hose, try trimming 1/4" off each end of the hose (pressure switch side and tub side) and reconnect them making sure to push hose ends securely onto connections. This is done because the hose sometimes stretches at the connection points and you will lose air pressure inside the switch, therefore the water will never shut off.
Alternatively you can use small clamps on each end.
If this doesn't work, check the function of the pressure switch by attaching a small hose to it and blowing lightly into the pressure switch while the machine is filling. You should hear a click and the inlet water valve should turn off. If it doesn't turn off you may need to replace the pressure switch or if the machine fills even when it's in the off position replace the inlet water valve.
Posted on Mar 03, 2009
    Problem Solver:
  • 17 Answers
Start filling, then unplug direct from outlet on wall, if water continues filling, replace inlet water valve.
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Jun 25, 2017 | Kenmore 24032\24036 Top Load Washer
My Kenmore 90 series washer will not drain my water or spin...please help
remove drain hose put in pail at grd level if flow check pump if no flow connect waterhose to drain pipe apply water pressure stop check for drain flow at ground level if okay drain in tub must be blocked
Jun 12, 2011 | Washing Machines
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore series 90 bypassing water. doesn't fill instead water flows out the drain tube once it reaches a level just below small load.
raise the drain hose up till the arch is about level with the back control panel. Once you here the water stop draing restart your machine and it should return to normal operation
Jun 03, 2010 | Kenmore 15864/15862 Top Load Washer
Kenmore 90 Series fills with water but would not agitate or spin
You have a problem with the motor coupling. Top-load washers use what's called a direct-drive system, meaning it does not use a belt but what's called a "motor coupling". I probably replace 5 a week because these little guys break because of 2 reasons that i've found.
1) The break mechanism is too dry and causing the basket to stop at a holt, which puts a lot of strain on the coupler.
2) They break because of over-loading. I don't think you're over-loading though because it was find for 5 straight years.
Good luck to you. The repair is kind of hard to do on your own for the first time, so I would call an authorized technician. It will run you anywhere between $90 to $120 at most.
Best of luck!
Jul 14, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Jul 08, 2009 | Kenmore Washing Machines
if water stops when knob pushed in raise console (probably screws under each end cap just pull caps toward you to remove )remove screws lift console ck small hose going to water level switch to be sure it is pushed on ..if water will only shut off when faucet turned off replace fill valve
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Over flow
hi thanks for the question do you shut the water off with timer do you unplug to stop the water if the only to stop the water is to turn taps off replace the water valve also check the small plastic tube that goes to the water control switch it will get lint in that tube and cause the same problem remove small tube and clean thanks the appliance doc
Sep 27, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 22422 Top Load Washer Logo
229 people viewed this question
Sal De
 Brian Main
Brian Main
