Question about Brother IntelliFAX 5750e Laser Fax
The power went out at the office. when the power was restored my brother intellifax 5750e will not work. there is an error 77 message displaying on it's panel.
  • 215 Answers
You can try this. press "menu/set" " *2864 " within 2 secs. then press "01" and wait for a few seconds until "para init" goes away. then press "99" and when you see "please wait" unplug machine. wait for 15 secs. and plug back in and see if it comes up. if not, then you have a hard error and must have serviced.
good luck,
razors
Posted on Mar 26, 2009
Machine is on and showing "error message #77 and says to unplug machine and call dealer. What is error 77?
Error #77 refers to a mechanical problem, but I'd say about 7 times out of 10 it's a mistake. Fortunately, Brother fax machines have override commands :). Try this:
1. Turn the power off and unplug the power source.
2. Press and hold the menu button and plug in the power source (don't let go of the menu button!).
3. Hold the menu button for 5 seconds after plugging in the power source.
4. Release the menu button and press "91"
5. If the screen still shows the error code, press "99".
Hopefully this will override the error and you can get back to work :) .
Hope this helps! Good luck!
Aug 30, 2010 | Brother IntelliFAX 2800 Laser Fax
I have a Brother intellifax 5750e fax machine. It gave us a "change drum soon" message. I changed the drum but the message has persisted for several days. There were instructions with the drum that...
There should be either a [Clear] button or an [Options] button on the machine key panel.
Open the front hatch and press the appropriate button. Follow instructions on the LCD display.
Oct 27, 2017 | Brother IntelliFAX 5750e Laser Fax
Error 77 message
The 77 error is caused by a fuser temperature sensor. The following steps can be used to possibly reset the Intellifax 4100 77 error.
1. Unplug machine then wait 15-20 minutes.
2. Hold down menu key. Plug in machine.
3. Release menu key at maintenance message.
4. press 91 then set button
5. press 99 then set button
6. Machine will warm up.
7. Press Reports key, then press 1. This will test if the machine can
print.
If these steps do not reset the error the thermal fuse would have to be replaced by a repair technician.
Jul 22, 2010 | Brother IntelliFAX 4100 Laser Fax
Fax machine Error 77 What do we do?
This is a Heater thermistor short circuit, to reset it...
  1. Unplug the power, press and hold the menu button, plug in the power
  2. (hold the menu button for 5 seconds after power is plugged in). Release
  3. the menu button, now press 91, if the display still shows the error,
  4. press 99.
Most people just ignore it, I suppose eventually if the thermoster is malfunctioning you could burn the printer out. But from a cost perspective I don't think it's worth replacing.
Jun 10, 2010 | Brother IntelliFax-4100e Fax
Error 77 on a intellifax 5750e
Unplug the power, press and hold the menu button, the power
press 99
Nov 24, 2009 | Brother IntelliFAX 5750e Laser Fax
Brother IntelliFAX 5750e Laser Fax Machine Error 71, anyone know this and know how?
that error points to your laser unit. chances are 99% that its bit the dust. a tech will have to service it and replace laser unit. thats the only option other than just buying a new fax.
hth,
razors
Apr 15, 2009 | Brother IntelliFAX 5750e Laser Fax
Hello, Our Brother 5750e is displaying an error code of 7C. Is this a coomon problem and is there anything I can do here in house to remedy it. I have checked the manual and there is no explanation for...
worst case scenerio is your engine board has gone bad. first though, try a new brother brand DR400. a faulty/binding drum unit can cause this. usually happens with generic brands.
hth,
razors
Dec 10, 2008 | Brother IntelliFAX 5750e Laser Fax
Installation of seperation rubber - Brother Intellifax 5750e
Pull open the document feeder.
Remove one screw on the chrome plate, pinch the legs of the pad holder to remove.
Sep 29, 2008 | Brother IntelliFAX 5750e Laser Fax
Help with outgoing faxes
Unplug the power cord for 30 seconds. Are you trying to fax on a DSL or any other kind of digital phone line?
Jul 03, 2008 | Brother IntelliFAX 5750e Laser Fax
Brother IntelliFAX 5750e Laser Fax Logo
212 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
